Question about EPoX EP-8RDA3I Motherboard
C1 Fault I have just purchased a new pc tower with the above motherboard. It came with no os, I put my XP cd rom in the cd drive but nothing happened. Then the unit began 'beeping' On the lcd panel on the MB it says C1 I am rubbish with pc can any one help? Paul
  • 2,961 Answers
C1 refers to a memory fault, so check that the memory timings according to the manual are correct or that the memory is not faulty.
Posted on Jul 26, 2007
HP d220m will not boot from hard drive, have tried several but nothing happens.
Hello, can it be your cd or cd rom that is the problem? I sugggest that you try with a other cd rom and make a copy of your cd and try to install from the new one. Plz post your exact error here.
Apr 05, 2012 | HP Compaq d220M (829160054797) PC Desktop
Getting three beeps with my asus m4a785t-m motherboard initializi
Okay, not much else is mentioned about the system so I would assume you have one CD/DVD drive and now two HDDs and your new HDD is still set to factory default of "Cable Select" or CD, if not and the new hard drive is a replacement for a damaged OS (Operating System) drive, then you need to insert the Windows OS Installation disk prior to booting and set the system to check your CD-ROM before checking Hard disks, for the OS.
First off if IDE, you have a ribbon that resembles this [====[========[ the furthest to the right would be what plugs into you motherboard, being the one with the furthest distance between itself and the next plug/connector.The one on the other end is for the Master drive and teh middle one is for Slave.
If only one HDD, then the jumper for the new drive needs to be set to Master and the CD/DVD-ROM needs to be set to Slave.
  • If two HDDs & one CD/DVD Rom, On the primary IDE Controller, set the OS HDD to Master, the CD/DVD-Rom to Slave & put the second HDD on the secondary IDE Controller as Master.
  • If two HDDs & 2 CD/DVD-Roms they must be set up on totally different IDE controllers to cancel out the chance of cross-communication. This happens on some systems because of having two CD/DVD Roms and/or two IDEs. So, we set the OS HDD to Master on the Primary IDE Controller & we set the CD/DVD-Rom to Master on the second IDE controller and the
I would normally say that three beeps from the motherboard itself would be either graphics card or memory problems, normally solved by simply pulling either or both and reseating them. Wear Nitrile gloves (the blue ones) to keep oils and static charge from damaging the components, ground yourself &/or touch the case before and while pulling the components. Check this site for "Post Codes" if the beeps are coming from the MoBo... if you have Award BIOS (should show what BIOS brand when booting up the system)
Award BIOS Post Codes
If three beeps from the system itself, then that would say it can't find the OS... and you might possibly also find an error on the monitor, stating something similar to "no power to monitor".
If you don't have an illustration on your drive telling you what pins are for what when it comes to the jumper, then search google for the drive brand and the word "jumper" or words "jumper configuration" or "jumper placement"
example: Maxtor Jumper configuration
If the system is SATA only (I believe it to have at least one IDE controller unless the board's controllers are all blue & black, to which I see a controller, but can't tell if it is FDE or IDE), then you'll most likely have to enable the SATA controllers in BIOS and set the boot preference/sequence/order as mentioned above, to check the correct disk for the OS, after removable devices & CD-ROM. Should be that order anyway, with floppy seek disabled to save wear on the head.
Hope that was not too much and that it helps!
Apr 15, 2010 | Frigidaire FEQ1442ES Electric Dryer
Windows xp will not boot
If you just installed windows then take the cd out and let the computer reboot on its own. Windows will ask you to replace the OS disk later.
So just restart the computer with nothing in the CD drive.
Also make sure in BIOS that the Hard drive is the first boot device. Don't need the CD drive as first anymore.
See if that helps.
Jul 09, 2009 | Intel Computers & Internet
Cannot get CD-ROM to work,to come up on screen.
Ok with that you need to insert the disc and then go into the my computer section of your computer and then in the CD rom drive you should see the disc and you will click on it to start the process. However if that does not work then your CD rom drive is defective and you need to purchase a new one.
Jun 17, 2009 | Computers & Internet
Attempt to turn on computer, no OS install windows
Marginal hard drive, hard drive cable, or hard drive controller (on motherboard).
Other suspect parts may be the CD ROM drive you're trying to run the OS install from. It may also be flaky, causing you to think you're loading the OS, but not really and not reporting errors until you discover the OS is not completely installed.
First thing to do is pull the HDD and cable out, reseat firmly and try again. May as well do the same for the CD/DVD drive.
Mar 05, 2009 | Toshiba Satellite M45-S165 Notebook
After a hard drive falure I need to install windows xp
At this moment I have taken the HDD out of the case, bought an adapter for its 1.8" interfce and proceeded over the USB. I was, however, installing Linux, with practically no experience with Windows.
Oct 21, 2008 | Toshiba Portege R100 Tablet PC
Windows XP OS
1st use the old CD and format the partition and then try the new OS.
Jan 06, 2008 | Compaq Diskette Drive / Cd-Rom Cable...
hard drives dont read cd's
does the door close?
if not close it.
1)left clik my computer
2)double clik the cd rom drive, making sure theres a disk in it.
3)right clik on my computer
device manager
look for a yellow exclamation point or red X where the cd-rom is.
high light the cd-rom
right clik
windows will detect and re-install the cd-rom drive.
try a cd
if that doesnt work update windows
also buy a cd-rom cleaner at your local electronics store
clean the drive w/th cleaner
try a cd
if updating your driver for the cd rom drive and all ive suggested then its time for a new cdrom drive
Dec 09, 2007 | Dell OptiPlex GX260 PC Desktop
CD ROM Won't work
First you want to make sure the CD you are using is good. Try a different CD-ROM, a known good one. If a different CD-ROM is readable then the problem is with your CD media and not the CD-ROM Drive. If another known good CD does not work then the problem is with the drive.
To fix this you must purchase a new CD-ROM drive and install it. has great deals. If you only want to read CDs and are not interested in burning then you can get a name brand CD-ROM drive for around $15.00, but if you need to burn as well the CD+-RW will run you about $30.00.
If you are using Windows XP then it is pretty simple to install the new CD-ROM drive.
Nov 20, 2007 | HP Pavilion a1330n (EL466AA) PC Desktop
Please check If your CD drive is detected on BIOS, if yes then Put a Windows XP bootale CD (checkout for the Service Pack) and choose boot from CD in the BIOS and go for "repair option" after the Agreement "I Agree-press F8" session. complete the installation then try installing the printer.
Oct 09, 2007 | Computers & Internet
EPoX EP-8RDA3I Motherboard Logo
730 people viewed this question
Top EPoX Computers & Internet Experts
Steven Wander
Steven Wander
Are you an EPoX Computer and Internet Expert? Answer questions, earn points and help others
