Question about Mitel 5303 Conference (50001905)
MITEL 5303 Conf Ph
Phone worked at one time. Connected it to analog line but still does NOT work, used original cables that came with product, thinking it might work on digital, plugged it into digital line, FYI - we have a Mitel PBX, please call me at (928) 697-4221 or email me back with solution, PLEASE,
  • 3 Answers
These are analog only phones using a POTs line if you've connected everything properly and all the cables are in fine condition no broken conductors or anything it should work. If the keypad lights up you only need to hit the very buttom button and you should get a dialtone. To make a call you may need to dial a 9 or 909 (depending on the phone system programming) to get an outside line if this connected on an anolog line through a PBX. Probably first test it using a working faxline. If you do not get a dialtone and all cabling looks good it maybe that keypad got dropped. I have one that has been knocked off of a table - someone tripped over the cord - noone will admit it but through testing I've discovered it's in the keypad end, symptons being no dialtone.
Posted on Feb 02, 2009
Will the uperset 4015 work with a magick jack?
No. The Mitel Superset 4015 is a proprietary digital phone that will only work on Mitel telephone systems. It will not work on some of the older analog Mitel systems.
Dec 13, 2010 | Mitel Superset 4015 Corded Phone
Phone isn't working. Message flashing says "Waiting for synch"
This happens on the older software levels of the Mitel phone systems when the phone type programmed does not match the phone type connected. Example: if the phone system programming has a 4015 phone type for that port and you connect a 4025 phone you will get this result. Another cause could be the port you are connected to is analog(used for analog devices such as fax, credit card, modem, or standard single line phone) instead of digital; you would get this result even on the latest software levels.
Assuming that this is the same phone that has been at this location and was working previously, try a different working 4025 phone at this location. If the different phone works, then the problem is in the phone and needs to be sent for repair. If the different phone doesn't work, change the line cord to eliminate possible bad line cord. If the phone still does not work, the problem could be in the outlet, building wiring or in the telephone system. At this point you likely need to call a service technician to track where the problem is.
Dec 10, 2010 | Mitel Superset 4025 Corded Phone...
MITEL 5303 Conference Phone question: during connection of a few numbers and 1 number is busy - how do you drop that call without dropping all parties connected?
I believe that if you reach a busy signal, you can hang up. The conference should ring you back and the rest of the conference will be there.
Here's what the documentation shows from within the help of a 3300 ICP/MCD...
a 5303 is to be treated just like a 2500 series set...
2500, 5302 IP Phone, SUPERSET 401, SUPERSET 401+, and SUPERSET 4001 telephones:
To form a Conference when a two-party call is already in place, or to add another party to an existing Conference:
  1. Press Flash or flash the switchhook.
  2. Dial the number of the next party.
  3. Wait for an answer.
  4. Press Flash or Flash the switchhook.
  5. Dial the Conference Call Feature Access Code.
To Leave a Conference:
  • Hang up.
2500 telephone:
To split a Conference and speak privately with the original party:
  1. Flash the switchhook.
  2. Dial the Conference Call Split Feature Access code.
Sep 30, 2010 | Mitel 5303 Conference (50001905)
How do I start a conference call on a Mitel 5303 Conference Phone? It states it only hosts up to 8-10 people.
I'm assuming you are using this on a 3300 ICP. In that case, the phone system is only able to do 8 party conference calls without an external Conference server.
You can dial the first number, press the flash button, dial the next number, dial the feature code (get from your vendor), repeat until you have all parties as part of the call.
The 5310 IP conference unit works much easier than this phone. A conference bridge such as Audio Web Conference with the appropriate licensing will allow for extended conference calls... it will also allow you to record the call for later "off-air" participation.
Sep 23, 2010 | Mitel 5303 Conference (50001905)
Invalid Set Type Check CDE
The original setup of the phone was most likely done on a mitel 5224, you can only use this model or newer. The 5220 or 5215 will give this error when trying to replace the original phone. To use these phones, delete the extension and redo it.
Jul 12, 2009 | Mitel 5303 Conference (50001905)
Clearwire VOIP ph adapter + Can only connect 1 phone downstairs
http://www.allnet-italia.it/img/speciali/pdf/777702433.pdf
if you need more call me at 804-372-RROD
May 03, 2009 | Linksys SPA-2102 NA Analog VoIP Adapter...
Mitel Superset 4150 will not conect
This phone is a digital phone and requires connection to a digital system commonly called a "key system". If you have removed it from where it was connected and tried to use it at home or somewhere else it will not work. Most home or normal phone jacks are connected to your local provider directly and is what is called an analog system. The 2 are NOT compatable without an interface device. If it is connected to a key system then thier is a problem with the port on the Mitel keysystem that goes to the jack you are plugging the phone into and you will need a technician to fix/rewire this onsite. Hope this helps you. A manual for your phone can be gotton here: http://www.octelephone.com/4150user.pdf
Mar 29, 2009 | Mitel Superset 4150 Phone
Sync massage displayed on the display and set is not working.
Jan 19, 2009 | Mitel Superset 4150 Phone
Need ''short'' cord pinout for Mitel 5303
I have made these cords up before, this cord only uses 2 conductors so a length of Cat3 (station wire) 3 pair or less would be more than enough. Looking straight at the jack end with the tab facing down the pins are numbered from right to left, starting at 1 from the right to 4 or 8 depending on whether it is RJ11 or RJ45. On the RJ11 end pin 2 is red and pin 3 is white,on the RJ45 end pin 1 is red and pin 2 is white. That's it all you need is a crimper and the ends.
Nov 24, 2008 | Mitel 5303 Conference (50001905)
Wanted to use two mitel 5303 for one conference call
Yes you would have to have them on seperate analog phone lines and 1 would have to dial the other. To add a 3rd party you have hit the flash button dial the other party, connect, and hit flash again.
Mar 19, 2008 | Mitel 5303 Conference (50001905)
Mitel 5303 Conference (50001905) Logo
381 people viewed this question
Top Mitel Lands Phones Experts
Shehu Pro
Shehu Pro
Andrew Taylor
Andrew Taylor
Are you a Mitel Lands Phone Expert? Answer questions, earn points and help others
