Question about Philips 50PF9631D 50 in. HD-Ready Plasma Television
TV makes "expanding and contracting" sound and switches "off" automatically
TV is only 1 month old. During this time there has been the occassional contracting and expanding sound coming from the rear of the TV. Tonight the screen turned off (to black screen) with the green "on" indicator light still alight and then within five seconds the screen returned to the TV program I was watching. This happened five times in fairly quick succession. I thought it could be the TV overheating as the gas heater was on. But the room was only 22 degrees. After the heater was turned off the TV functioned correctly. If the heater is the problem what is going to happen in summertime when the ambient temperature reaches 30 and somtimes 40 degrees. Philips technical support have not heard of this as a common fault. I seem to always purchase the dud. Has anyone had the same problem?
  • 74 Answers
Take it back to the store with the receipt and make a fuss so they give you a new one in a box. Do not let them have it repaired, it may never be right.
Posted on Mar 24, 2008
SOURCE:
Why does my TV have sound & no picture?
return it for warranty service
Mar 30, 2015 | Televison & Video
I already have a phone number. I also have an active account that should be about ready to expire. I simply want to renew it so that I can keep my phone active to make and receive calls Help!
Hi Ronald,
All cell carriers that I've ever heard of are happy to keep you under contract - you just have to contact them to let them know at the end of the contract - if yours is not the type that automatically converts you to a "month to month" customer (no contract). This is not necessarily a bad thing! In most cases, you can keep using the device & service under the terms of your old contract. Things (cost, amount of talk / text / data) generally change only when you sign up as per the terms of a *new* agreement. This also when you are offered a subsidized price for a new device. If you're happy with your current device and would rather not have to go out of pocket at all to buy another - or if the amount of talk / text / data is is better under your existing plan - why sign up again? Continue as a month to month customer and you're free to sign a contract with them (or anyone else for that matter) at a time that YOU want whether due to lost or stolen device, better terms in a new contract being offered, etc..
Many carriers answer calls made from the cell phone that are placed to *611 (Star 6 1 1) and they should be able to help you navigate your current contract and new one - if needed. Otherwise, check your carrier's invoice, refill minutes card or website for contact telephone numbers or locations to learn about your contract.
Feb 05, 2015 | Cell Phones
Model HO-0250H, heater makes a pair of snapping noises one after the other, perhaps from expansion/contraction. Heater is two months old.
The unit uses oil to create residual heat. The oil can contain small amounts of moisture and when the unit heats that moisture turns to steam, Steam has a great expansion ratio. When the steam condenses back to moisture it can conglomerate into large water droplets instead of being dispersed. This means that when it heats back up the steam expansion is more radical and makes noise. Unless the unit starts leaking oil, it is fine to continue using it.
Feb 20, 2014 | Pelonis Heating & Cooling
During a hauling in operation the windlass started to making a strong noise and the gipsy stopped turning. I checked the clutch but it was OKAY. I have a little video where you can hear the noise. If...
I would check the wire leads off the windless to switch and from switch to battery (typically ground) During times of extreme load thoes thick wires heat up expand and contract and might loose a little contact or corrosion. Thoes windlesses are pretty bullet proof and very rarely have i seen one break. So I don't think its the winch itself. I would start there. Good luck Aloha
Feb 25, 2018 | Lewmar V700 Vertical Windlass - 12V 1/4" W
My 2month old 40E200 toshiba, has problems with the sound cutting out. Doesn't happen often, but when it does, problem last for about 10 minutes?
Hi This could be a dry solder joint, lack of solder during manufacter in combination with heat causes minute cracks in the solder around a component pin, heat can make the crack contract cutting off the circuit and when the joint cools enough it will expand and connect again until evetually it doesn't connect at all, so please contact your supplier to get it fixed under warranty.
Hope this helps.
(Don't forget the thumbs up if you found the advice helpful! - Thanks)
Feb 12, 2011 | Toshiba Televison & Video
My Maytag refrigerator makes a loud popping noise. It woke me up at 1 am. Refridgerator is 10 years old no ice maker. The sound is pretty loud. Is this a bad sign? Is there any danger here? Should I be...
the popping noise you're talking about, could it just be your self-defroster in operation,sometimes if there a lot of ice and it operates a long time, there could be expansion noises,such as the refrigerator walls expanding/contracting from the heat of the defroster,if it's water you will hear a sizzling popping sound,nothing to fear dear
Dec 08, 2009 | Maytag MSD2756G Side by Side Refrigerator
Have had tv for about 3 years all of a sudden the sound went out came bace 2 or 3 times and is now gone anything i can do?
Try removing the back and re-seating the connectors, or wiggle them . Over time the cheap connectors on boards tend to expand and contract not making good connection. Intermittant problems are a bear to track down.
Jul 25, 2009 | TruTech PLV16190 Television
Vcr playback sound interruptions
Please get the VCR check by any local technician. Since the sound is dropping intermittently it is a hardware issue
Oct 07, 2008 | Computers & Internet
Picture too large for screen after 2 months of normal operation
Have you unplugged your tv for 1 hour and restart it mostly problem will be solved or gently tap on the sides of the tv to get out of the zoom like mode .
How old is your tv ?
Did you replace any component in your tv recently ?
SAM ANDERSON
Sep 25, 2008 | Samsung LN-S4692D 46 in. LCD HDTV
Ticking noise
It is part of the waste gate just above the gas tank. It periodically checks for leaks and pressurizes and releases. Gives a ticking noise when it does this. Not a problem and GM is aware of this and said its normal on our cars.
Jun 02, 2008 | 2007 Chevrolet Cobalt Coupe
Philips 50PF9631D 50 in. HD-Ready Plasma Television Logo
59 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
