Question about HP DeskJet F4280 All In One Printer InkJet
Replacement ink cartridge printing like low ink
I have just replaced my C4280 black ink cartridge and it is printing as though it has low ink. Very faded. I hit the okay and printed a test page scanned it to align the cartridge and still printing faded. Any suggestions.
    Genius:
  • 2,120 Answers
It's dried up inside of the cart.
Posted on Jan 29, 2009
New black very faint
1. hope you have not touched the contacts or head those protected by pink tape.
2. or the ink is dried up
Replacing Cartridge HP Photosmart C4280 All in One Printer
Apr 06, 2016 | HP Photosmart C4280 Aio Printer
HP Photosmart C4280 All-in-One printer, printing in only black blue and weird pinky red
Replace color ink cartridge ,black cartridge is not required because of black prints are ok..
Sep 04, 2012 | HP Photosmart C4280 All-in-One InkJet...
Dell V305w Printer Alignment problem. Remove tape from cartridges or check troubleshooting. Press > to continue. Ink cartridges reset, tape removed, trays aligned. HELP!
In my case this happened with black cartridge out of ink, colour cartridge low; replaced black: had permanent alignment problem, though test print looked OK; wouldn't print black. Replaced colour cartridge, then it all worked OK, straightaway!
Aug 24, 2010 | Office Equipment & Supplies
My HP C4280 won't recognize the ink cartridge.
Are you using aftermarket of refilled cartridges? The electronic chip may be damaged so that the printer cannot sense the cartridge. Try using a new OEM cartridge. Chances are that the problem will go away. If it does, take the faulty cartridge back to where you got it and ask for a replacement or a refund.
Nov 07, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
I have refilled the cartridges on my HP Photosmart C4280. I know this is not advisable but I'm afraid I can't afford their prices. So far so good - it seems to print fine, my problem is that I still...
When refilling an inkjet cartridge that contains a chip, the chip records when the cartridge goes low and then empty. The chip needs to be replaced to eliminate the low or out message. You can set the printer to continue printing when it receives an out message even though there is ink available. However if you do run the printer and there is no ink flowing it can cause damage to the prinheads.
Nov 05, 2009 | HP Office Equipment & Supplies
Printer will not recognize new blk ink cartridge.
I think either the printer's scanner(or film as some call it) and/or the carriage is faulty. The signal cable that connects the carriage to the logic board could also be a suspect. Try replacing these items one after another and the culprit will be isolated. Good luck.
Jun 03, 2009 | HP PhotoSmart C4280 Laser Printer
How do I install ink cartridge for hp photosmart C4280
To replace the print cartridges
1. Make sure the HP All-in-One is on.
CAUTION: If the HP All-in-One is off when you open the print cartridge door to
access the print cartridges, the HP All-in-One will not release the cartridges for
changing. You might damage the HP All-in-One if the print cartridges are not
docked safely when you try to remove them.
2. Make sure you have letter or A4 unused plain white paper loaded in the input tray.
3. Open the print cartridge door.
The print carriage moves to the far right side of the HP All-in-One.
4. Wait until the print carriage is idle and silent, and then lightly press down on a print
cartridge to release it.
If you are replacing the tri-color print cartridge, remove the print cartridge from the
slot on the left.
If you are replacing the black or photo print cartridge, remove the print cartridge from
the slot on the right.
1 Print cartridge slot for the tri-color print cartridge
2 Print cartridge slot for the black and photo print cartridges
5. Pull the print cartridge toward you out of its slot.
6. If you are removing the black print cartridge in order to install the photo print cartridge,store the black print cartridge in the print cartridge protector or an airtight plastic container.
7. Remove the new print cartridge from its packaging and, being careful to touch only
the black plastic, gently remove the plastic tape by using the pink pull tab.
1 Copper-colored contacts
2 Plastic tape with pink pull tab (must be removed before installing)
3 Ink nozzles under tape
CAUTION: Do not touch the copper-colored contacts or ink nozzles. Touching
these parts can result in clogs, ink failure, and bad electrical connections.
8. Slide the new print cartridge forward into the empty slot. Then gently push the upper
part of the print cartridge forward until it clicks into the socket.
If you are installing the tri-color print cartridge, slide it into the left slot.
If you are installing a black or photo print cartridge, slide it into the right slot.
Work with print cartridges 69
Maintain the HP All-in-One
9. Close the print cartridge door.
If you installed a new print cartridge, the HP All-in-One prints a print cartridge
alignment page.
10. When prompted, ensure plain white paper is loaded in the input tray, then press the
button next to OK.
NOTE: If you have colored paper loaded in the input tray when you align the print
cartridges, the alignment will fail. Load unused plain white paper into the input
tray, and then try the alignment again.
11. Place the page print side down on the scanner glass and then press the button next
to OK to scan the page.
When the On
Please Don't forget to rate this solution. Thanks.
Feb 17, 2009 | HP Photosmart C4280 Aio Printer
Ink cartridge replacement
I had the same problem, and after scouring around online for a few days, I learned that this is one of the biggest gripes about this printer. Basically, you're out of luck unless you replace EVERYTHING, even though you only want to print black (nuts, isn't it?). So I went out and bought all new color cartridges, and it STILL won't print. I think it's just a bad printer all around. :(
Sep 07, 2008 | Epson CX8400 All-In-One InkJet Printer
C4280 printer photo cartridge instalation help
The extra cartridge you bought was probably the number 99 cartridge, if I'm not mistaken.
The cartridge actually replaces your black cartridge. Inside of the cartridge has black ink as well as the special photo ink.
I hope this helps
-Ernest
Mar 07, 2008 | HP PhotoSmart C4280 Laser Printer
HP DeskJet F4280 All In One Printer InkJet Logo
336 people viewed this question
Seeker5211
Seeker5211
