Question about Samsung RS2534 Side by Side Refrigerator
Water and ice
Water runs very slow, and the different ice there seems to be only cushed ice. Takes for ever to get a glass of water.
We did get some one to pull fridge out to see hose was pinched or pluge.
    President:
  • 1,214 Answers
Have you checked the filter?
Did you or they disconnect the line and confirm there was sufficient flow and pressure?
Posted on Jan 28, 2009
Hypothesis concerning the effect of decreasing the temperature on the rate of production of gas from an alker seltzer tablet dropped in water
Reaction with water produces carbon dioxide fizz.
Baking-soda and citric acid react with water to produce sodium citrate and carbon dioxide.
If the water is below 32 degrees and in ice form, then the reaction would be slowed, and/or stopped depending if there was surface moisture on the ice.
Between 32 degrees and boiling, it might be possible that higher temperature water with more actively moving molecules could penetrate more quickly, and disperse the CO2 quicker allowing reaction to be faster.
Above boiling, when water is in steam state, which might be hard to contain and maintain, the table would probably dissolve as water vapor condenses on surface, but it would probably take longer than immersing tablet into glass of water..
Pour very hot water into one glass.
Pour very cold water into another glass.
Drop a table into each glass and see if there is noticeable difference in time before the tablet dissolves.
Mar 10, 2013 | Water Heaters
The water dispenser is extremely slow. It takes one minute to fill a 12 oz glass.
Check/Change water filter - even if new! Also check to make sure your water supply at the wall is turned all the way to the "on" postion.
Please rate us 4 thumbs up!!!! Tips Provided by: GOFAR Services, LLC - We repair refrigerators and all other appliances in the Houston, Katy, Spring and Woodlands, TX areas!
Aug 29, 2011 | LG 26.0 Cu. Ft. Side-by-Side Refrigerator...
Kitchen Aid KSCS23FVMK less than a week old had the waterline installed two days ago. Everything was working well (except it seemed that the ice took forever to be made) until this morning when no water...
Slow water and ice, could mean that you haven't gotten all the air out of your system yet. I would suggest holding the lever down for water for quite some time to evacuate the air out. If I am right eventually water will start flowing.
Jul 01, 2011 | Refrigerators
Water is slow to dispense. Takes forever to get a glass of water? Ice maker seems to be keeping up? 5 yr old professional series in a 5 yr old house?
Try replacing your water filter. If that does not solve it you could possibly have a problem with your water valve or where the water line connects to your house water system.
Oct 26, 2010 | Frigidaire 26.0 cu. ft. Side-By-Side...
Water runs slow
There is a valve on the frige, electric valve sometimes two (main and then branches off to the ice and water) these valves can get fouled, even with softwater. You will need to check and see if the valves are replaceable, there should be on the back possibly under a cover, blue, the other might be higher up behind a cover. they are cheap and easy to replace.
Jun 25, 2010 | KitchenAid KSRA22CN Side by Side...
Water dribbling out of dispencer whirlpool american fridgefreezer
Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
May 10, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Push the water dispenser, water starts but then stops abruptly
Yes , replace the water inlet valve . The piece the wall water line connects to .
Aug 15, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a Kenmore side by side refrigerator/freezer. I am getting really slow flow from water dispensor (outside freezer side door). It takes 20 seconds to fill up a glass of water.
check to see if your ice cubes are well formed or hollow / if hollow replace your filter 1st and if no good replace your water line / if cubes are large and well formed the replace your water valve to fix your water problem.
Nov 26, 2008 | Kenmore 44103 Side by Side Refrigerator
Water leak
IF THE ICE MAKER AND DISPENSER ARE BOTH OFF, THE WATER VALVE IS THE PROBLEM. THERE SHOULD ONLY BE WATER RUNNING WHEN THE ICE MAKER CALLS FOR IT, AND THAT SHOULD ONLY BE ABOUT 7 SECONDS WORTH,
(4 OUNCES).
THE ONLY THING THAT PUZZLES ME ABOUT YOUR DESCRIPTION IS THAT YOU SAY ICE FREEZES OVER THE COMPRESSOR. THE COMPRESSOR IS THE HOT ROUND OBJECT LOCATED UNDER THE REFRIGERATOR OUTSIDE THE COOLING COMPARTMNTS. FREEZING ONLY TAKES PLACE IN THE FREEZER COMPARTMENT. ARE YOU TALKING ABOUT THE EVAPORATOR COILS? IF THERE IS WATER THERE, THE ICE MAKER COULD BE STUCK IN THE FILL MODE AND THE BACK OF THE ICE MAKER FROZEN SO THE WATER CAN'T REACH THE MOLD OF THE ICE MAKER.
CHECK THE FRONT OF THE ICE MAKER BEHIND THE COVER FOR A BROKEN GEAR. IF IT HAS WRITING ON IT THAT SAYS DO NOT ROTATE MANUALLY, YOU NEED TO REPLACE THE ENTIRE MODULE ON THE FRONT OF THE ICE MAKER.
Apr 08, 2008 | Frigidaire GLRS267ZA Side by Side...
Samsung RS2534 Side by Side Refrigerator Logo
77 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
