Question about HP LaserJet 2605DTN Color Printer
HP Color Laserjet: ghost images, both black and color print jobs
Seems like images is permanently stamped on the roller on each print jobs creating an image (only a small part ) of the original image. ran the self cleaning mode and each time it prints perfectly but problem comes back soon after that.
  • Anonymous Feb 14, 2009
    ghosting
    Sergeant:
  • HP Expert
  • 285 Answers
Did you try buying a new drum? You should if you have over 25,000 prints on it. You should also try replacing the toner. Please tell me if this helped. Thanks!
Posted on Jan 28, 2009
  • 55 Answers
Hi
sounds like either you fuser rollers need to be replaced or you need a new drum and cleaning blade, those 2 items will cause ghosting,
good luck
HP 2600n Laserjet Ghosting. Prints multiple, faint repeats down the page. Changed all toner cartridges, still happening
Perform fuser cleaning procedure. If not helpful, replace the hot fuser roller. When worn out it collects toner and may lead to repetitive image.
Mar 09, 2017 | HP Color LaserJet 2600n Printer
Hp 5550 patchy print
Most of the cases fuser assembly or supplies are causes of ghost image. If image is not properly transferring on media causes transfer roller or ETB.
Do this small exercise: Give print command, wait till paper grabs, once paper entered in cartridge area, power it off, open top & front cover, remove paper and see the print quality.Observed any ghost image what you observed? No ghost image? then problem with fuser assembly..
1.Remove fuser assembly, check any toner particles deposited on surface of fuser transfer roller or heater roller.. if found clean carefully with good cotton cloth while fuser having certain temperature,pl avoid metal & sharp objects to clean..
2. Clean paper path roller(You can observe the rollers to push the paper to reach the destination)
I hope this exercise will resolves the issue..
Jul 26, 2012 | HP Color LaserJet 5550hdn Printer
HP 3550 printer: copies are coming out with faint images of previous printing jobs
Ghosting is caused by a failing transfer belt assembly. The transfer belt is how the printer moves the image from the colored toner cartridges to the paper. The surface has a special organic that allows the toner to be picked up and is transferred to the paper but when it gets worn down some of the toner stays on the transfer belt which causes the ghosting of the previous image. The transfer belt assembly is user replaceable and looks just like a big toner cartridge. You can get them from Office Depot or Amazon.com as well as almost any place you can get the toner for the unit. Here is a link to Amazon.com
http://www.amazon.com/HP-Color-Laserjet-3500-3700TRANSFER/dp/B0001GKY7C/ref=sr_1_1?ie=UTF8&qid=1315341092&sr=8-1
I hope this helps, if so please rate my solution.
BuddyMc
Sep 06, 2011 | HP Color LaserJet 3500 Printer
MY HP LaserJet 2840 has a brand new Toner cartridge. Now it won't print at all and we are getting a "OPC at end of life" prompt. What does this mean?
Imaging drum reach 20,000 (black only) or 5,000 (color), replace the image drum.
Supplies life
The life of the imaging drum depends on the number of black-only or color pages that print jobs
require. Imaging-drum life is also affected each time the device calibrates because calibrating causes the imaging drum to rotate. Imaging-drum life is measured in terms of number of rotations rather than number of pages printed.
The type and length of print jobs also affects drum life. A series of short print jobs uses more drum
life than an equivalent number of pages printed in a single large job. To extend drum life, print
multiple copies of a print job at one time rather than sending the same job to the device multiple times.
The life of a print cartridge depends on the amount of toner that print jobs require. When printing text at 5% coverage, black print cartridges last an average of 5,000 pages and cyan, magenta, and
yellow print cartridges last an average of 2,000 pages. High-capacity cyan, magenta, and yellow print cartridges last an average of 4,000 pages. (A typical business letter has 5% coverage.)
Aug 18, 2011 | HP LaserJet 2840 Printer
The black is ghosting and text is fading out completly on right hand side
Hi
For ghost printing, i suggest you clean the fuser roller inside the cartridge compartment by a cotton swab with water and remove all the toner dirt on the roller. For faded print outs, the problem is the toner is near to end, Just replace new toner cartridge. Try also to shake the cartridge to distribute evenly the toner power.
Please let me know if you need more help
Mar 06, 2011 | HP Color LaserJet 2600n Printer
Ghost image only on black hp color 5550
change out the Black color toner ctg.. smiles
Mar 31, 2010 | HP Color LaserJet 5550hdn Printer
HP 2600n - Maintenance of the transer roller sheet
You can clean it using piece of paper (not printed). time for replacement - your image is very ghostly and you cant get better image after cleaning lasser/scanner assy :)
Oct 22, 2009 | HP Color LaserJet 2600n Printer
HP 2600 ghosting
It is a massive pain but a solution that worked for me is to run a 'clean' after every card stock sheet. I know it's wicked awful but it actually worked and I had to run 100 times (one for each good color card stock)
First put plain paper in tray 2
Next
Hit left arrow until you get to 'system service' and press green check
Next
then go to 'clean' and press check
Now it should print a clean image without ghosting
May 29, 2008 | HP Color LaserJet 2600n Printer
HP LaserJet 2605DTN Color Printer Logo
577 people viewed this question
Seeker5211
Seeker5211
