Question about Dacor ECS230 Epicure Electric Double Oven
Dacor eo230sch L 60
I own a dacor EO230 sch oven for 4 years. The bottom oven is displaying L 60 cooling fan code. When the oven was first isnstalled, it didn't work properly and the dacor rep eventually came to our house and anew oven was installed. What is the current code and is this a user friendly repair? Thanks
Jay b
Krazytech
  • 725 Answers
SOURCE: Dacor Wall Oven Epicure EO130
I would call the store you bought it from or dacor as it is under factory warranty...
Posted on Aug 31, 2007
SOURCE: Possessed Oven
I found a new touch panel (or membrane switch pad) for < $166 at http://www.myapplianceparts.com/ . The person on the phone at this company was very pleasant and immediatley confirmed that they had 10 of these in stock. This suggests to me that more than a few of these have gone bad. Luckily, they are very simple to replace if you are willing to turn a few screws and carefully pull of the electrical connectors. I dissasembled mine in 20 minutes, got the part number (#62682B for my ECS130), and found best price in 20 minutes.
Posted on Oct 08, 2007
vitg55
  • 78 Answers
SOURCE: dacor single oven flashes an F2 error code and won't stop beeping!!!
This is from manufacture service manual:
-F2- Alarm Heating Mode High Temperature
Is activated when the ERC senses a runaway heat condition or when the temperature exceeds
“runaway limits”. The ERC will beep until the cancel or another function is selected. If the alarm
repeats the F2 alarm check the oven sensor and wiring after fi rst checking for a stuck relay. If alarm
goes away verify the oven will complete a clean cycle without any type of failure.
Another words the problem with oven sensor or relay board.
Posted on Dec 18, 2008
SOURCE: dacor convection oven is displaying off mode and will not go on
Press the "Cancel/Secure" until the display clears.
Posted on Sep 24, 2009
SOURCE: Display reads U60 Cooling Fan - oven won't heat
I got Dacor to give me the number sequence -- - push "cancel" and "#" at same time - when screen asks for "service ID" enter "S1234" (get "S" by pushing "7" 5 times) - screen will list "U60 Cooling Fan" as number 1, so select "1" - select "clear all", this should clear the error - hit "cancel" to get out of that screen
Hope this works for you! Best suggestion I have is DON'T BUY DACOR!! We also own their 30" dishwasher, which has been a nightmare experience as well.
Posted on Jan 13, 2010
Schematic wiring for epicure double oven eo230sch
Hi I found the schematic and a whole lot more here: http://www.msaworld.com/wp-content/uploads/sites/3/2014/07/Dacor-Technical-Manual-All-Products.pdf
Sep 19, 2014 | Dacor EO230SCH Discovery Epicure 30"...
How do I find the model number on a dacor double wall oven?
The MODEL Series you already said in your question: EO230SCH
Check and see if it is this model:
Good Luck!
Dec 06, 2010 | Dacor Epicure 30" Double Wall Oven,...
DACOR IS A PEICE ****
The hi limit thermostat probably tripped during self clean. It can be manually reset. Turn off the power and remove the grill under the control panel. There is a two wire switch behind the door latch press in the red button on the switch. Reassemble and turn on the power. If it works you can reset the cooling fan to run longer which could cure your problem. Press and release upper broil button, press and release the up arrow, then hold down the broil button until it reads COOL 000. Press the up arrow until it reads COOL 200. Press cancel. Done.
Jul 01, 2009 | Dacor ECD230 Epicure Electric Double Oven
Our Dacor Millennia wall oven will not heat
There is a manual reset button behind the vent under the touch pad. Turn off the power. Open the door. Remove the vent. Behind the latch is a two wire switch. press the red button on it until it clicks. reassemble and turn on power. It over heated when the power went off by stopping the cooling fan.
Mar 04, 2009 | Dacor MCS130SS Millennia Electric Single...
PCS 130 Keypad
Dacor probably won't cover anything. F1 is either the touch pad or ERC (clock). If it stops beeping when the touch pad is uplugged from the ERC then the touch pad is the problem if not it is the ERC. Call Dacor Customer service to get a price on the parts and to voice your displeasure.
May 22, 2008 | Dacor PCS130 Preference Electric Single...
Apr 09, 2008 | Dacor ECS230 Epicure Electric Double Oven
Dacor CPO130W F4 fault
f-4 on decor ovens mean the oven temp sensor is bad. replace the oven temp sensor and it will be fine
Nov 27, 2007 | Dacor ECS127 Epicure Stainless Steel...
The code is telling you that the oven has sensed a fault in the coling fan circuit of the upper oven. Dacor has had a few problems with the cooling fans in these new ovens since theyve been out, so most likely you will have a bad fan motor. If that is the case, be prepared to have the repair person have to pull the oven out of the wall to get to it and change it. If its a realy board problem (less likely) than that can be changed from the front. Call up Dacor and find an authorized servicer in your area since it will still be under warranty. Good Luck!
Feb 05, 2007 | Dacor Millennia MOV130 Electric Single...
Dacor ECS230 Epicure Electric Double Oven Logo
156 people viewed this question
Top Dacor Ovens Experts
Dan Webster
Dan Webster
Vitaliy Gins
Vitaliy Gins
ashburton
Are you a Dacor Oven Expert? Answer questions, earn points and help others
