Question about HP Photosmart 2710 All-In-One InkJet Printer
Power problem on HP2710
AC power reading 31volts. No power available on unit.Is there a fuse inside the 2710 ? Thanks for your help,Bob
  • 1 more comment
  • rjwambolt Feb 07, 2009
    Turn off printer and went to turn it back on, will not work. Replaced ac/dc adapter and did not help
  • raydelarosa Mar 30, 2009
    HP Photosmart 2710 printer . . No Power. . checked power pack to printer measures 31 volts DC (ok). . . need schematic to check fuse. . .
  • Anonymous Mar 31, 2009
    No Power. . .checked power pack reads 31v - (ok). . . checked fuse (ok). . . need schematic to check further.
I just gave the printer to the repair shop that wanted to charge me $30 to diagnose the disease.
Posted on Jan 29, 2009
Crown XLS 602 power amp: Where inside is the fuse so I can replace it?
Hi Tom,
The fuse you may be referring from the power supply is not
used(none) instead a CB1 or circuit breaker is installed.
These breaker is in series with the power transformer ( trace it).
Disconnect the AC outputs of the power transformer when trying to
reset.( of course with the unit unplugged ).
Measure the output AC voltages, if it is OK
Be happy partially!
Next would be.....
Check for possible shorts on the Positive and Negative Supply
rails to ground or speaker out, for what might have caused the
breaker to tripped.
And these wont be easy troubleshooting , Good luck!!
thanks for choosing Fixya for assistance.
Dec 01, 2012 | Crown XLS 602 2-Channel Amplifier
Dometic refrigerator model RM 2193 for RV works only in the DC and LP Gas mode. two days ago the AC mode was still working and stopped yesterday (outside temperature was about 40 degrees...
Hi and welcome to FixYa, I am Kelly
Operators manual:
Parts manual:
If you look at the last page of the parts list (page 10) it is showing a thermostat across the Black and white wires.
There is not a fuse that I can see. The fuse has to be external to the unit. You should be able to read continuity (resistance) of the AC heating element at the power cord with the AC switch ON.
AC Power source must be removed to perform resistance checks.
No continuity there are 2 possibile failures (Other than wiring)
1. AC heating element
2. Thermostat.
Thanks for choosing FixYa,
Jul 22, 2011 | Dometic Refrigerators
Can't make copies on hp 2710
Bar is going bad cause there is a problem with the track that its on or a problem with the board making it think it went the whole way. Its more expensive to have it fixed at a shop then to just buy a new one.
Apr 15, 2010 | HP Photosmart 2710 All-In-One InkJet...
I need a replacement power supply for hp2710 printer
hello, this should not be too hard to find really. you may even be able to buy at BESTBUY or Office Depot.
here is a direct link to a store that should have it.
HP2710 power cord
EBAY is another great option
hp printer cord
hope this helps good luck!
Mar 27, 2010 | HP Photosmart 2710 All-In-One InkJet...
Help connecting HP 2710 wireless to my PowerBook G4
No, there is no fee. I will help you figure it out. However looking thru the HP manuals is the HP 2710 your printer model number or your notebook? I found manuals on notebook.
Don't forget to rate this solution before you log out.
Jan 26, 2009 | HP Photosmart 2710 All-In-One InkJet...
Dead Sony Laptop
If power supply is supplying correct voltage, then you do not need power supply PCB.
Try starting the laptop with AC adapter and no battery, if battery is shorting out you may get same problem.
Test the soldering joint on the AC socket and laptop motherboard, if there is a bad soldering on laprop ac adapter socket, you get same symptoms.
If it is none of the above, and the adapter is fine, then it is usually a faulty motherboard.
Nov 16, 2008 | Sony VAIO PCG-V505CP Notebook
My hp2710 all in one printer shows an error message 0x886a6546 and all the function lihgts are flashing.
I have problem with hp photosmart 2710. j see on LCD some error code Ox886a6546
Jun 25, 2008 | Office Equipment & Supplies
My RV unit got a power surge and the microwave looks dead.
Yes they have fuses, I am positive it's your fuse, take all 5 screw's off and you'll see it at the back on the right hand side were the ac cord goes in.
Jan 19, 2008 | GE JVM1440 Microwave Oven
HP Photosmart 2710 All-In-One InkJet Printer Logo
129 people viewed this question
Ben Johnson
