Question about Hoover U5750-900 WindTunnel Bagless Upright Vacuum
Replacement belt # for hoover wind tunnel model u5750-900. original belt # 38528-035, please
Your belt number is correct ending in 035. I have had luck with belt number ending in 033 also.
Posted on Jan 29, 2009
I have a Hoover Wind Tunnel vacuume that the brush does not work. Replaced it with the Hoover Belt 38528-034 and it does not move what's up with that?
The brush roller may be clogged with debris. If so, the belt will only slip until it burns through from friction.
Nov 19, 2017 | Hoover Vacuums
Where is belt located on Hoover wind tunnel vacum. And how to replace it. My brushes are not spinning.
Its usually located underneath the body of the unit, turn it upside down and you should see the beater brush. You need to open the bottom cover to get at the brush and drive belt.
Mar 25, 2015 | Hoover U8126-900 Wind Tunnel Dual V...
How to change a belt on a Hoover wind tunnel
It depends largely on the model. Do you know the model number? you can get any hoover replacement belt here:
Replacement Hoover Vacuum Belts
Dec 09, 2009 | Vacuums
How do you change the Hoover wind tunnel belts?
If you turn the vacuum over there will be (4) screws that hold on the base cover for the roller brush. Remove the screws and the cover and you can get to the belt(s). You can get replacement belts here:
Hoover Windtunnel Belts
Nov 18, 2009 | Hoover Company Wind Tunnel U53019 Upright...
We've changed the bag and we are still not getting good pick up. It seems to leave small paritcles and bits of fuzz.
Did you change the belt? If the belt is worn or stretched it won't pick up well. You can get replacement belts here:
Replacement Vacuum Belts
Nov 16, 2009 | Hoover Company Wind Tunnel U53019 Upright...
How to change the V belt on hoover wind tunnel U6435-900 ?
Below I have listed a link to the manual which has instructions and a link to the V belt you need.
Windtunnel Manual
Windtunnel Replacement Belts
Nov 03, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
How to replace belt on Hoover Wind tunnel vacuum
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=831441
Generic problem for all Vacuums
Posted by dinosir on Jul 25, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. All you would need to do is to remove the bottom plate by screws, clips or levers and that will get @ the belt(s) – some Hoover WindTunnels have one and the self propelled models have 2 – you can cut off the belts or slide them off and 1st you need to hook the larger belt onto the brushroll & if you have 2 belts hoof both onto the brushroll pulley and then use a belt puller or a screwdriver with a hook on the end and pull or stretch the belt(s) onto the motor pulley and then track the belts in a straight line and replace the bottom plate and then start up your vacuum. The recommended belt change for a vacuum is every 4 to 6 months for the best cleaning. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 25, 2008 | Vacuums
Changing belts on Hoover wind tunnel U6401
Take off the bottom plate covering the brush roll, 4 screws. There are 2 belts, if you replace both, put the V belt on 1st, then stretch the flat belt over the motor shaft, then over the bigger pulley along side the V belt.
May 20, 2008 | Vacuums
HOW DO I REPLACE THE DRIVE BELT ON A HOOVER WIND TUNNEL SELF PROPELLED
Take the brush belt and slip it over the pull into the groove. Then take the flat belt and hook onto the motor shaft and then pull belt over pull and push it around the entire pulley. It can be difficult but after the first time it is easy. You have to push the belt up with your thumbs so the belt will wrap all the way around
Apr 06, 2008 | Hoover Company Wind Tunnel U53019 Upright...
Hoover U5750-900 WindTunnel Bagless Upright Vacuum Logo
242 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
