Question about Panasonic NV-GS10 Mini DV Digital Camcorder
Help,,, camcorder when turn on says "to service " and turns off
Hello , when turn on camcorder , comes on display please re-operate after pushing reset button, when i do this comes on screen " to service " and turns off ,, any ideas !
  • Scott_1975 Feb 24, 2008
    i have the same problem when i turn on camcorder it comes on display please re-operate after
    pushing reset button, when i do this it comes on screen " to service " and
    turns off
    is there a service manual i can obtain to repair this myself
After reading the above solution, a few swift taps to the bottom got it to work. I guess it is just be careful, but if it happens - show it some tough love
Posted on Sep 06, 2008
  • 73 Answers
The bottom of the camcorder has been ' nudged ' and the drum cable has come loose ( way short ); will take a good tech at least an hour to take the camera apart and finish testing the repair but it may happen again if the camcorder is not kept in a well - cushioned carrying case ;
Posted on Jul 29, 2007
2 Suggested Answers
  • 3 Answers
SOURCE: help,,, camcorder when turn on says "to service " and turns off
see this
http://www.fixya.com/support/t301818-error_displayed_service
Posted on Feb 12, 2008
Hi having problem setting date ,month ,time on camcorder . The touchscreen is not working when i press against screen
If the touch screen of the Camcorder is not working, please follow the troubleshooting steps.
Please make sure that you're using fully charged batteries.
Turn off the Camcorder and turn ON again and check the operation.
Try resetting the Camcorder by pressing the reset button behind the LCD panel.
Note: Please make sure that the Camcorder is turned ON while pressing the reset button.
If the issue persists again, please perform LCD screen Calibration and check if that helps.
Please follow the steps below to perform the LCD Calibration
Perform a power resetting of the Camcorder. To perform power resetting, please remove the battery pack, turn the Power switch to Play/EDIT/ON for more than 15 seconds, turn the Power switch to OFF position and then reinsert the battery pack.
If the issue persists even after performing all the above-mentioned steps, service is required.
I hope this information will help you to resolve the touch screen issue of the Camcorder.
Feb 22, 2011 | Sony Handycam DCR-HC20 Mini DV Digital...
RCA CC6262 Camcorder Problem:
check that is not just a broken cable
Jul 06, 2008 | RCA CC6262 Camcorder
My display screen is blank.why
Ifthe screen of the Camcorder is not working, please follow thetroubleshooting steps.
Try resetting the Camcorder by pressing the reset button above the hand strap.
Note: In the above picture, 10 represent the reset button.
If the issue persists again, please perform LCD screen Calibration and check ifthat helps.
Perform a power resetting of the Camcorder. To perform power resetting, pleaseremove the battery pack, turn the Power switch to ON for more than 15 seconds,turn the Power switch to OFF position and then reinsert the battery pack.
If the issue persists even after performing all the above-mentioned steps,service is required.
I hope this information will help you to resolve the touch screen issue of theCamcorder.
Dec 04, 2010 | Sony Handycam DCR-HC32 Mini DV Digital...
I have a sony dig 8 trv340 and am receiving an error code of c31:42 what does this mean?
In DCRTRV430 Camcorder, the C:31:42 error message is a Self diagnostic display. This message can be clearly identified by the help of a Sony Authorized service technician. Each of these codes indicates the symptoms and resolutions of the Camcorder. In C:31:42, the issue is with the tape and the tape mechanism.
I suggest that you remove and reinsert the tape to check if it helps. You may also try inserting new tapes in the Camcorder. Please remove the battery and/or power cable, connect, and perform operations from the beginning. You may also try resetting the Camcorder back to factory default after removing the tape.
To Reset the Camcorder, perform the steps below:
? Please open the LCD screen to locate the RESET button.
? To reset the Camcorder, press the RESET button using a sharp-pointed object.
? Please make sure that the Camcorder is turned on while pressing the reset button.
Also, try turning off the Camcorder and remove the battery pack. Then move the 'Power Switch' of the Camcorder to the ON position
for 1 minute. After about 1 minute, move the 'Power Switch' to the OFF position.
Now reinsert the battery, turn on the Camcorder and check whether it is working fine.
Thanks.
KenSolutions
FixYa
Oct 23, 2010 | Sony Video Cameras
When i turn on my nv-gs50 vcr it says please re-operate after pushing the reset button
" " When i turn on my nv-gs50 vcr it says please re-operate after pushing the reset button
May 21, 2010 | Panasonic NV-GS50 Mini DV Digital...
Help
yes had this on a few JVC it may be that the moisture has corrosded the dew sensor and will need service. When you store it use those crystals that come in packing of some items They are excellent for preventing this in Video cameras
Please rate our help to keep the service online
Aug 17, 2009 | JVC GR-D290 Mini DV Digital Camcorder
Problem with Panasonic Camcorder NV-DS28
From speaking to a repair centre this is a very common problem with Panasonic camcorders.
I got the impression it was a panasonic problem with a connector that needed either cleaning or replacing.
There are 2 fixes, one is cheap quick and temporary.
The other involves sending the camcorder away to be professionally repaired, it should cost the minimum fee, which was £50 in 2007.
As for the cheap version, it involved turning the camcorder off and hitting it against a copy of the yellow pages and turning on again.  This worked for long enough to record my 2nd daughters birth.
Feb 22, 2008 | Video Cameras
Panasonic NV-GS50 - Display indicates "To Service"
This means you need to get it serviced, because it has detected a fault or error.
Sep 06, 2017 | Panasonic NV-GS50 Mini DV Digital...
LCD is not working
Hello, in order to repair this Camcorder you should replace the LCD panel flexible cable FP-185 and the plastic hinge cover. If you need more info please advice. Best regards. Arpi
Apr 26, 2007 | Sony Handycam DCR-HC42 Mini DV Digital...
Panasonic NV-GS10 Mini DV Digital Camcorder Logo
493 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
