Question about Samsung CLP 300 Laser Printer
Samsung clp-500 paper feed roller replacement - how to...
There are 2 tires on one shaft and a spring.
Releasing the white clip on right hand side (like HP) does nothing useful. I expect I'm going to have to take off the LHS side cover and go from there- anyone got any ideas or visuals for help-
thanks
Don
  • sritter860 Feb 26, 2009
    The shaft still doe not roll enough after releasing the white platic clipped part. Any other way to get it to roll freely?
You're on the right track! If you remove the paper tray and put the printer in a position so the front of it is facing up, you can then access the roller shaft with ease. If you now look on the right hand side of the roller shaft you will see a white plastic end which is secured onto the shaft with a little clip, lift this up and slide the plastic part inwards. This should now make the shaft easy to turn so you can release the two white clips on the roller and remove the rubber band (which there is only one of, but looks like two on a first glance). Once removed, I just turned it inside out so you can get another few months or more out of it before you have to buy a brand new one for a couple of ££. Replacement is just the reverse of removal. Hope this help!
Posted on Feb 17, 2009
What I would add to Unicronicus's solution is that after you have removed the clip securing the roller shaft you need to roll the rubber roller in the direction of anti clockwise looking from left to right, i.e. the nearest part of the roller upwards and back. A half turn will reveal the clips that hoold the roller band in place. once these are unclipped you can roll the roller back and remove the rubber on its spool. replacement is much simpler in that you just clip it back in position. Whole thing takes 2 minutes
Posted on Nov 24, 2009
Paper jams from top and side feed on clp 500. Any solution suggestions?
dirty/jammed rollers - paper obstruction - loose parts - improperly inserted cartridges
Oct 20, 2013 | Samsung CLP-500 Laser Printer
The paper sometimes makes a skipping sound when it feeds. how can I clean the feed rollers ?
1) Open front cover and remove two screws above the ink cartridges
2) Open the back cover, too
3) Lift off the top cover
4) Remove 4 screws near the green levers inside the back cover
5) On top, remove 2 screws near the small white clips bearing the top rolerr;
Aug 29, 2011 | Samsung CLP 315 Laser Printer
Riso GR3770 will not pull the paper through once it passes the initial feed assembly. The paper ''picks up'' just fine, but after the lead edge enters the machine, it kicks off impression and gives a...
what happens sometimes is the rear side of the registration (shiny silver color) roller becomes worn down so bad that the spring cannot grab properly. the registration roller, in this case, would have to be replaced.
the way to check is by getting to the back of the machine, and if this is the cause, the spring should be a little wobbly on the shaft. with a new roller, the spring fits snug, and grabs properly for it to feed.
Mar 31, 2009 | Riso Office Equipment & Supplies
Clp 300 won't feed paper
Remove the paper tray. Gently pull the sides apart at the front end of the tray, to release the spring-loaded ramp which pushes the leading edge of the paper upwards.
Underneath this ramp are two compression springs approximately 1/2" in diameter and 2" long (above, left). The problem with the paper feed appears to be that these springs very quickly get fatigued and fail to exert enough pressure to push the tray upwards. Replace the long, thin springs with a more compact pair, with better compression, like one of the pairs on the right. I am still experimenting to find the ideal size, but this has definitely helped. Our local Ace Hardware store has a fairly good selection of compression springs. Home Depot had nothing remotely suitable.
You may find that an extra pair of hands and a pair of long-nosed pliers make the job easier when you are trying to keep the springs in position as you replace the ramp in the tray.
Jan 14, 2009 | Samsung CLP 300 Laser Printer
CLP 300 crumpling lower right hand side of paper
There is a foreign object in the paper feed path. It could be anything from a paper clip or staple through to an insect (or worse). It will definitely be on the side where the crumpling occurs. Try feeding a strip of card or thin flexible plastic backwards through the feed mechanism. A laminated sheet of paper can also be effective for this.
Nov 18, 2017 | Samsung CLP 300 Laser Printer
The paper won't feed into a lexmark X3480
There are a pair of white rollers on a spring loaded assembly that feeds the paper into the machine. If these rollers are glazed or very worn, they will not feed the paper.
Also, the mechanism is known for its temperamental nature. I also recommend removing the paper tray and manually lifting the paper feed assembly gently by hand, insuring that it returns downward in a smooth and unobstructed manner. There are tiny clips that must be released on the white feed rollers, if you decide to remove them. However, I suggest giving them a good cleaning with a soft cloth moistened with dish cleaning detergent and water. Use very little detergent -- just a drop or so, and water. Wipe the feed rollers until the entire "tread" area is clean on both rollers.
ZBob
Jul 28, 2008 | Office Equipment & Supplies
Paper jam
I too have this infuriating problem and the reason has already been pinpointed very well it is indeed the front rubber pinch cam not grabbing the paper well. I have approached this problem from another angle... under the front sprung loaded flap on the paper tray
there are two compression springsapprx 1/2" in dia. Gently prise apart the 2 flap pivot (on the extended arms) to gain access to the springs ,pull out the springs and either replace them with slightly stronger ones or pull the existing springs apart to retension them and pop them back (long-nosed pliers or tweezers) this will restore the spring tension lost during use with the rubber pinch cam.
Jabba0737
Mar 10, 2008 | Samsung CLP 300 Laser Printer
Samsung 300CLP "paper jam"
I have just posted my "fix" for the paper jam elsewhere on this forum. Check it out and I hope it helps you too?
Nov 24, 2007 | Samsung CLP 300 Laser Printer
Dell 1700 laser printer wont load from tray only manual
This is a common misconception with this model printer. People say that the roller does not drop down to pick up the paper. With this model printer, the pickup rollers ONLY drop when the paper tray is inserted. If you look on the top left edge of the paper tray towards the front of the printer you will see 1 1/2" to 2" section where the plastic edge is raised about 1/2 an inch. This raised part in the plastic actually serves as the mechanism for dropping the pickup rollers on to the paper.
So... The solution DOES HAPPEN TO BE cleaning or replacing the pickup rolers/tires. Rubber rejuvinator is the best for cleaning the rollers, but buying a whole can that you may only use once or twice may be a bit overkill. You can try cleaning them with soapy water if you do not have any rubber rejuvinator. DO NOT use alcohol, as this will dry out the rollers and shorten their lifespan even more.
Oct 02, 2007 | Dell 1700 Laser Printer
Samsung CLP 300 Laser Printer Logo
635 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
