Question about Microwave Ovens
I purchased a Dualite Mini Oven Model #POA316. I purchased the mini oven through Costco. The ad says you are to receive instructions along with receips that should be inside the carton. However there are no instructions or any paper work.
  • Microwave Ovens Master
  • 9,042 Answers
The Smith Agency, Ltd. exclusively handles all sales and marketing activities of DUALIT household products in the USA. Please use this web site to see product information on all available items offered by DUALIT in the USA. We encourage you to contact us at the e-mail address identified below to assist you in the purchase or marketing of DUALIT products.
DUALIT USA
P.O. Box 669307
Marietta, Georgia USA 30066-0106
Telephone: 770.509.3006
Telefax: 770.509.8736
Email dualitusa@smithagy.net
Your owner's manual is here.
Posted on Jan 28, 2009
Panasonic Oven model No NN-C784MF/WF
I would keep the items in. Usually, oil is sprayed on which can cover anything that is in oven at that production step. Won't hurt anything one way or the other.
Mar 12, 2014 | Microwave Ovens
Kenmore modle 721.80042700
It may be a blown fuse or a bad thermostat / TCO on the oven cavity or above or on the microwave.
Yours should have a "mini-manual" (technical sheet) hidden either behind the grille or control panel. It is very helpful in locating and testing components.
There is a video here showing how to remove a typical over the range control panel assembly in under 5 minutes.
Accessing some components (especially the oven cavity thermostat) for testing and possible replacement will require you to remove the oven from the wall and take off the outer cover.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download Kenmore manuals and installation instructions at http://www.managemylife.com by clicking the Manuals link near the top center of the page. Then enter your full model number from the tag on the oven on the next page.
A full Sears/Kenmore model number has 3 digits, a dot, then 8 more digits, such as ###.########
You can order parts and find helpful exploded views at the Sears Parts Direct Web site .
May 03, 2013 | Kenmore 62622 Microwave Oven
Microwave and display panel are not working. There is power to the electrical ground fault interruptor box and it is not tripped. Could it be the fuse inside the unit itself? I can see a fuse behind the...
Since you posted this under model KHMS105EBL, I'll assume that's your model number.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
If you don't find your mini-manual, or if you want to look at it before removing the controller, you can download it here (just enter your full model number with no dashes).
You can also find helpful exploded views and order parts here.
This model has a line fuse, an oven cavity thermostat, and a magnetron thermostat, any of which can render the oven "dead".
If those components are good, then you may a problem with the control circuit board. More info here.
Accessing some components (like the oven cavity thermostat) for testing and possible replacement will require you to remove the oven from the wall.
You can download Whirlpool / Kitchenaid owner's manuals and installation instructions here.
If you need more help, let us know.
Aug 10, 2010 | KitchenAid KHMS105EBL Microwave Oven
Whirlpool microwave GH7145XFseems to have shorted out. Is there a circuit breaker somewhere on the oven itself that can be reset? History: Trying to turn off the oven light when the door was open, I...
There should be a line fuse inside, and a less likely culprit would be the oven cavity thermostat.
mini_manual_behind_grille_small.jpgAt our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you don't find your mini-manual, or if you want to look at it before removing the controller, you can download it here (just enter your full model number without dashes).
Accessing the oven cavity thermostat for testing and possible replacement will require you to remove the oven from the wall and take off the outer cover.
You can download Whirlpool owner's manuals and installation instructions here.
If both of those components are bad, it may be a damaged control circuit board.
We can repair that for $39.95 in most cases, or you can buy a new "microcomputer" circuit board (part number 8169379) here for $146.66.
Jul 16, 2010 | Whirlpool GH7145XF Microwave Oven
My MH3185XP microwave oven will not turn on. Power is to unit. I changed the fuse inside key pad (clear fuse) but still no luck. Suggestion?
In these models, there are several fuses and two or three thermal cutouts / thermostats which need to be checked.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden behind the grille, which is very helpful when troubleshooting, testing, and locating components.
If you don't find your mini-manual, or if you want to look at it before removing the controller, you can download it here (just enter your full model number from the label on your oven).
Accessing some components for testing and possible replacement will require you to remove the oven from the wall.
You can download owner's manuals and installation instructions for several brands (including Amana, Frigidaire, Jenn-Air, Kitchenaid, Litton, Maytag, Roper, Tappan, Thermador and Whirlpool) here.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
May 27, 2010 | Whirlpool MH3185XP Microwave Oven
We urgently need Instruction Manual / owner's Manual (original booklet) of our newly purchased Microwave Oven having Model "CE283GLT/XTL" (Product Serial No.:09317DEL900334D) as this Manual is not...
hi, here is the link to the manual of your microwave
http://downloadcenter.samsung.com/content/UM/200709/20070914093233421_CE283GL_XTL-02976H_EN.pdf
kind regards
Mar 11, 2009 | Samsung Microwave Ovens
No power maytag mmv1153aaw
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
It may be an open fuse, magnetron TCO or oven cavity TCO.
Accessing the oven cavity for testing and possible replacement will require you to remove the oven from the wall.
You can download Maytag owner's manuals and installation instructions here.
Jan 27, 2009 | Maytag MMV4205 Microwave Oven
Maytag mmv1153aaw
GE Microwave/Convection JVM 1090 oven won't reach temperature
You probably have a bad thermistor.
(At that site, that part is misspelled as "thermister" for your model).
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Accessing some components for testing will require you to remove the oven from the wall.
You can download GE owner's manuals and installation instructions here.
Jan 02, 2009 | Microwave Ovens
REPLACING FUSE IN WHIRLPOOL MICROWAVE
It's hard to tell from the exploded views, but it appears to be on the floor of the microwave behind the control panel.
At our site, we have a video showing how to remove a typical over the range control panel assembly in under 5 minutes.
If the fuse is not the culprit, also check the two thermostats - one on the magnetron and one on the top of the oven chassis.
The mini manual / tech sheet will show you where they are and how to test them.
To check the oven thermostat, you will need to remove the oven from the wall. You can download Whirlpool owner's manuals and installation instructions here.
Nov 04, 2008 | Microwave Ovens
Microwave Ovens Logo
99 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Gerry Harvey
Gerry Harvey
Are you a Microwave Oven Expert? Answer questions, earn points and help others
