Question about Intermec EasyCoder 3400e Thermal Label Printer
Easycoder 3400e only printing half a label
We have 3 easycoders 3400e that were working just fine the other day but now all 3 of them have this same issue. We use Bartender 6.0 software to print out our labels. So the problem is that when you try to print either one label or multiple of labels, it will print out only the first half of the label and stops. When you hit the form feed button it goes to the next label and does the samething.
What we have done:
1. Change out the printer cables
2. Updated the computes to the newest driver Seagull has on their website.
3. Fully deleted and reinstalled the printer.
after all of that we are still having this issue with it just only printing the first half of the label. Any help would be great thanks.
  • nsondag May 11, 2010
    Have you looked at the settings for the paper size? I would check the paper settings in Bartender and in the printer's properties and make sure they are both set correctly.
    Champion:
  • 254 Answers
Check the size of the labels in your software
Posted on Sep 11, 2009
Intermec EasyCoder PM4i Printer will not print
Will it do a test print? Probably something like holding the button whilst turning it on.
Jul 06, 2016 | Intermec EasyCoder PM4i Label Printer
Easycoder C4 Printer wont print
See if this can help:
epsfiles.intermec.com/eps.../1-960572-01%20UG%20EC%20C4.pdf
May 26, 2014 | Intermec Easycoder C4 Therm Label Printer...
Printer printer duplicate labels
i have the same issue, this case happened when out of paper or ribbon, while this program and label form works fine with the zebra printer
Oct 18, 2012 | Intermec EasyCoder PM4i Label Printer
Crinkled ribbon
Try adjusting the head tension or ribbon tension.
May 19, 2009 | Intermec EasyCoder 3400e Thermal Label...
Mis align printout
hi, its hard to say but.... does it feed ok or skip labels??? if it skips labels, the sensor will need replacement or adjustment, also download the latest drivers, and if your driver or software gives u the option, play around with the magnification settings, also double check length, borders etc, try making the label length setting appear longer , shorter etc. Hope this is of help to you,M,
Feb 12, 2009 | Intermec EasyCoder PM4i Printer
Intermec PC4 label printer
Your printer is not sensing the gap between two labels.Please try calibrating the printer for the gap.
Switch ON the printer while holding FEED key down, on printer start feeding label realese the FEED Key.
Printer will stop feeding paper after printing SELF TEST, Once again press FEED key for 3 seconds. Printer will enter into normal Mode.
Check now.
Aug 14, 2008 | Intermec EasyCoder PC4 Label Printer
Failed to print using Intermec Easycoder pc4 label printer
If you have another USB port asidefrom the oneyou are using now try to transfer your printer cable. Make sure your USB port is firmly connected to the motherboard. Follow the USB connectors and check if these are well fitted and not loose.Apply pressureon the endsto set the connectors.
May 12, 2008 | Intermec EasyCoder PC4 Label Printer
Intermec EasyCoder 3400e Thermal Label Printer Logo
447 people viewed this question
Top Intermec Office Equipment & Supplies Experts
Paul Bade
Don  Farrell
Don Farrell
Arizona Information...
Are you an Intermec Office Equipment and Supply Expert? Answer questions, earn points and help others
