Question about EliteGroup ECS A780GM-A Motherboard - AMD 780G, Socket AM2+, ATX, Audio, Video, HDMI, PCI Express 2.0, Gigabit
Instructions on atx case wiring to motherboard
I am building a desktop pc with an atx midtower case and I would like to know how to connect the case wiring to the motherboard.I am confused on the positive and negative pin wire connections.Can you help.
  • 565 Answers
Assuming that the computer is laying down on it's right side, and you are viewing the F panel (the front panel header) from the right side of the motherboard (the bottom of the computer), pin 1 is on the bottom left of the F panel, pin 2 is on the top left, pin 9 is on the lower right, and pin 10 is on the top right (no actual pin)...
1 HD_LED_P Hard disk LED (+) 2 FP PWR/SLP *MSG LED (+)
3 HD_LED_N Hard disk LED (-)
5 RST_SW_N Reset Switch (-)
7 RST_SW_P Reset Switch (+)
9 RSVD Reserved
6 PWR_SW_P Power Switch (+)
8 PWR_SW_N Power Switch (-)
10 Key No pin
Usually the wires and the pins are color coded, (the colored ones being positive.) Sometimes the connections are written in very small abbreviations on the motherboard.
Posted on Jan 28, 2009
  • Bob
    Bob Feb 21, 2009
    Thanks for the positive feedback and taking the time to vote.
  • 32 Answers
There should be markings on the motherboard and it should also show you in the manual the way it goes.
Here is a link that also shows the default configuration of the power, reset, hdd led etc.:
Normally on the cords from the case (if they have labelling on the plastic end) the labelling will always face out (so you can read it when its plugged in)
I hope this helps
Have a great day!
How do i restore a diablotek elite atx mid tower to factory settings
Cases don't have "factory settings." This sounds like a problem with the motherboard configuration. Make sure to re-check all your pin connectors leading to USB, Audio, and HD. Also, you may need to remove the MB to check if there's any damage, and to be sure that you don't have a short somewhere.
Jan 14, 2013 | Diablotek Elite 450W PSU ATX Mid Tower...
Need mb schematic for h57m01
Here is a link to the Gateway site, they should have the manual you are after, if you cant seek it on their site email them to get a copy.
Sep 24, 2012 | Gateway Computers & Internet
Researching power supply for Cooler Master CAC-T05-UW Must be ATX MidTower, ATX compatible form factor,2 external 5.25" drive bays,2 external 3.5" drive bays,2 internal 5.25" drive bays,7...
The power supply will fit... the question is what do my motherboard, video card, ans drives need in wattage. most systems will do well with a 650 watt. I like antec as a brand.
Aug 29, 2011 | Cooler Master CAC-T05-UW ATX Mid-Tower...
Installed a GA H55M USB3 motherboard in a Raidmax Tornado case. When I go to turn it on their is power for about for about a 1sec and the fans turn a couple of times and a couple of seconds later their is...
I once had something similar happen to me. Triple check to see that all connections are secure to the motherboard - a loose 20 pin ATX cable was the culprit in my case.
Hope that helps. Good luck!
Dec 09, 2010 | RaidMax Tornado ATX238WRP Black SECC Steel...
I need a motherboard that will fit in a Raidmax ATX1072BP Mid Tower ATX Computer Case!
Most desktop computer cases have a range of standard mount holes, standard offs.
I suggest you select a motherboard that suits your requirements.
To be sure that the motherboard will fit your case, take the motherboard mount base with you to the computer shop and place the motherboard of your choice on the base to see if the mounting holes line up.
You may need to upgrade the switch mode power supply to a higher power unit if the total power requirements is near the maximum the existing unit can deliver.
Dec 03, 2010 | RaidMax ATX1072BP MID TOWER ATX COMPUTER...
Need to know which style of m b I have is it an atx
The difference between ATX and MicroATX is the size. An ATX board will usually have 6-7 slots to add cards like video, network or sound cards. An ATX board will also usually not have a video port on the board. A MicroATX board will usually have only 3-4 slots to add cards into it, at least one of which being dedicated to AGP or PCI Express Video cards.
To answer your question: That computer uses a MicroATX board. A Micro ATX board will most likely work in any PC Case whereas an ATX board requires an ATX size case (Mid or Full size Tower).
Jun 06, 2010 | eMachines T3508 PC Desktop
Pc tower motherboard upgrade
you can put in any new micro-atx motherboard no problem. I can be 100% sure if the case is Atx full size- best way to check is to see how many pci expansion slots are available at the back of the case. Any Atx case can hold micro-atx mobo's but a micro atx case wont hold atx mobo.
May 27, 2009 | Compaq Presario 5000 PC Desktop
Problems on PCCHIPS M701G Motherboard
connect your three pin socket in your power plug
Jan 12, 2009 | PC Chips M701G V1.1 Motherboard
HP a220n (midtower PC) replacement
Duane , a good AMD 64 x2 Duel core processor motherboard would be the Asus M2A-VM AMD Socket AM2 MicroATX Motherboard / Audio / Video / DVI / PCI Express / Gigabit LAN / USB 2.0 / Serial ATA / RAID this motherboard will fit in your midtower. It comes with firewire and usb ports. hope this helps.
Sep 17, 2007 | HP Pavilion a1220n (A1220NED904AA) PC...
EliteGroup ECS A780GM-A Motherboard - AMD 780G, Socket AM2+, ATX, Audio, Video, HDMI, PCI Express 2.0, Gigabit Logo
1,478 people viewed this question
Top EliteGroup Computers & Internet Experts
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
