Question about Audiovox 8910 Cellular Phone
How do i use my cell phone witout the head set icon
I cannot use my cell phone . i can not remove the head set icon. i do not know how to remove it.
    Problem Solver:
  • 9 Answers
This should be automatic so take back to the shop or try the phone menu in settings you can select headset and handset
Posted on Jul 25, 2007
I have multiple icons on my android and I don't know how to remove them
Removal could vary depending on the phone you are using and the version of android you have, and which screen the icons are on.
If the icons have been added to the home screen, on my S4 just press and hold the icon that you want to remove (just a couple of seconds), then drag the icon to the bin at the top of the screen.
If you want to prevent icons being added to the home screen when you install new apps, goto the google play store on your phone, and click on 'Play Store' at the top of the screen. Then goto 'Settings' and untick 'Add icon to Home screen'. Any new installs will be in you applications folder but will not be added to the home screen.
Jun 08, 2014 | Cell Phones
Iwant to know how to install lcd screen
  • Place your cell phone face-down, remove the back cover, remove the battery from its compartment and set it aside.
  • 2
    Remove the Phillips-head screws securing the back panel of the phone. This portion of disassembly varies from phone to phone. Some cell phones require that you pry off the back panel with a thin plastic object such as a guitar pick or credit card. Remove the back panel and set it aside.
  • 3
    Remove the circuit board. This part of the disassembly process varies from cell phone to cell phone. Most cell phones require that you remove the screws securing the circuit board in place. After the screws are removed, you may be able to completely remove the circuit board, but many phone require that you disconnect one or several ribbon cables connecting the circuit board to the keypad, LCD screen and camera. Lift the circuit board out of the phone and set it aside.
  • 4
    Remove the now-exposed LCD screen. You may need to remove a few small Phillips-head screws. Lift the LCD screen out of the cell phone casing and set it aside.
  • 5
    Follow this procedure in reverse to install the new LCD screen into your cell phone and re-assemble the cell phone casing.
  • Oct 09, 2010 | Cell Phones
    CAN I REMOVE 3800 V6 CYL HEAD, WITOUT REMOVING INTAKE MANIFOLD COMPLETLY. THANKS, CARL
    You could try, but getting the intake out of the way usually helps. I don't know how many studs they have there, But I know you won't be able to move either the head or the intake either direction to slide it out. So, you might as well take it off. Hope this helps.
    Aug 31, 2010 | Buick Regal Cars & Trucks
    How to fix my razr v3x camera?? i need help!!
    go to settings then click on master reset,and should work like new witout problems.if my info was of any help please leave a comment ,thankyou.
    Sep 02, 2009 | Motorola Mobility RAZR V3x Cellular Phone
    Remove icons from screen
    goto menu,tools,settings,general,personalization,standby mode
    there set active stand by to off.then you can see the screensaver
    Sep 01, 2008 | Nokia N95 Cellular Phone
    Head set icon
    you need to change that icon to normal
    Jun 12, 2008 | Nokia 6233 Cellular Phone
    My n70 mobile phone does not switch on is there any way to switch it on witout the button
    Without disassembling it fully, unfortunately not in any way that doesn't also reset the phone back to factory settings.
    May 26, 2008 | Cell Phones
    How do i remove square blue icon on top left hand corner of screen?
    its the symbol for the 3g signal to turn it off go into menu then to settings, scroll across to connectivity then to mobile networks and then to gsm/3g network and select gsm only, it should then go away
    Jan 19, 2008 | Sony Ericsson W850i Cellular Phone
    Nokia 3230 headset icon can't be removed
    If factory settings didn't work,this will SURELY help:
    1.Turn off your phone..
    2.Press and hold three keys, i.e. Green Button(call answer key) + " * " button + " 3 " button and while holding the buttons boot the phone..
    3.Hold till the phone shows the Nokia Logo/formatting screen..
    The problem will be solved for sure..
    Regards..
    Dec 02, 2007 | Nokia 3230
    Audiovox 8910 Cellular Phone Logo
    55 people viewed this question
    Top Audiovox Cell Phones Experts
    Marvin
    Marvin
    John Porter
    marty morrison
    marty morrison
    Are you an Audiovox Cell Phone Expert? Answer questions, earn points and help others
