Even with new OEM toner, have a darkline along right margin
Continually have a problem with right hand margin having dark line run vertically down the right margin..Need cleaning, a tech? Help.
    President:
  • Office Equip... Master
  • 990 Answers
Hello sir; I don't know what kind machine you have but I can resolve the problem you have, either replace drum cleaning blade or drum cartridge.
Posted on Jan 28, 2009
Canon irc4580i print dark problem
In the process used printer, will be inevitable printed page by your printer have the bad quality prints. For example: Toner specks, Light image, Vertical line, Dropouts, background, Toner smear, Vertical black line and band, Vertical white line, Background scatter, Black pages, Loose toner, Horizontal stripes, Ghost, Uneven Density, poor fusing ...
The common print quality problem Canon IRC-4580 printer
Currently, The Canon IRC-4580 is the laser printer have high speed, easy to use, friendly for user and printing clear text.
However, we can not avoid the damage of some components of the printer when used.
In this article, I will introduce some basic errors with printing quality problems of Canon IRC-4580 printer and "How to fix it".
After viewed artical, you know:
- How to fix (repair/solve) Vertical line (black or white) in Canon IRC-4580 printer
- How to fix (repair/solve) Poor fusing (loose toner) in Canon IRC-4580 printer
- How to fix (repair/solve) Uneven Density in Canon IRC-4580 printer
- How to fix (repair/solve) Light image in Canon IRC-4580 printer
- How to fix (repair/solve) Ghost in Canon IRC-4580 printer
1. Fix print quality problem "Vertical line" for Canon IRC-4580 printer How to fix print quality problem Vertical line
This plobrem "Vertical line" is usally error of Canon IRC-4580 printer. For this "Vertical line" error, technicians divided into two smaller error are: Vertical black line and band and Vertical white line.
Description:
- Vertical line and band: On the printed image appear some straight thin black vertical.
- Vertical white line: On the printed image appear some white vertical voids.
Error location:
- Surface of the charge roller
- OPC drum
- Cleaning blade
- LSU unit
- Developing roller
Cause of error "Vertical line" on the printed page:
- May be surface of charge roller scratched or dirty by toner powder.
- May be have some grooves on the OPC drum.
- May be cleaning blade is damaged.
- May be LSU window or LSU lense has dirty.
- May be surface of developing roller has scratched.
How to fix(repair) "Vertical black Line and Band" for {{SPkey1}} machine:
- Replace the charge roller of toner cartridge.
- Replace the OCP drum.
- Replace the cleaning blade
If printed page are not improved
- Clean the LSU unit by soft cotton cloth and try to print. If Vertical line is not clear on the printed page you should replace LSU unit.
- Replace new axis developer and try to print
2. Solve print quality problem "Poor fusing (loose toner)" for Canon IRC-4580 printer. How to fix print quality problem loose toner
Description loose toner: Toner is not properly fixed on paper, use to hand rubbing lightly on the printed image toner powder may be stick in hand
Error location: toner cartridge or fuser unit
Cause of error "Dark Image or black" on the printed page:
When toner cartridge is empty. You toner refilled by toner powder ware not compatible. This is makes toner cartridge components demaged and temperature of fuser unit is not enough melt to toner powder
How to fix(repair)"Poor fusing (loose toner)" on the printed page for Canon IRC-4580 printer:
With this error, you should replace toner cartridge or fuser unit to fix it.
3. How to fix print quality problem "Uneven Density" for Canon IRC-4580 printe How to fix print quality problem Uneven Density
Description: The printed page has one half light and one half clear.
Error location: Toner cartridge, transfer roller, springs, doctor blade
Cause of error "Uneven Density":
- The pressure force on the left and right springs of the transfer roller is not even.
- May be toner low also causes this error
- Doctor blade has bent
How to repair error "Uneven Density" on the printed page for Canon IRC-4580 printer:
- Replace springs and transfer roller.
- Toner refill toner cartridge Canon IRC-4580 and reset toner cartridge chip (replace new chip) or replace new genuine toner cartridge.
- Replace doctor blade.
4. How to solve print quality problem "Light image" for Canon IRC-4580 printer How to fix print quality problem light image
Description: The printed image is all light and no Ghost.
Error location: Toner cartridge, Developer, HVPS board
Cause of error "Light image" on the printed page
- Enabled toner save.
- Toner cartridge is low
- OPC drum may be faulty by strong light intensity
- Temperature in room is below than 10*C
- Bad contact caused by the toner dirty between the high voltage terminal in the HVPS and the one in the set
- Abnormalities output from the HVPS
How to fix(repair) error "Light image" on the printed page for Canon IRC-4580 printer:
- Disable toner save by change in printer driver.
- Replace the OPC drum.
- Replace developer.
- After printer is power on, wait 30 minutes then start printing
- Clean up the contact between the high voltage terminal in the HVPS and the one in the se- Replace the new HVPS if the problems are not solved by 4 away above.
5. How to fix print quality problem "Ghost" for Canon IRC-4580 printer How to fix print quality problem Ghost
Description: Ghost occurs intervals of the OPC drum or transfer roller.
- OPC drum has fauty.
- The life of the transfer roller has been expired
- The high voltage terminal is contaminated by toner powder or
- Replace OPC drum
- Replace transfer roller
- If performed 2 away and the error does not clear, you should replace ganuine toner cartridge .
- Replacce HVPS board.
Oct 29, 2016 | Canon Office Equipment & Supplies
Vertical line on paper from top to bottom
In my experience if you refill the toner cartridge with the toners available in the market,though they are labelled"for Brother 2140" you get vertical dark patches on the paper. Once in a while you get good quality print too. Replacement with correct toner cartridge seems to the solution.
Oct 22, 2012 | Brother HL 2140 Laser Printer
KYOCERA FS2000D ecosys laser printer. I replaced the toner as per instructions. First print had a vertical line down right margin of page. So googled if I should be cleaning anything because it does not...
its probably on the developer roller look at it as you spin the roller you should see a darker than normal area wipe the roller with a dry cloth until you no longer see it if you are turning it the right way no toner will come out the roller will have a thin even coating of toner on it or try cleaning the charge roller on top of the drum unit it should be 1 of the 2 these machines need to have the oem toner
Mar 16, 2017 | Kyocera FS-2000D Laser Printer
Black line down the right hand side of prints
it may have had a dirt inside that may have been causing the lines. try cleaning with a soft dry cloth then try to print. reseat first the toner before you clean or wipe with a soft cloth
Sep 23, 2009 | Office Equipment & Supplies
4 faint lines running vertically down the sheets of paper
just open the printer cover and clean the toner with tissue paper and make sure the toner is not damage othewise you have to replace the toner.
Sep 09, 2009 | Samsung ML 2010 Laser Printer
White/blank vertical lines
Try cleaning the laser **** glass. If dust or toner is on the glass, you won't get proper or even charge due to this condition. You need to remove the photoconductive drum to check this.
Jun 05, 2009 | Toshiba e-STUDIO 6CP Laser Printer
HP LaserJet 2430 prints vertical grey bands
It is a bad Toner Cartridge or Fuser. Most likey a bad toner cart.
Mar 07, 2009 | HP LaserJet 2430n Printer
Vertical lines
If you have already replaced the toner cartridge as you stated, and the lines appear in the exact same locations as they did prior to changing the cartridge, then the problem is most likely the printhead ( laser ) unit.
Now when I say this, it does not necessarily mean the printhead is defective, it may simply be dirty, or have either dust, toner, or paper obstructing the lasers line of site with the photoconductor.
Remove the toner cartridge, use a flashlight to look into the unit, and try cleaning the printhead using compressed ( canned air ) air. Most of the time the obstruction will clear just by this. In some cases, the dirt on the glass is stuck, and must be wiped off with a soft, lintfree cloth, but try the canned air first.
Please comment after you have tried this and let me know how you make out.
Thanks, and good luck
Nov 05, 2008 | Konica Minolta PagePro 1350W Laser Printer
Installed new toner. Printer prints well, except approx 1 inch of vertical line doesn't print about 1/2 inch from right margin. Have gently shaken cartridge, run a cleaning paper, reiserted cartridge.
Assuming none of your print area margin settings have been changed, it sounds like you may have a defective drum. You can try carefully cleaning the corona wire, a hair thin wire, with a dry cotton swab. Do not touch the drum! The drum is an integral part of the toner cartridge. Return it to the store as defective.
Aug 17, 2008 | HP LaserJet 1022 Printer
Fading output
your balance seems to be off
Apr 12, 2008 | Brother HL 1240 Printer
51 people viewed this question
jasbo
jasbo
