Question about Cameras
How to replace lamp on Anscorama Slide Projector 980
I have a borrowed slide projector, obviously quite old. The lamp has burned out. I do not have the instruction manual. I would like to have some idea of how to replace this lamp before I order one.
Thank you for any assistance you can offer.
SOURCE: Reset Lamp Hours Timer
This works on a couple different Toshiba models -- might work on yours...
Make sure the main power switch is OFF. Hold the "ON", "MENU", and "INPUT" buttons at the same time and turn the main power switch on. Keep them held until the yellow power standby light comes on, then let go. It is done.
Posted on Dec 06, 2007
SOURCE: Slide projector autofocus constantly adjusting
My slide has the remote but remote is not working the projector i have is v5000Af
Posted on Dec 29, 2007
SOURCE: how to replace an hp 070 projector lamp
undo the top cover you will see a black cover with clips and at the back or side there are two small screws which hold the rear concave mirror in place undo the screws bend the clip back gently and remove ....pop out old bulb and put in new bulb with a piece of tissue dont touch it with your fingers.... do all the rest in reverse order ...did mine tonight took 10 minutes just a bit tricky getting screws back in.....you need a long magnetic posidrive with a small head....
Posted on Mar 23, 2008
SOURCE: ekatagraphic slide projector that won't advance the carosel forward or backward. it will pop a slide up and down. it sounds jammed it humms when buttons are depressed any ideas?
The most common causefor the failure of the slide tray to advance or reverse is the breakageof this small Link (part # 217769). It fits on the end of the solenoid actuator arm and is held in place by a Rivet (part # 159943). Thereplacement of this part does not take a rocket scientist, however, amoderate mechnical aptitude skill is required.
This Set contains 1 Link and 1 Rivet. If your projector Does NOT have a focus motor in it, then this is the kit for you. If your projector does have a focus motor, please order "KODAK-KIT" From: https://www.micro-tools.com/store/item_detail.aspx?ItemCode=LINK
Posted on May 31, 2009
  • 685 Answers
SOURCE: projector lamp burn out
What bulb code (usually a 3 letter code) or the model number I cannot say. Sometimes that info is written on the inside cover that covers the bulb, sometimes it is in the instruction manual. It is almost always written on the bulb.
Posted on Nov 08, 2009
Slide continuously change
The clutch contact on your KODAK Carousel 600 Projector has either burned off from use (the projector is almost 50 years old) or is out of adjustment. Either condition will allow the continuous cycle to happen. Because of the projector's age, parts will be really tough to come by. I have attached a diagram to show you what the affected parts look like. Be sure to take extreme caution - - there is exposed electrical contacts all over with the bottom cover removed. Also, be sure to remove the lamp and all optics before starting this repair.
Jan 17, 2014 | Kodak Carousel 600 Slide Projector
Need a replacement dek lamp with a asa code
DEK Lamps for Kodak Slide Projectors are almost always in stock at "Batteries PLUS Bulbs" retail outlets. If you don't have one of these stores in your area, try: www.bulbman.com
Jan 28, 2013 | Kodak Carousel 600 Slide Projector
How do I change my projector lamp?
Instructions
  1. Front Projector
    • 1 Disconnect the power cable from your projector. Allow it to cool for 30 to 60 minutes. Lay the projector upside down on a table.
    • 2 Remove the lamp cover, typically located on one of the rear corners of the projector's underside. Depending on your projector, you will either have to loosen a few Phillips screws or press on one or two plastic release tabs to remove the lamp cover.
    • 3 Loosen the screws holding the lamp assembly in place. Grab the assembly by the handle and slide it out of the projector.
    • 4 Slide a new lamp assembly into the projector. Don't touch the glass on the bulb because it will damage the bulb. Tighten the retaining screws on the lamp assembly and replace the lamp cover.
    • 5 Turn the projector right side up and reconnect the power cable. Power on your projector.
    Rear Projector
    • 6 Unplug the TV from the outlet. Let it cool for 30 to 60 minutes.
    • 7 Remove the lamp cover. On most rear projection TVs, the lamp cover is located on the right or left side of the TV's rear panel. Remove the cover by loosening the screws and pulling the cover away from the TV. Certain manufacturers, like Mitsubishi, have the lamp cover in the front of the TV, near the left speaker. To get to the cover, you must first use your fingers to pry off the front panel below the screen, revealing the speakers and lamp cover. Loosen the screws on the cover and pull it away from the TV.
    • 8 Remove the lamp assembly. Loosen its screws, grab the handle and slide it out of the TV. If you have a newer Sony model, there are no screws. Instead, press the release tab to unlock the lamp assembly and slide it out of the TV.
    • 9 Slide a new lamp assembly into the TV. Don't touch the glass on the assembly, as the oils in your fingers will damage the bulb. Tighten the screws or pop the retaining tab into place.
    • 10
      Replace the lamp cover and front panel, if necessary. Plug your TV back into the electrical outlet and power it on.
Tips & Warnings
  • Touching the lamp assembly before it has cooled can cause a nasty burn.
Read more: How to Change a Projector Lamp ' eHow.com http://www.ehow.com/how_7307928_change-projector-lamp.html#ixzz1rpURlpva
Apr 11, 2012 | Office Equipment & Supplies
I have a sears easi-load circular tray 9985 for a slide projector. I don't know what brand projector it will fit in. Thanks.
I have a number of these. The printing on the box is as follows:
For use with Sears 9833, 9843, 9853, 9854, 9883, 9884, 98833, Sawyers, GAF and Anscomatic tray-loading projectors.
Apr 30, 2011 | Cameras
It hasnot been used in 12 years. it was working for afew days then it wasnt. the power was on but the big light in the back is out.is it the bulb or something else? Is it worth fixing? can I get an...
Chances are that if the cooling fan is running, then you burned out the lamp. Contact Bulbman.com or Bulbs.com for a quote on the lamp. If your projector is a Carousel 4400, then you will need to replace the lamp with an ANSI Code "FHS" lamp. If that's all that is wrong with the projector the lamp will cost you about $40 (best guess).
Dec 08, 2010 | Kodak Carousel 4400 Slide Projector
Kodak slide projector Kodak 600 burning bulbs, fan is working
Excessively short lamp life is usually caused by material building up on the lamp socket terminals, caused by arcing. This material build-up causes higher current loads and will ultimately shorten lamp life. A new lamp socket is a simple solution to your problem!
Feb 16, 2010 | Kodak Office Equipment & Supplies
Light won't come on, replaced old light bulb.
First, check to see if the lamp lights at all (spill light coming out of the projector near the fan). If it does, then the problem could be just the "dark shutter" not opening. If the lamp does not light, it could be a couple of things: it could be the lamp thermal fuse has opened or it could be a bad lamp socket.
Sounds like you need to seek out a factory-trained repair dealer for this one, to narrow down the possibilities!
Apr 20, 2009 | Kodak Carousel 5600 Slide Projector
Slide projector
No, there is no re-set...there is however a thermal-coupler which will burn out instead of your projector burning up. It is close to the "Kodak" name plate inside and right behind the lamp socket. You CAN by-pass this unit but I don't reccommend this since it then could become a fire hazzard. We still repair those: www.flcamerarepair.com
May 04, 2008 | Office Equipment & Supplies
Cameras Logo
201 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
