Question about Frigidaire Dryer Timer Control Knob White 134011703
Dryer timer knob keeps breaking
I have had a Frigidaire stack washer and dryer for 6 years and just ordered my 4th dryer timer knob. It has always been hard to turn and then after about a year, the plastic neck of the knob breaks and I have to get another knob. This scenario keeps repeating. I don't think it is the knob, I think it is the mechanism inside which is very tight and won't turn easily but I don't know how to fix that. Any ideas?
  • 958 Answers
SOURCE: Removal of the timer knob.
you have two different knobs to replace?..is it the water level knob or the timer knob?
if its the timer knob you need to remove, look underneath the timer and you will find a black plastic pin depressed at the middle. pull it slowly for about 1/4 of an inch.
then you can remove the knob in the front of the timer switch.
in putting it back, install the knob first in the timer and then depressed that black plastic pin to lock the knob.
be carefull not to pull the plastic pin all the way out. it would be very hard to put it back in.
cheers,
drcool
Posted on Aug 02, 2008
ngfam1
  • 639 Answers
SOURCE: Frigidaire PS417831 Timer Knob Assembly
Dear etgt3,
ngfam1 here for you!
I am happy to be of assistance!
I believe you should use service for this particular situation!
It sounds like you will may cause it to cost you twice!
once trying and once to pay service!
Here is a good service that I recommend to my customers,
in our 65 year old appliance business!
A&E Factory Service
1-800-905-9505
They are open to make appointments 7days/24hours
A&E is factory authorized service for most brands!
Including warranty work!!!
They will help you, and all will be well!
You will be fine now!
Thank You
Bless you,ngfam1
PS. PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM BEFORE YOU SIGN OFF!
Posted on Aug 26, 2008
SOURCE: needing to take off old timer knob and replace with new one
We found this on another web site:
This was super easy. If you can screw and unscrew a nut from a bolt, its that easy.
The Knob assembaly comes as a whole. So once you remove the old knob (unscrew to the Left).
Then replace the new knob assy (screw to the Right) till its a snug fit. As you will see this knob is designed to be a clockwise rotation only - normal operation - sort of a self tightening screw.
Posted on May 24, 2009
iwillfixforu
  • 619 Answers
SOURCE: Frigidaire GLGT1031CS1 washer timer
Yes. Replace the timer and you are good to go.
Posted on Jul 06, 2010
  • 14 Answers
SOURCE: need part break down for frigidaire FEX831CS top
go online to frigidare's web site,or contact sears parts central
Posted on Dec 19, 2011
How to diagnose washer timer not turning?
Good Afternoon Friend,
I understand that the washer timer on your Frigidaire laundry center, model# GLEH1642DS, stopped turning and you want to know how you can diagnose this. Typically, this is not be a do it yourself repair, as there are no step by step repair instructions. I suggest contacting your local authorized technician for further assistance. They have been trained on your appliance and should be able to diagnose it and determine what is causing the timer button to not turn. Hope this is helpful.
-Best Regards-
WP
Jun 29, 2014 | Frigidaire GLEH1642DS Front Load Stacked...
Dryer timing button off
Hi - Are you referring to the dryer timer button (located on the far left side on most laundry centers) is broken? If so, you might need to replace the entire button. You can contact the manufacturer directly to get part or go through a part distributor but part numbers can be different.
Knob, dryer timer, white-part number: 131873304/MSRP: $24.20
Sep 25, 2012 | Frigidaire FEX831CS Top Load Stacked...
Jul 05, 2010 | Frigidaire GLGT1031C Dryer
Fridgidaire fex831fs1 washer/dryer stack unit: how is washer timer function knob removed from timer shaft ?
i have a frigidare washer dryer combo model fex831fs approximately 6 mo old . turned on a load and water gushing out from underneath, checked hot and cold hoses not leaking, water coming from underneath
Mar 03, 2010 | Frigidaire FEX831CS Top Load Stacked...
I am replacing the washer timer and do not unserstand how to remove the front dial knobs FEA831FS
Hello HmKm, You should be able to just pull the knobs straight off the control stems. Once you have them off, there are a couple of screws on the angled section just above the washer lid. Remove them and you will be able to access the washer controls.
Before you go working on the parts, to remove the control timer, please unplug the stacked washer/dryer combo and turn the water offl. Now you can remove the two screws (that are behind the timer knob) to free it from the metal control panel. Depending on your model, there might be another mounting strap inside the unit that holds the timer in place. If so, remove those screws and you shoud be able to drop the timer down and remove the wiring connection plugs and take out the faulty timer. Now simply push the wiring plugs onto the new timer and reinstall.
Close everything up, reversing the procedures above and turn the power back on and the water and you should be able to use the washer/dryer as normal.
Hope you find this Very Helpful and best regards!
PS: I was one of the folks that was trying to conect with your request for a live chat, but the system wasn't responding, so I aplogize for that technical glitch. Anyway, this is what I would have provided you during the chat session, so best of luck to you in undertaking the repairs.
Dec 12, 2009 | Frigidaire FEX831F Top Load Stacked Washer...
Pressure switch on stack washer
usually the pressure switch is next to the timer or in front.
Oct 09, 2007 | Frigidaire GLEH1642DS Front Load Stacked...
Frigidaire Dryer Timer Control Knob White 134011703 Logo
123 people viewed this question
Top Frigidaire Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Frigidaire Hardware and Accessory Expert? Answer questions, earn points and help others
