Question about Symbol MC50 Pocket PC
I can't get my symbol mc50 to connect to a wireless server
Usually it won't accept the IP address, but when it does it says wireless network out of range...even if my computer is connected to the network, and even if the pocketpc is right next to the computer and the modem
  • 1 more comment
  • Anonymous Feb 27, 2009
    The arrows say I've got connection, all the internals are ok, but it won't download my orders to an ftp site.
  • Anonymous Mar 17, 2009
    usb drivesr for mc50
  • Anonymous Apr 16, 2009
    same problem. Won't connect. Says "network out of range" at the same time - signal strength is "Good"! WTF?
    There doesn't seem to be any way to troubleshoot the connection either.
  • 3 Answers
SOURCE: MC50
It seems very easy but here is the users manual
http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=6819502apdf&sliceId=&dialogID=35606078&stateId=1%200%2035594914
Posted on Dec 28, 2007
SOURCE: MC50 wireless connection
i have same problem with c5040 , i downlad activesync 4.5 and still i could not solve the problem . i can not get internet . wot i need to do ?
Posted on Jun 06, 2008
  • 6 Answers
SOURCE: Symbol Pocket PC 2003 ( MC50) wireless connection errror
Just upgrade the software on it to version 21 from Motorola site
Posted on Dec 11, 2008
SOURCE: reload operating system in symbol mc50
As you know a cold boot will not help you here.
You need to access the IPL loader.
Press and hold the Power button and both Scan buttons, then press the Reset button. When the mobile computer resets into IPL, release the Power button and Scan buttons.
If you need any more help then please do not hesitate to contact us:-
helpdesk@biastechnology.com or TEL 01202 620955
http://www.biastechnology.com/
Posted on Dec 11, 2009
  • 3230 Answers
SOURCE: need a manual for a symbol MC50 PDA
Well you can please follow the below links to get your manual -
http://phone.manualsonline.com/manuals/mfg/symbol_technologies/mc50_1_2.html
or
Good Luck!!
Posted on May 18, 2010
How to connect my self and make my IP address ?
you can set your laptop up to detect ip address automatically in its network settings. if you had provided the operating system it would have helped to narrow down how to do this. If you had told us how you plan to connect to the router this also would have been helpful. Are you connecting via blue cat5 ethernet cable or via wireless. If it is wireless your laptop should detect the wireless network and you can ask it to connect to it. If the wireless link is encrypted you need to log into the router via ethernet cable and look for the securirty settings on the wireless and find out what the encryption code is. Usually the router will use what is called an internal IP address range. the subnet is usually class c being 255.255.255.0 and the ip address default gateway IP address is usually either 10.0.0.1 or 198.168.0.1 and this can be put into the browser to log into the router. When you set the laptop to automatically obtain the IP address the Wireless Router has a DHCP server that manages the leases of IP addresses to computers connected to it. However if you are connecting the Wireless Router into an existing network with another router you will need to set the IP address to the next IP address eg 10.0.0.1 on existing router make second router 10.0.0.2> if you have a DCHP server on the wireless turn it off if you have a DCHP server on the existing router otherwise you have confusion as to which DHCP server to listen too on your network.Make sure the DHCP router does not allocate at least the first 10 addresses eg 10.0.0.1 to 10.0.0.10 to allow for the routers and printers on your network that may need dedicated IP addresses (Static IP addresses)
Feb 07, 2015 | D-Link dlinkgo Wireless N 150 Router...
I want to connect my Iphone to my wireless network..can I do that When I try to go on line with my Iphone it sees my local network but will not accept the password I have a wrt160n broadband cisco router
First of all you will have to configure your router to accept the iPhone. To do this you will need to go in to the router in your browser window and add your new device, it will ask you for your MAC number which can be found under the back cover of your iPhone or in your WIFI settings.
Then you will need to configure your router to either automatically assign an IP Address or use an allocated IP Address and use the same setting on your iPhone. Also, you will need to configure your router to either assign a DNS Server automatically or to use an allocated DNS Server and once again you will need to use the same settings on your iPhone.
Your IP Address is crucial in oreder for your iPhone to connect to your wireless network. Your DNS Server is crucial in order for your iPhone to access the internet through your wireless network.
Thank you for using FixYa! Have a great New Year and please remember to rate this solution.
Warm regards,
BearWeb
Jan 01, 2010 | Linksys WRT160N Wireless Router
How do i use my wireless ethernet? it recognizes the 1394 net adapter and i have the needed drivers with no splat problems. do i need to set up a wireless connection through the connection settings? i have...
If you are in a network, you need to have a thing called IP address which is usually assigned by a DHCP server or a wireless access point.If DHCP Server is not available in your case then you need to configure evreything manually.If DHCP server is available then you don't need to configure anything.Just search for the WI_FI signal and connect with it.
For manually configuring Wireless Network Setting
Go to control panel and click "network and Sharing Center", click Change Adapter settings" Right Click on the wireless adapter, Select "properties", click on "Internet Protocol version 4(TCP/IPv4)".
Select now use the followinf IP address,
Manually fill the IP address :
                       Subnet mask :
                       Default Gateway:
Select "Use the following DNS address "
Manually fill Preferred DNS address:
                Alternate DNS address:
For example :                           IP address               : 192.168.0.10
                       Subnet mask               : 255.255.255.0
                       Default Gateway           :192.168.0 1
                    Preferred DNS address    :218.248.234.117
                     Alternate DNS address   :218.248.136.142
IP address is needed for communications between devices.
subnet mask is needed for identifying your Network Address Node.
Default Gateway is usually your Router or Wi-Fi access point IP Address.
DNS address for resolving domain name(mostly for Internet browsing)
Hope you can connect it now.
HAPPY NEW YEAR.
Dec 31, 2009 | Gateway 4525GZ Notebook
When my wireless network is unsecured I can connect fine and browse the internet fine, but the moment I try to set up security I get a "limited or no connectivity" message from my wireless network. What's...
You must ensure that you have enabled the router as a DHCP server and the client PC network connection is set up to "obtain an IP address automatically". If the computer is not obtaining a valid IP address from the DHCP server (i.e. the router) you will get the limited or no connectivity error. You can easily check to see if you have a good IP address by opening a CMD prompt window and running ipconfig.exe. Generally, the WBR-1310 will have assigned an IP address like 192.168.0.xxx. If you have an IP address like 169.254.xxx.xxx you router is not assigning your computer a valid IP address. Powering down the PC and/or the router will usually fix this, but not always. There are other, more compliated, steps that can resolve the problem if the above steps do not work.
Oct 10, 2009 | D-Link 802.11g Wireless Router WBR-1310...
I ve adsl device for wireless sometime it works n sometime i ve to plug in cable because wireless function not works
well!! I have an answer for you.your comp is loosing the IP address. goto start - programmes - accessories - dos prompt. type ipconfig.you`ll get ip address,subnet mask,default gateway.copy it. goto network and sharing center,click on view status,goto propertiesand double click on internet protocol(tcp/ip) or IPv4.type in the IP address,subnet mask,default gateway.in DNS server address type the default gateway in primary DNS and in secondary 4.2.2.2. your connection won`t drop after this.
Jul 10, 2009 | Dell (430-3572) Wireless Adapter
Intel Proset wireless just drops connection
Jul 02, 2009 | Intel 3945ABG (WM3945AGM1WB) 802.11a/g/b...
My 2Wire Wireless adapter connection keeps getting disconnected every 5-10 minutes(ATT U-Verse Internet Svc)Is there a better adapter to resolve my problem ? Thank you.
well!! I have an answer for you.your comp is loosing the IP address. goto start - programmes - accessories - dos prompt. type ipconfig.you`ll get ip address,subnet mask,default gateway.copy it. goto network and sharing center in vista and network connection under control panel in XP,IN Vista,click on view status,goto properties and double click on internet protocol(tcp/ip) or IPv4In XP,right click wireless network connection and goto properties and double click on internet protocol(tcp/ip).type in the IP address,subnet mask,default gateway.in DNS server address type the default gateway in primary DNS and in secondary 4.2.2.2. your connection won`t drop after this.
Jul 01, 2009 | Computers & Internet
Connecting on 802.1x wireless network
www.socketcom.com
WIRELESS NETWORKING DEVICE 20PK SDIO BT CARD FOR MC50- [Manufacturer/Brand] SOCKET COMMUNICATIONS [Model/Part Number/SKU] BL4805-652, BL4805652
Apr 09, 2008 | Symbol MC50 Pocket PC
Cannot connect to the internet via the Wireless router.
contact ur service priovider they will provide u  ur ip address and default gateway as well as dns server address
After getting ur ip
go to network connection > wireless network connection > properties > scroll down for internet protocol  and double click on it > click on use  the following ip and then enter the ip address and default gateway with dsn server provided  by ur service provider > click ok
now u  r done and u can connect 2 the wireless network
Mar 01, 2008 | D-Link DSL-G604T Wireless Router
Symbol MC50 Pocket PC Logo
913 people viewed this question
Top Symbol Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Greg Cann
Greg Cann
Michael
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
