Question about Jenn-Air JES9860 Electric Kitchen Range
How do you clean the oven of a Jenn-Aire self clean stove?
The instruction manual's ideas don't work. I tried 409 cleaner with paper towels covering the cleaner for several hours and then tried to wipe it clean and nothing happened. Even the dirty spots on the door don't come clean.
  • blkrauss Jan 29, 2009
    It is a self cleaning oven and the manual says, in big print, DO NOT USE OVEN CLEANER.
  • Anonymous Mar 15, 2009
    Same problem! can not clean oven with oven cleaner (per manual) selfcleaning seems to take forever & don't really clean well
    Genius:
  • 2,920 Answers
Have you tried oven cleaner
Posted on Jan 28, 2009
  • Ronnie Houston Jan 29, 2009
    says that on mine too but i use it before i use the self cleaner for the harder to clean spots it works
How can I clean the roof of my Stoves 720EF Electric Double Oven
I have been using the Lakeland brush on oven cleaner for ALL of the inside of the oven including the stay clean bits without any problems. With the 720, I just brush on the cleaner and follow the instructions. To answer you question, I don't actually lie upside down, you should be able to reach it fairly easily. You may need a number of attempts to get the worse of! Be careful of the thermostat sensor at the top rear right of the oven. It should be bright and clean but will not take any heavy handed cleaning, especially the thin wire leading to/from it. FYI the fan cover at the rear of the oven is held on by 4 self tapping screw and comes off/ goes back on with any problems.(The rear of the cover by the vents build up with grease). Don't use the cleaner on any aluminuim bits ( which includes the fan) as it harms it.
Dec 31, 2011 | Stoves 720EF Electric Double Oven
I have a self cleaning Whirlpool SF369LEK oven. I want to clean the oven bottom manually. Can I use steel wool?
Iwould not use steel wool you can get some non toxic oven cleaner that does not smell very strong and works great spray it on and wipe with paper towels have used before and is great stuff
Nov 20, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
I bought a used 27" Thermadore double oven off Craigslist. (Loves me some Craigslist.) SS, convection, electric. Sticker on side indicates it was manufactured in 2001. I can't find the tag with model...
If Thermador kept the tag information in the same place, look at the bottom of or just below the control panel (front left hand side of the control panel (when facing the oven) where the cabinet curves).
The oven cleaners can damage the finish and parts of the self-clean oven. The damage may cause the oven to fail sooner than it would otherwise.
If you have a small spill that you want to clean without using the self-clean cycle, on a painted surface, use soapy water or Fantastick or Formula 409 applied to a clean sponge or paper towel and then wipe clean. If the spill is on a porcelain surface, wait until the oven is cool and use Bon-Ami or Soft Scrub on a clean sponge. Then rinse clean. For stubborn dirt, use a soap filled pad.
I hope this helps.
(Thermador has manuals on their website: http://www.thermador.com/SupportCenter/DocumentDisplay.aspx?menu_id=27&menulevel=0302&cat_id=687 )
Aug 05, 2010 | Ovens
Uneven Temp in Ovens after Self Cleaning
in the users manual there will be a calibrating page. also self clean is hard on the oven a sensor that is meant to read 400 degrees has a hard time being accurate after 900 degrees
Dec 13, 2008 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
No digital display oven works
We own a Jenn-Aire model W27400W oven. The display module has gradually gone dim over a period of several months prior to the end of the warranty, and the display is no longer visible. It is apparent that several Jenn-Aire oven models use the same display. Does Anyone else have the same problem, and If so, are they willing to join a class-action suit against Jenn-Aire with us?
Steve Patterson
303-256-8494
stevieb4019@comcast.net
Nov 21, 2008 | Jenn-Air JJW8527C Expressions Collection...
Jenn-Air S160
I did it by mistake. I tried to move the lever over and of course, it didn't open but went to restart. I hit the cancel button and then tried the door again and it opened. Yup, we all here feel likes dorks!
Thank you!
Sep 06, 2008 | Kitchen Ranges
Stove cleaning
The filter in the jenn air can be run through the dishwasher. clean the outside of the oven as best as you can before you start the self clean cycle. NEVER!!! use oven cleaner inside a self cleaning oven. or on the gasket. . You can use a degreaser or oven cleaner on the cooktop on any stainless steel, procelain or chrome surface. Don't get oven cleaner on painted or aluminum surfaces. Rinse off very well.
Jul 05, 2008 | Kitchen Ranges
The grease drain line is clogged on my Jenn Air Range/Oven somewhere between the grease storage bin and the bottom of the grill area in the area that is not visible. Is it possible to clean this?
Both grease drain lines on my Jenn Aire SVE 47600 are blocked - I have tried liquid plumber, but it hasn't cleared things up. Has anyone had this problem and figured out a solution?
Jan 13, 2008 | Kitchen Ranges
Jenn-Aire locked tight!
Try turning the oven tempurature all the way to the right (past clean). That is what unlocks mine.
Jan 12, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Jenn air s136 stove won,t self clean
You've probably already read pages 34 through 37 of the owners manual for this oven. We had this stove in the house we bought and the owner wrote in his own directions, which seem to work fine:
1. Turn knob selector to clean.
2. Turn temp knob to clean.
3. Close and lock door.
4. Push enter button and turn dial clockwise to desired time.
5. Push enter button again.
You've probably already tried this, but just in case I figured I'd pass it along.
Nov 18, 2007 | Jenn-Air SVE47100 Slide-In Electric...
Jenn-Air JES9860 Electric Kitchen Range Logo
544 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
