Question about American Standard Plumbing
Peerless single control bath faucet drips
How do I take it apart (remove inner plastis retainer) to stop drip
  • Thomas F. Schneider May 11, 2010
    Remove the plastic retainer Most you remove with a screw driver prying toward the center, and then pull out the whole Cartridge  ,
    take it to the parts place and match it up for a new one. Is it not like that?
  • 34 Answers
If it is a ball cartridge then it should just pop out with a flat head. This is of course after you unscrew the metal cover off of it.
Posted on Feb 04, 2009
I have a single handle shower faucet, turn all the way and you get only hot water.... It has been dripping over the last few weeks when off, hot water. now it's a steady flow. How do I adjust...
hi there:) your problem is caused by the cartridge inside the valve body. could be one of 3 things...1)the cartridge is damaged 2)hard water build up 3)foreign matter. it is not to difficult to replace it yourself: first turn off the water then find the set screw, which holds the handle in place, usually located at the base of the handle and remove it. (look closely/carefully cause it's hiding) then remove the escutcheon ring and the trim sleeve to expose the "bonnet" (lock ring) and remove it. (ritey titey lefty loosey) now you can remove the cartridge and inspect it for debris/damage. if you need a new one just take it w/you to any plumbing supply including home depot and/or lowes and they will help you find it. here is the installation/owners manual from peerless: hope this helps but if you need anything else just ask:)
Jul 30, 2011 | Peerless Industries Peerless& Single...
Faucet drips andi don't know how to adjust it so the drip stops.
you will need to replace the washer, you will have to disconnect the faucet underneath and replace the washer,then tighten accordingly
Jul 18, 2011 | Kohler K-15172-FG-7 Coralais...
I have a very old single valve peerless tub/shower faucet that leaks out the spout when turned off. I removed the knob and there seems to be a plastic part that surrounds the stem and may also serve as a...
im sorry i dont know how to explain step by step what you have to do but i know what you are talking about and its called a diverter. they get stripped out and thats why the spout leaks. they are not difficult to replace depending on the model but some of them have to be sweat apart with a b-tank.
Feb 05, 2011 | Delta Faucet Peerless& Shower Faucet...
Single handle shower/bath faucet is dripping. Want
I can fix this.
What is the last thing you did before this problem started?
Jan 13, 2011 | Delta Faucet Delta 172-SSWF Waterfall...
Shower drips - seems to be increasing
Need to replace your internal seals inside the shower valves.
Go to Home Depot, Lowes,etc. and make sure you take your model number and maker of your shower and they can get you the parts to repair the valves to stop your leak.
If you do not repair it soon, the water leaking by will cut your metal seat and it will never stop dripping, you will have to replace the valve and it is a MAJOR job.
This is a free answer, Please rate me
Oct 16, 2010 | Peerless Industries Peerless& Single...
Leaky(slow Drip) from 1700 series bath faucet. How to stop?
you need to shut off the main water supply
take it apart an put new seals in it where bought it should have the rebuild parts
Aug 18, 2010 | Delta Faucet Home
Peerless faucet P99196 dripping; tried everything. Only made it drip more. How to fix?
If you have replaced boots and springs and or cartridges. Did you replace with after market parts or OEM. If after market parts were used use OEM. Hope this helps.
Apr 11, 2010 | Delta Faucet DELTA/PEERLESS FAUCET CO....
I have a two-handle Delta faucet that drips.  With both handles turned completely to off, the faucet drips at a about 1 drip every 15 seconds
sounds like you need to replace the valve seats. if you shut the water off and remove the handles you will see the valves. you have to remove them and under that you should see these little black things. they come out but have springs under them so be careful. the black things are the valve seats. i would start by replacing them
Dec 15, 2009 | Delta Faucet DELTA/PEERLESS FAUCET CO....
Replace the seal on the 470 DST single handle pull out faucet
Turn the water off at the faucet, remove the handle and the retaining nut that is apart of the trim. You will see where you can use a wrench to remove it. The ball assembly will come right out and you can replace the washers right below it. Put it back together and if needed, tighten the tension ring that is on the retaining nut (usually grey or white in color) so it won't leak water around the ball stem. Good luck.
Apr 02, 2009 | Delta Faucet Delta 470-BL-DST Signature...
Dripping faucet
Moen is a cartridge style unit. They make two different cartridges that you can buy at Home Depot. Turn the water off under the sink and then remove the handle. You will see the the cartridge. It has a U shaped retaining clip that pulls out. Once you remove it, then take a pair of pliers and pull the cartridge out. Take it up to HD and match the one you have. The new one will slide right back in and you will reverse the process.
Mar 15, 2009 | Moen 7065 Vestige Single-Handle Kitchen...
Plumbing Logo
243 people viewed this question
Top American Standard Plumbing Experts
john h
Steve Wood Plumbing...
Level 1 Expert
Level 1 Expert
Are you an American Standard Plumbing Expert? Answer questions, earn points and help others
