Question about Maytag Neptune MDE7500AY Electric Dryer
Gaining access to dryer
I have an electric Neptune Drying Center. Modle # MCE8000AYW. This is the one with an upper drying cabinet and a lower tumble dryer. I need to know how to gain access to the inside cabinet of the lower tumble dryer.
  • matpan Feb 24, 2009
    Hi on the job. I have the screws out on my neptune and am tugging on the front panel but the whole dryer is moving and the front panel isn't coming out. Could you go into this part in more detail.
  • Anonymous Mar 17, 2014
    changed to 3 wire from 4 wire now dryer wont start and control panel appears dead
  • 640 Answers
Open door you see 2 screws holding hinge a a piece,,remove them now remove the 2 screws opposite them ..just let door stay for now...pull the front panel to you its just on 2 clips...now at each corner of the bottom of the top theres a upside down l shaped clip remove 5/16 inche nut driver...ok left the top...swing it up and back ,,so it will lean back,...remove 4 bulk head screw and the door switch connection..and your there..onthejob
Posted on Jan 29, 2009
  • rocksnake Nov 22, 2010
    thankyou, you were right on.
MAYTAG NEPTUNE DC MOD# MCE8000AYW
Your exhaust is gettting restricted and not able to remove the moisture from the clothes. Also check lint screen with very slow flow of water. If water rolls off wash filter good .. If water can't pass through smoothly then air is also having problem being pulled through as well.
Nov 15, 2016 | Maytag Dryers
Why does my Neptune moder number mce8000ayw dryer not tumble?
If the motor runs, but the drum doesn't rotate, check the belt, part # 341241. It's probably broken and off of the drum.
May 14, 2014 | Maytag Neptune MDE5500AY Electric Dryer
I need to take off the lower front of the dryer unit to gain access to the igniter
Just remove the control panel. The screws are accessible from the drying cabinet. There will be 5 screws holding the bottom panel in place from the top. It tilts out then up off the clips.
Sep 08, 2010 | Maytag Neptune MCG8000AW Gas Dryer
Drying Cabinet above emits a smoky scent but there is no smoke
These cabinets seem like such a good concept.
While I have never worked on one, I would first take the back off (having disconnected the power) and look for a build-up of lint on the heat exchanger/heating coil assembly. Check that ducts are free of built-up lint and fans turn freely.
Lightly lubricate the motor shafts with a drop of machine oil. reassemble and run a test cycle monitoring carefully (keep a fire extinguisher at hand and a clear path to exit the building, have ready access to a telephone, know how to turn off the main power in your home). You will likely need none of these precautions but it's best to be safe and prepared.
Most dryer failures are related to lint build-up leading to excess heat. Clear vent ducts frequently, clean out the inside every few years, lubricate lightly at the same time.
Jul 07, 2009 | Maytag Neptune MCE8000AY Electric Dryer
Maytag mce8000ayw start button won't work
your starter button needs checked at least but most likely replacded
Feb 21, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dryer makes noise like a bird chirpping.
You'll need to access inside the cabinet and oil the tires and belt pulley. Hope this helps!
Jan 28, 2009 | Maytag Neptune MDE7500AY Electric Dryer
Maytag Neptune Drying Center MCE8000AYW
Email me a response to robert_fawbush@yahoo.com and I will be more than happy to provide you with parts breakdown illustrations and possible part numbers and locations to replace. The service amount verses the do-it yourself amount will be well worth the savings. Typical labor cost on appliances are 75.00 per hour and a mark up on the parts. If you feel you can do it yourself after getting the photos e-mailed to you, it will save you approx 200.00 if not a lil less or a lil more.
Please rate this solution "fix-ya" if it seems to satisfy your question.
Apr 14, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune DC Model# MCE8000AYW leaks water from the right side of drying center unit while using the "Wrinkle Release Hanging Dry Only" feature. The leak happens during the steam portion of the cycle....
Stop using the water bottle because the water is overflowing the heater steamer pan and will short the heating element and the part is no longer avaliable and the top will stop drying.
Mar 27, 2008 | Maytag Neptune MCE8000AY Electric Dryer
Problem with upper cabinent of Maytag Drying Center.
Mine did same thing within warranty. There is a motherboard problem in them that is cause by power surge during an eletrical storm. First try unplugging for 10 minutes and see if it resets. If that doesn't work, you need to have the motherboard replaced that runs the unit.
Repair man took the front off my unit and replaced entire motherboard. He stated that it was a known issue with that motherboard. I have had no problems since my motherboard was replaced 18 months ago.
Dec 02, 2007 | Maytag Neptune MCE8000AY Electric Dryer
Squeeking in lower dryer
remove the rear panel. unplug dryer before doing anything
Oct 24, 2007 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune MDE7500AY Electric Dryer Logo
401 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
