Question about Kenmore 99123 Electric Kitchen Range
Ovendoor not closing for tight seal...
Model kenmore elite 970698231, approx 4yrs when using oven on covection bake the door will not close tightly, even the air from the fan will cause the door to move slight thus causing the cooking cycle to halt. there does not seem to be much tension in the springs/hinge. is this my problem
gord
  • hatemyoven Mar 25, 2009
    I have the same problem - the oven door will not close tightly, allowing heat to escape which is becoming very dangerous and is extremely inefficient.  How do I fix this problem?
    President:
  • 1,214 Answers
You should feel the door pull closed when you as you lift it and get near the closed position.
There is some spring linkage associated with the hinge pins at the bottom sides of the oven.
I cannot find the oven you indicated, but I did find exploded views and parts list of the topic post oven on the SearsPartsDirect website.
Posted on Jan 28, 2009
Ice in bottom of side by side Kenmore freezer side
Make sure the doors are closed tight - freezer door may open a crack when frig side closes.
If door is tight, make sure the door gasket makes a tight seal. Often they need to be cleaned (409 is my favorite) or they get twisted. They also sometimes come away from the door in spots. Pay attention to the bottom seal which you usually don't notice in daily use.
Nov 03, 2017 | Kenmore Refrigerators
My oven will not heat in any of the settings - bake, bake covection or broil. The fan and light work. Also, the self cleaning function worked blowing hot air for 3 hours
Sounds like you need to change the heating element in the oven. comes out with two screws in the rear of oven. good luck
Oct 21, 2017 | Ovens
How can I get a user manual for my Kenmore Elite 30 inch Electric slide in range with ribbon radiant elements model number 46804
Kenmore Elite Electric Slide In Range 30 in. 41053 - Sears
www.kenmore.com/kenmore-elite-30inch-slide...electric-range...
Kenmore
Rating: 3 - ‎30 votes
The slide-in Kenmore Elite range 41053 has a true convection oven for faster pre. ...Kenmore Elite 30" Slide-In Electric Range w/ Convection - Stainless Steel ... Owners manual - English (Warranty) .... I called SEARS repair to look at my range and the repairman told me that this range has flaws with the oven fan and there is ...
Kenmore Elite 30" Double-Oven Slide-In Electric Range w
www.kenmore.com/kenmore-elite-30inch...slide...electric/p-02...
Kenmore
Rating: 3.5 - ‎30 votes
The exciting Kenmore Elite double-oven slide-in range 4111 offers all the feature. ... Versatile cooktop options include a 12-inch triple-ring element, a 9-inch Turbo Boil Flex™ element, and a ... Owners manual - English (Warranty) .... Ovens are both conventional or can be set to convection, my first bake was a cheese cake.
Nov 28, 2015 | Kenmore Kitchen Ranges
Will a plain fan convection/microwave ROAST/BAKE as well as a "true" convection that has an extra heating element and fan convection/microwave
Most likely the Kenmore is actually made by Sharp. Most of the combination microwave/convection ovens are. I have one with a "Wolf" name on it, and it roasts/bakes very well.
Apr 07, 2015 | Kenmore Kitchen Ranges
Oven on lock. How do you unlock
most likely the door locked due to an overheat situation. It's a safety feature on most ovens made today. It may be caused by a fan motor not running properly thus allowing area above oven cavity to sense extreme temperature, blockage in air flow pattern, or a bad temperature control.
Whatever the cause, it's best to have a tech take care of this issue for you to prevent danger to you and your family.
Jan 29, 2015 | Kenmore Elite Stainless Steel 40" Dual...
New Kenmore elite range blows cold air from oven vent when top burners are on. Is this normal
That sounds a bit unusual.... Does the fan come on when you turn on the oven on bake? How about on broil? How about on self-clean. If it comes on in all those settings, then it may be working as designed. If NOT, they there may be a crossed wire, or you may have a malfunctioning control.
Nov 11, 2014 | Kenmore Kitchen Ranges
Replace thermostat on kenmore elite
Possibly none of these videos are exactly like your oven but it should give you enough information to get the job done.
Note that some of the videos are not for ovens.
Replace thermostat on kenmore elite oven YouTube
KENMORE ELITE Walloven Parts Model 79048033800
Oct 16, 2014 | Kenmore Elite 30 In. Electric Self-clean...
We have a Kenmore Elite refrigerator that smells like dead fish when the motor runs (we have never put fish in the refrigerator)- what is the problem and is it something that we can fix?
Sounds like water has gotten into the foam insulation or the unit was left closed for a period of time with no power (not running). You may want to try putting a box of baking soda inside the frig and freezer. Place the boxes to the back on one of the shelves as close to the fans as possible. If that doesn't work you may have to shut it down and leave the doors open for a week with baking soda still inside or 2 to 3 days with a fan forcing air into it constantly still with baking soda inside, of course the food inside would have to be removed.
May 27, 2011 | Kenmore Refrigerators
I have kenmore elite 7903670 it seems that the door does not close when we bake is that something normal with this oven
No. It sounds as if the door springs have gotten weak. With the complete model number there are several reputable appliance parts companies on line that you can order from. Hope this helps. Rick
Mar 09, 2010 | Kitchen Ranges
Oven door will not shut tight at top
The door is not tight per say. The seal is hat determines if it is properly closed. Check to see if the seal is tight all the way around(use a strip of paper to check consistency). If it is not sealing the hinges are tweeked and need replacing.
Eric
Feb 22, 2010 | Kitchen Ranges
Kenmore 99123 Electric Kitchen Range Logo
541 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
