Question about Kenmore 24032\24036 Top Load Washer
Washer begains to fill but will not start the cycle
The cycle never started but continuing to fill with water and even with the lid closed it overflowed.
  • 640 Answers
Defective pressure switch....replace
Posted on Jan 28, 2009
Samsung Washer model WF448AAP/XAA fills up with water but will not start cycle
That could be the lid switch is open or not engaging.
Check the continuity of the lid switch
Mar 07, 2016 | Samsung Washing Machines
My washing machine fills up with water but does not continue the wash cycle. Sometimes when you slam the lid the washer will continue the wash cycle to the end. Other times the washer stays filled up...
Sounds like the lid safety switch is either out of adjustment, or needs replacement.
Most washers will fill with the lid open, but no continue a cycle where the drum or agitator spin, unless it senses the lid is closed.
Oct 01, 2013 | Whirlpool Washing Machines
Agitator starts at begining of cycle before washer is full
Please be carful as running the agitator without enough water will overheat and kick out the motor, however it should be ok when it resets itself.
Yes, the machine should stop agitating when you lift the lid so this too is part of the problem.
After looking at the print I can only suggest that the cam contacts in the timer ( contacts 12 and 14) that start the motor are burned and stuck together.
Sep 17, 2009 | Frigidaire FEX831CS Top Load Stacked...
Washer fills with water but wont continue washing cycle
Your lid switch is bad or loose.. open and close your lid and see if you can hear clicking noises.. if not.. then your lid switch is broken.. good luck
Jan 21, 2009 | Washing Machines
Kenmore 22082
OL on my washing machine
May 17, 2008 | Kenmore 22062 Top Load Washer
Washer continues to work even if water is not filled to top and even if i try to stop continues to spin
A defective pressure switch can interfere with the cycles that depend upon the switch to indicate when water has filled or emptied from the tub. It can also result in underfilling or overfilling of the tub. The switch routes current from the timer control to the temperature switch and the water inlet valve when the tub needs to be filled. Once full, the pressure switch cuts the current and reroutes it to the motor on the timer control to continue the cycle.
Dec 07, 2007 | GE WBSR3140DW Top Load Washer
Water fills Cycle won't start
Often the lid switch needs replacement. I can become cracked from the lid being dropped.
Nov 06, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore 24032\24036 Top Load Washer Logo
41 people viewed this question
Sal De
 Brian Main
Brian Main
