The knob broke on my Euro-Pro Model T0160 Toaster Oven. I would like to order a couple of knobs. Lowe's no longer sells the model so will not order a knob for me.
The knob on my euro-pro model to289 is broken. Where can I find another
The same knob on my euro pro broke this morning for no reason. Upon closer inspection there was a crack in the know so I pulled it off and tried to use pliers to turn from warm to toast. It turned but the over still did not work correctly. My toast never toasted and barely got warm. I think the over stayed in the keep warm mode and replacing the piece of plastic on front is not going to fix my problem.
Thanks for allowing me to help you with this problem. It took a while but I was able to find the information you need. Just click on this link:
www.euro-pro.com/europro/productdetail.aspx?pid=8093C938-4393-47B8-A9B5-9D606596B9CE(Euro-Pro+Base+Catalog)
Figure out what you need and place your order. If my information was helpful, please give me a good rating. Thanks for using FixYa!
Check out my solution at this link:
http://www.fixya.com/support/t2513159-plastic_knobs_off_fan_speed_broken_need
Apparently there is no solution to the broken knob problem, so the deal is I will go out and buy another toaster/convection oven from another manufacturer, maybe they will have one that the knob won't break after a few uses.
I have the same problem, the knob for the second switch broke, I clicked on the link you had attached but it said it didn't exist...please advise where I can get a knob for it.
Thanks,
The on/off knob on my euro To161. toaster is broken. How can I get a new one
