Question about Zyxel Prestige P-330W Wireless Router (P330W)
I have problems with installing Linksys wrt 54 gl wireless router
  • Mark Egan May 11, 2010
    Please describe the problems your having so we can help you.
  • 20 Answers
I will need more information to help you with this. but since this is a new router, you definitely have a modem, chances are you'll have to bridge the modem first for you to be able to use your linksys router
default username is blank
default password is admin
check with your ISP if your connection type is DHCP or PPPoE
if it's PPPoE, you'll need to configure your router, you need to put in your username and password for your ISP inside your router's GUI or main interface page
Posted on Jun 22, 2009
Client Mode or 2nd Wireless Router with new Subnet Mask?
The original firmware does not have this option, but you can get a custom firmware at http://www.dd-wrt.com/
DD-WRT is not supported by linksys, so a little caution there as this could ruin your router if it is not installed properly. Fortuately they have plenty of documentation on installation and troubleshooting if needed.
Also found this on how to setup Client Mode through DD-WRT - http://www.dd-wrt.com/wiki/index.php/Client_Mode_Wireless
May 20, 2012 | Linksys WRT54G Wireless-G Broadband Router...
Router does not show wireless light. I have reset it but can't access it with the setup wizard. Any suggestions?
* NOTE: If you tried to set-up the WRT-150N Router previously, but failed, with the Router ON, press the "Reset" button on the back panel and hold it down for 10 seconds, then release. This will reset the Router to factory settings and erase all previous data.
then do this :
1. Hook up the Linksys WRT-150N Router to the Modem via a LAN cable.
2. Hook up the Linksys WRT-150N Router to your computer via a LAN cable with the LAN cable in Port #1 on the Linksys WRT-150N Router.
3. Type http://192.168.1.1 in the address bar of your web browser.
4. Log-on to the Linksys WRT-150N Router with these log-on credentials:
Username: linksys (lower-case)
Password: admin (lower-case)
5. Click on the "Clone PC MAC Address" tab.
6. Click the "Clone PC MAC Address" button.
7. Click "Save", click "Continue".
8. Click the "Wireless Security" tab.
9. Choose "WPA2 Personal - TKIP/AES" for encrypted security.
10. Enter encryption password (passphrase).
11. Click "Save", click "Continue".
12. Exit the web browser.
13. Disconnect the LAN cable from the computer and Port #1 on the Linksys WRT-150N Router.
In about 5 seconds, your wireless connection should be up and running.
Sep 15, 2010 | Linksys Wireless-N WRT150N Router
Hello, I have a Linksys Router model No. WRT 160N and have problems with the wireless signal. Doesn't appear the wireless symbol ON and I have connected already the modem cable. The modem is OK cuz I can...
* NOTE: If you tried to set-up the WRT-160N Router previously, but failed, with the Router ON, press the "Reset" button on the back panel and hold it down for 10 seconds, then release. This will reset the Router to factory settings and erase all previous data.
Then do this
1. Hook up the Linksys WRT-160N Router to the modem(cable, DSL or satelitte)
2. Hook up the Linksys WRT-160N Router to your computer via a LAN cable with the LAN cable in Port #1 on the Linksys WRT-160N Router.
4. Log-on to the Linksys WRT-160N Router with these log-on credentials:
13. Disconnect the LAN cable from the computer and Port #1 on the Linksys WRT-160N Router.
Sep 15, 2010 | Linksys WRT160N Wireless Router
Need to reset to factory default a linksys wrt 54
Push and hold the reset button in for like 1-2 minutes then release it, it should reset the settings to default
Oct 15, 2009 | Linksys WRT54GX2 Wireless-G Broadband...
Bridge or Repeter mode.
It is possible but you will need to flash the router with custom firmware.
Here is how:
http://www.dd-wrt.com/wiki/index.php/Installation
This is only possible if you have two wrt54-g routers that are of one of these types:
WRT54-G ver 1
WRT54-G ver 2
WRT54-GL
(there is a sticker on the bottom that can tell you what version it is)
This is the article that I followed and it workes great.
http://www.dd-wrt.com/wiki/index.php/Wireless_Bridge
Apr 29, 2009 | Linksys Wireless-G WRT54G Router
Repeater router responds with 'Address not found...'
You need to start from scratch.
Whenever you need answers they can be found here -
http://www.dd-wrt.com/phpBB2/viewforum.php?f=1&sid=785382853553ee7844cfab78da0607db
But best to start with the Wili - http://www.dd-wrt.com/wiki/index.php/Installation
And here is your get out of jail card -
http://www.dd-wrt.com/wiki/index.php?title=Recover_from_a_Bad_Flash
If you have to resort to the hard method of recovery, be careful.
I have only ever permanently killed one router - doing this - http://voidmain.is-a-geek.net/redhat/wrt54g_revival.html
You will first need to establish which model router you have. Then you will (assuming you want to use DD-WRT firmware) need to flash a micro or mini firmware. Then you flash again, using the standard.
There are many users worldwide using your WRT54G and GL routers with other than standard firmware, me included. I manage a network of 9 routers running DD-WRT V23SP2 standard.
Don't give up, and when it says to leave it 30 seconds (or 2 minutes) DO! Be patient...
Apr 06, 2009 | Linksys Wireless-G WRT54G Router
Linksys 300n 1.1 router installation instructions
HERE IS THE LINK TO THE MANUAL
http://downloads.linksysbycisco.com/downloads/WRT300N_ug,0.pdf
Jan 07, 2009 | Linksys WRT300N Wireless Router
Router to use as relay.
Linksys WRT54GL with DD-WRT firmware. Now, DD-WRT will void the warranty, but it has been incredible for my uses when configuring WDS. A the WRT54GS has also been said to be an excellent router, but I cannot say.
Dec 22, 2007 | D-Link AirPlus DI-524 Wireless Router
3rd party firmware broke my router!
did you check whether you have downloaded the correct firmware for your linksys???
Dec 02, 2007 | Linksys Wireless-N WRT150N Router
Zyxel Prestige P-330W Wireless Router (P330W) Logo
141 people viewed this question
Top Zyxel Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
