Question about Toshiba 42DPC85 42 in. EDTV-Ready Plasma Television
42dpc85 My tv recently started making a clicking or pecking noise. Its coming from the back of the tv and looking at the back, its near the top of the unit and slightly right of center. Any idea as to what this noise is and what can be done to make it stop? It does not appear to have affected anything else, still have picture and sound.
    New Friend:
  • 71 Answers
You have to repair this ASAP, otherwise the next step is going to be black spots here and there and then a black screen with sound. It happened to us and the TV guy said it was only an annoying noise and nothing else. When the TV started getting black spots everywhere we checked with another TV guy and he said that bcs we didn't repair the clicking sound in time, the consecuence was the black spots we are getting now. Of course Toshiba won't do anything so they lost our business too.
Posted on Oct 31, 2009
Get a new one
Posted on Oct 22, 2008
    Problem Solver:
  • 5 Answers
You have a cap on the powersupply going bad. it can be replaced but you will have to take the back of the unit apart to find out witch one it is. look for one that is swelling at the top.
Posted on Sep 17, 2008
SOURCE:
Pecking noise in or around motor & missing
get the engined serviced .check the oil level .
Mar 03, 2014 | 2002 Oldsmobile Silhouette
Pecking noise in motor
Where did you put the Sea Foam? (Fuel Tank or Oil)
What is the Code that came up?
The noise (without hearing it) is hard to answer but it could be a sticking Lifter, Low Engine Oil, Broken Internal Component, Spun Bearing, Transmission, and the list goes on and on.
If you can tell me what the code it, I can help you a little more. P0300 -P0306 are Misfire Codes. I am curious what you have
I own a 2005 altima w/ 180,000 miles on it. about a yr ago it started making a pecking noise.(the sound that makes you think it's low of oil, only the oil was fine) recently the pecking has gotten very...
Yes It could be the timing belt because as your car ages and the belt gets worn it starts to stretch. If your timing belt stretches enough your car will come out of time and that will cause a peck or knock. Another thing that you may look into if you have not had a tune up recently is spark plugs and wires. If you have worn plugs or wires it can also cause this to happen on occasion. I hope this helps you out.
Aug 26, 2011 | 2005 Nissan Altima
When I attempt to start my 89 jeep cherokee, it only makes a clicking noise, near the starter relay. Then occasionally it will try to turn over, but makes a grinding noise near the starter.
try to jump start it if it starts its the battery,if it doesnt than it time to remove the starter and go have it tested,while its out look for any worn teeth on the flywheel and starter solenoid teeth also.if starter comes back ok then look at all the cables,look for corrosion as it can hide under the wire sheilding.
Jun 26, 2010 | 1989 Jeep Cherokee
Magnavox plasma television will not turn on, makes
Relays clicking noise you hear.....change caps..you might see visible signs of CAPs being bad....swolen,,, top ready to explode etc.
May 19, 2010 | SNK Magnavox 42MF231D 42 in. Plasma TV
Toshiba 42DPC85 Won't Turn On
Hello!
I'm adding a "Troubleshooting" part of the manual to this TV.
Hope it will help!
https://manualsbrain.com/en/manuals/981801/?page=45
Nov 16, 2017 | Toshiba 42DPC85 42 in. EDTV-Ready Plasma...
My tv turns off by itself and makes a clicking noise
Most likely it has some bad capacitors in the power supply. Flat--panel sets are VERY hard on capacitors, due to the fact that the "rising heat' from the set "cooks" the caps and they fail VERY early.
Oct 12, 2009 | Samsung HP-T4234 TV
Fridgefreezer
My kenmore refrigerator has just recently started clicking CONSTANTLY. What could be the problem? It is not very old.
Apr 22, 2008 | Refrigerators
Toshiba Plasma clicking noise
Check the fan, it may be dust or a bad bearing.
Oct 10, 2007 | Toshiba 42DPC85 42 in. EDTV-Ready Plasma...
Open Questions:
See all Toshiba 42DPC85 42 in. EDTV-Ready Plasma Questions
Toshiba 42DPC85 42 in. EDTV-Ready Plasma Television Logo
375 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
