Question about Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker
Whirlpool refrigirator with top freezer
Bottom part of refrigirator is freezing.
    Genius:
  • 1,075 Answers
Run your hand around bottom door seal see if you can feel a warm spot, if you do check that area for contamanation ie;particals of food etc if not pull the seal in that area back slightly see if seal is split.if all seems ok look at the drain hole at the back of your fridge inside it often clogs up with small particals of food if this is the problem use a pipe cleaner to clean it.if its cloged water will be seen lying at the bottom of your fridge ;if any of the above do not cure your problem turn down your fridge a little this will not affect your freezer.hope this helps you.adrian
Posted on Feb 16, 2009
Why is the top shelf of whirlpool upright freezer not freezing?
Just had this issue. Freezer is packed usually & suspected airflow. Emptied bottom 2 shelves & vent strip was solid frost. Bottom 2 shelves were filled w/ solid roasts & other solid large items. Used blowdryer & currently waiting to see if it begins freezing top shelf.
Jul 03, 2014 | Whirlpool EV160NZTQ Upright Freezer 16 cu...
GE GSS25LGMA refrigirator/freezer refrigirator side is freezing
There is an electrically activated air dampener in the upper left back side of the refrigerator section which most likely has broken (in the open position), allowing cold air from the freezer to continue to enter the fresh foods section. Replace the dampener assembly.
Mar 29, 2010 | Refrigerators
Freezer (top) is cool, but refrigirator at room temperature
Your first step is to make sure the condenser coils and the fan are clean and there is nothing blocking air flow around the outside of the fridge. A good vaccuming and brushing will do it wonders.
If this does not improve the operation. Tell the landlord that it is bad and if it is part of the supplied appliances, he should replace or repair it for you.
If he is not cooporative, do some online searches for methods to convince him to do his job or who to contact to ensure he doesn't cause you harm.
Sep 20, 2009 | Whirlpool ET4WSKXK Top Freezer...
Refrigirator is not cooling. Freezer is cooling
if you have a bottom freezer, you need to defrost the unit the cool air from the freeezer is what cools the top part, but the channels are iced up
unplug the unit and let it thaw out overnight
Sep 12, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Refrigerator Not Cold
You are not moving air between the freezer and refrigerator sections. This may be due to a defective fan motor or a frozen evaporator coil.
Aug 09, 2009 | Whirlpool ET4WSKXS Top Freezer...
Water at bottom of refrigirator
Find the drain line from the freezer to the evaporation pan near the motor. Often the line is visible on the back of the fridge. That line is plugged either with food residue or the collection point in the freezer is solid ice. The self defrost feature melts the frost and drains it to the evap pan. If you remove the floor from the freezer area, you will see the collection point. When the line gets plugged with food, no water drains and then freezes to block the line even worse. So, if there is ice at the collection point, remove it somehow, maybe a hair dryer, and then clear the line by blowing compressed air from the bottom of the drain hose through to the collection point.
Jun 19, 2009 | Maytag MSD2756G Side by Side Refrigerator
Whirpool gold
Sounds like the unit may be stuck in to defrost . The defrost clock is usually inside of the refrigerator compartment up by the thermostat controls. you can take a screw driver and advance the controller to make the compressor come back on . usually when they start to stick they neeed replacing. good luck and please don't forget to rate the answer please. Thanks for using FixYa.
Jan 01, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
FRIDGE COMPARTMENT FREEZING
try this,make sure you dont have anything blocking your blower in the freezer.if that is okay if you have seperate controls for the freezer and the fridge,try setting the frige setting lower and the freezer higher,this makes the blower work more in the freezer.hope it helps.
Dec 06, 2008 | Refrigerators
Whirlpool Refrigirator
water is probably caused by ice blocking the drain for the auto defrost. take off the back panel and you may see ice accumulating at the bottom of the evaporator. switch off, clear the excess ice with a hair-dryer used carefully and make sure water runs down the drain freely. ice in the drain may take some clearing - boiling water and patience are needed
Apr 14, 2007 | Whirlpool GS6NBEXRQ Side by Side...
Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker Logo
116 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
