Question about Brother ML-100 Typewriter
Correction tape is stuck
The correction tape and ink tape somehow was switched and when I was tying nothing was happening and when I deleted it began typing. I took out the ink ribbon and now my correction tape is stuck... when someone turned on the typewriter the correction tape aligned to the left and now it is stuck. How can I fix this? HELP!
  • 20 Answers
SOURCE: Print head and ribbon do not in sync
sounds like the ribbon carriage is out of position, try holding the shift, and code keys, then power up, if thats no help the hold frame might have to be resitted.
Posted on May 01, 2007
squipps
  • 204 Answers
SOURCE: typewriter won't type letters
HI.. the hammer solenoid may be faulty..it should make a typing sound when you hit a key.( the printhammer moved and strikes the printwheel) or when you changed ribbons you might have unlatched the printwheel..there is a lever you press to relatch it until it "clicks"
If not that then make sure the ribbon is seated correctly, that it is between the printwheel and the black roller.Also visually inspect the ribbon so it is not caught in the printwheel.
Posted on Feb 06, 2008
Bubbabear64
  • 2794 Answers
SOURCE: Typewriter suddenly will not print!
It's been awhile since I've worked on these.
What is the typing mechanism in here? I believe Brother was using a wheel.
Posted on Jun 19, 2008
  • 14 Answers
SOURCE: the correctional tape
Hello. I had a similar problem, and Upstatoes helped me. Mine started with striker stuck forward, and then went to working for a few days, but sticking forward again And it was caused by the spring not being in the right place. But the correction tape housing is pushed up and pulled down by the white, adjustable piece on the right side, that has the screw holding it into the adjustment place. If you take off the ink ribbon, push the carriage to middle, and turn on the typewriter, there will be a switch at the top left of the keyboard, on the underside, you will need to flick with your finger, one time, as the carriage moves to the left. This is the reference switch, and you will be tricking the typewriter into thinking it is now in the left side start position. After this, you can see the white adjuster piece on the right side of the carriage, and, as you type a letter, also see if it is holding down the correction tape housing. Then when you hit the erase key, see if the cam on the inside (looking through the small holes in the correction tape housing) turns and pushes up this housing? It may be the tab in the white adjuster is not inside the grove of this cam. Either way, at that point, you may be able to see if something else is not as it should be? My problem was the long side of the spring was not underneth the white adjuster. (I had been putting it under the housing, and it was not helping ot push everything up like it should be.) Aparently this cam with the white adjuster tab in the groove holds everything down, easily, as you type, but has to have the spring help to push up when you use the earse key.
Posted on Sep 18, 2008
faxman789
  • 297 Answers
SOURCE: Replaced Typewriter Ribbon & Now Correction Tape doesn't work
Is the ribbon that you installed a correctable one? It should have a yellow or orange knob to turn it. If that knob is blue, you installed a multistrike or non-correctable ribbon.
The only other thing is you have the correction tape in backwards
Posted on Jan 15, 2009
I was driving and the van just died. it still turns over just doesn't fire. i'm guessing it lost spark or gas. nothing happened, no warning signs. it just died. fuel pump is 1.5 years old. whats a fast...
Have someone turn the key on while you have you ear close to the fuel tank. You should hear a 1-3 second whirr as the pump builds up pressure. If no sound you can tap on the tank with a rubber or dead blow hammer to see if the pump is stuck. This trick will only work so many times before complete failure! Fords also had a fuel pump shut off switch, after Pintos started blowing up. Most cars had them in the trunk under the plastic covers. I'm not sure on the vans. Look for a small black box with 2 wires near the tank on the inside of the van. You can cut out the switch and tie the wires together with a wire nut and black tape or shrink tube to bypass the switch.
Feb 19, 2011 | 1995 Ford Econoline
My hp 5510 printer won't print.
op sys is operating system like windows 98 windiws XP and so on so forth
Aug 02, 2009 | Office Equipment & Supplies
Printer will not pull the paper through...
This usually happens when something is blocking the path of the paper....make sure nothing was dropped inside...usually a paper clip or a staple might get stuck somehow.....try using a compressed air can to blow off any debris.....
Apr 13, 2009 | Canon PIXMA MP160 All-In-One Printer
The yellow light blinks and it won't print
I also started having problems with my HP 870Cse when I began using refilled cartridges and had ink leakage (cartridge contacts corrupted). Check for this problem. If so, remove cartridges and gently clean the spillage. Then try using HP brand cartridges and see if this doesn't remedy the problem.
Jan 21, 2009 | HP Deskjet 870cse Printer
Hi8 Tape Will Eject but will not forward/record/rewind,
a problem with an electro mechanical mode-select switch there could be a timing problem arised by mechanical problems on contacts inside (an old video recorder problem between the seventies and nineties ) all equipments where tapes or cassettes are used.
A service manual for timing should be neccesary
Sony CCD TRV16 Hi8 Handycam Camcorder Service Manual Page 13
Apr 01, 2017 | Sony Hi8 Hi-8 Tape
Atari 2600
that could be the transformer where the AC adapter ties into the board or even as simple as the power switch is dead.
Nov 27, 2008 | Video Game Consoles & Games
How do I solve error message 6A00 on canon printer?
Turn switched it off, open the lid and manually slid the cartridge-tray to the left. Use a piece of tissue to clean the base-pad where the heads are stored. It turned out to be stuck in a kind of upward position and somehow the mechanism that moves the tray is released so nothing happens when you switch on the printer.
Touching it snapped it loose. Remove all ink residue, move the tray back to its most right position and close everything.
Please let me know.
Sep 30, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Printer Won't Switch On
It looks like you did have the "replace waste ink pads" problem. If you still have this problem and want help in solving it, please post a new comment to this effect.
Jun 06, 2008 | Epson Stylus C46 InkJet Printer
ERROR MESSAGE 6A00
dear troughton
I had this error (6A00) on a MP760 after a couple of months of not using it.
I switched it off, opened the lid and manually slid the cartridge-tray to the left.
Then I used a piece of tissue to clean the base-pad where the heads are stored. It turned out to be stuck in a kind of upward position and somehow the mechanism that moves the tray is released so nothing happens when you switch on the printer.
maybe you can succseesfull like me
post me in back
oke,thx
cropp
Mar 11, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Brother ML-100 Typewriter Logo
42 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
