Question about Acoustic Research 900MHz Wireless Stereo Speakers with Auto Tuning
Can Acoustic Research wirless speakers be used for surround?
I bought Acoustic Research AW877 900 Mhz Indoor Wireless Speakers, and they only work with "line out", not speaker terminals. I think they are only for using as extra speakers, not surround. Am I right? Amazon will not take them back. Any ideas?
Thanks,
Atiq
  • atiq1969 Jan 29, 2009
    That's exactlw was I was looking for. Thanks! But won't it still damage the transmitter, even if I connect it to the "speaker to line level adapter"?
    By the by, even the "geniuses" at Acoustic Research didn't offer me that suggestion (the MANY times i called). You must be an electronic genius!
    Scholar:
  • 140 Answers
Yeah, I looked it up on thier website. Here is what they say.
Warning: This product is designed to work with line level outputs or headphone outputs only.
DO NOT connect it directly to speaker outputs as it will permanently damage the transmitter.
You can use these as surround speakers if you like. You just need a line level surround output on the receiver. Most high end receivers have this feature but, you may only have speaker level outputs.
If that is your case the only option you have is to use a "speaker to line level adapter".... http://www.crutchfield.com/p_543ADP12/Russound-ADP-1-2-Speaker-level-to-Line-level-Adapter.html?tp=9070
Now crutchfield.com is always a little high on prices but if you look around I have seen them around $10 online.
Good luck with your project.
Posted on Jan 29, 2009
  • sleepy_user
    sleepy_user Jan 29, 2009
    As long as you get decent quality converter/adapter you should have no problems with damaging the unit. The more expensive units actually have little adjustment knobs on teh adapter so you can adjust the output levels to the transmitter.
I have a pair of acoustic research "active partner" speakers in need of a power adapter. Above the entrance of the plug in print it has DC 11.5 V. Need a compatible adapter.
DC 12v adapters are common and I think that would work. The similar "Powered Partner" speakers used a 14v DC adapter. Just check the size of the plug and the configuration (center pin is +). Radio Shack and other sellers have universal adapters.
Sep 29, 2013 | Acoustic Research Audio Players &...
Acoustic Research Model AW871 wireless sterio speakers
Your connection between the AR transmitter and the ONKYO receiver sounds solid. I'd guess it's the wireless speakers that are the wrong point, or at least that's what I'd look at first. Doing a bit of research, I noticed a couple minor points. First, these seem prone to RF interference from other RF devices. Have to tried switching channels on them? Second, someone reported theirs would not work properly unless the speakers were turned on just before the transmitter, and turned off shortly after the transmitter. Apparently you have to hold the button on the front in for 5 seconds to turn the speakers on or off. I know that's rather basic, but it's been a few days and no one else has responded, so I figured we should start somewhere.
Aug 27, 2007 | Audio Players & Recorders
I connected an external device to USB 1 and watch movies with no problem, except I would like for the audio to play through my dvd player which has surround sound. With no audio o/p RCA connections on the...
you are using a stereo speaker so definitely you won't get surround sound, Most TV may have either RCA or 3.5mm headphone jack type, both serve the same function, what you need to do is just use a convertor check from this link.
May 16, 2011 | Acoustic Research 900MHz Wireless Stereo...
I just purchased a LG LE5500 55" TV. When using my accoustic research wireless speakers it creates an echo effect. The Geek Squad said there was nothing I could do to prevent this echo. Is there a way of...
try different ways of sending the audio to the speakers. you can go digital out from the tv into your receiver or go directly from your cable/satellite box into your receiver. I use both...from the tv for netcast and from the box for all others. assuming you are going through a receiver
May 08, 2010 | Acoustic Research 900MHz Wireless Stereo...
I want wireless speakers for a 25'X 30' room to connect to a stereo. would the Acoustic Research be powerfull enough. Are the two speakers truly wireless or do the need to be connected to each other
they are wireless but need to be plugged in for power. or batteries. can be used as mono or left and right. i sell these spkrs and have had no complaints. hope this helps.
Jul 10, 2009 | Acoustic Research 900MHz Wireless Stereo...
I have a set of Wireless Acoustic Research speakers. I recently came home from college and the transmitter (connected to the television) does not work. I've tried everything from trying a different outlet...
Try using a different source than your television. If it works, then there's an issue with the output of the TV. However, if you use the same cables as you were using with the TV, they may be bad. Try using another device with a different set of cables to plug into the transmitter, which should help identify where your problem really is. Please rate my answer, thanks.
May 11, 2009 | Acoustic Research 900MHz Wireless Stereo...
Cylinder Like Sharper Image Indoor/Outdoor Wireless Speakers
ask google or you tube or go to car toys they can help. good luck
May 18, 2017 | Sharper Image SR277 Speaker
Wireless speaker won't come on after plugging in now....
Try the adaptor that you know works in the speaker that doesn't. That will eliminate if its the adaptor or the speaker. You will need a multimeter to check if its the on /off switch or not. A quick alternative is to "bridge" out the on / off switch wiring. (Use a piece of wire to join the wires going through the switch together.)
Sep 04, 2017 | Acoustic Research 900MHz Wireless Stereo...
Yamaha htr-5940 with Acoustic Research wireless speakers AW877
use a 4 way splitter directly off the cable box 1 pair off cable to two out puts from cable box my setup works even tv is off I use it for music with tv off
Jun 03, 2008 | Yamaha HTR-5940 Receiver
Acoustic Research 900MHz Wireless Stereo Speakers with Auto Tuning Logo
324 people viewed this question
Top Acoustic Research Audio Players & Recorders Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you an Acoustic Research Audio Player and Recorder Expert? Answer questions, earn points and help others
