Question about Griffin Technology Evolve Wireless Sound System for Apple iPod - High-Gloss Black
Griffin evolve speakers
Can these speakers be opened?
The back plate is definitely snap off. As teodo mentioned, do not pull the entire rubber backing off. On the bottom and sides of the back plater there are two snaps, each directly on either side of the wider ridge along each edge. The top is a different problem. The snaps are on the speaker side and clip onto the bottom of the upper edge of the back panel. To remove the back plate: Start on the bottom of the speaker at the back edge. Pull away the rubber edge carefully to expose the joint between the back panel and the speaker box. Along the center of the of this joint on the panel is a wider ridge. Place a thin flat edged tool on one side of the ridge, pry, then push forcibly until the inner edge of the back plate is apart. Do this to each of the edges on the bottom and sides of the speaker. Don't peel away any rubber on the top side of the speaker. Press your flat edged tool into the joint and lift gently the back plate side of the joint before pushing it out. This will disengage the clips on that edge. If you're looking to replace the batteries, they are 3.5V 5200maH. Take Care
Posted on Feb 25, 2010
  • 2 more comments
  • Ketterman Jan 27, 2011
    Retro, did you find a place to get a new battery pack?
  • Rick May 13, 2012
    I'm sure nobody reads this anymore but where did anyone get a replacement battery?
  • MadAxeManUK Jun 05, 2012
    I'm looking for a replacement battery too. Any ideas?
Here is a picture of the Evolve Speaker back cover removedgriffin evolve speakers - _573.jpg
Posted on Jan 27, 2011
  • Victor Zavala Jun 09, 2013
    Where can I buy a replacement battery?
Yes, but you need the right tools and you are likely to scratch and mark the surface.
They aren't 'sonically welded', they are just snapped together. To open them you'll need some thin but rigid pry tool and a lot of patience.
You'll need to remove the back cover (the side with the ON / OFF switch). First peel the rubber off the edges - you don't need to fully remove it, just enough to access the joint between the cover and the rest of the speaker. Then pry open the light gray plastic cover.
My speaker wasn't working because I dropped it, causing the magnet to detach from the chassis. It was a very easy to fix it once I managed to open the speaker. Griffin support gave me only one option: buy a new set. Unfortunately they are not available anymore in my country.
Hope this helps
Posted on Jan 30, 2010
  • bonimoron Jan 07, 2011
    how did u reattach the mgnet? mine is the same problem and got it to work but cant secure the magnet
No, don't ask me how I know, but they're sonically welded. Let Griffin know if you're having trouble and they can probably help you out (email them at support@griffintechnology.com). Good luck, Rachel
Posted on Feb 11, 2009
3 Suggested Answers
SOURCE: griffin evolve remote not functioning
how did you take off the back to put in new batteries... try syncing your speakers by holding the 2 volume buttons on the base at the same time for about 2 secs.... the light will start to blink and you just click any button on your remote. If that doesnt work then its firmware
Posted on Dec 03, 2009
oldmanewtoys
  • 414 Answers
SOURCE: the speakers to my griffin evolve system do not
sender reciever is off code to send signal
Posted on Feb 26, 2010
My Griffin Amplifi is not working, and I am trying to fix it, but i do not know where the screws are at to open it.
Pull off the knob, undo the bolt on the pot. Then remove the plastic cap which disseminates the blue glow. Next, slip your nails under the edge of the metal grille and slowly prize it off (don't worry, it's supposed to come off). Now there's 8 screws exposed. Undo those and she's all yours...
Aug 30, 2011 | Griffin Technology Amplifi Speaker System...
One of my speakers is not charging. How do i replace the battery.
the batterys are not replaceable because they are rechargeable please contact the manufacturer i hope this helps
Jul 26, 2011 | Griffin Technology Griffin Evolve Wireless...
The speakers on my Griffin Evolve wireless speaker system will not work. However, when I transfer them to a second identical system and base, using the same iPod they do work. It seems as though the base...
Well, you did the right thing by verifying that the speakers are not the problem (they work in an identical system). Try connecting a different iPod, just to rule out that being a problem. Some of these docks need an adapter for some versions of the iPod... check to make sure you have the right one. Otherwise, if the base is defective, maybe you can get a replacement from Griffin. Contact their technical support staff. Good luck.
Nov 07, 2010 | Griffin Technology Evolve Wireless Sound...
My 2yr old was playing with my ipod in my griffin speakers
Unfortunately, it sounds like she broke the jack inside of it. It has lost connection to the main circuit board, and is of course now useless. If you know what you are doing and it is NOT under warranty, you could try opening it and resoldering it, not that it will definitely work. Otherwise, if it is under warranty, back it up (if you can), and take it back to the store.
May 01, 2009 | Griffin Technology FireWave Surround Sound...
Itouch does not play through fm transmitter
i had the same problem... like it played through the itouch speakers and not through the radio how do i get it to play through the radio
Apr 07, 2009 | Griffin Technology iTrip Auto FM...
Griffin evolve remote not functioning
Dec 28, 2008 | Griffin Technology Evolve Wireless Sound...
Griffin Technology Evolve Wireless Sound System for Apple iPod - High-Gloss Black Logo
6,753 people viewed this question
Top Griffin Technology Audio Players & Recorders Experts
Gary
Gary
Are you a Griffin Technology Audio Player and Recorder Expert? Answer questions, earn points and help others
