Question about Mitsubishi VS-60703 60" Rear Projection Television
Sound but no picture, menu looks bowed/hourglass screen
Last night it was fine and this morning there is sound but no picture.  the menu comes up but looks like it is displayed on a bowed screen so i have the red, green and blue letters all just off of each other.  then this afternoon it was ok again.
  • jvaliga1 Jan 29, 2009
    Thank you for the quick response.  How do i know which chips are the convergence chips?  are they marked or do i need to get a schematic for the TV.  If i need a schematic, where do i get one.  I am do not know anything about fixing this but I know someone who can if i let them know what to solder.  Also, am i re-soldering chips or amps, you made reference to both.  Sorry if it is a ridiculous question but like i said, i don't know much about electronics repair.
    Thanks again.
  • jvaliga1 Feb 05, 2009
    1 more thing i noticed, when i took the front panel off i saw what looked like sticky liquid on the circuit board, after doing some research it looks like a crt cooling leak might be happening.  How difficult is this to fix?  I found coolant online and need to know what to use to seal the tube.  I saw something about RTV sealant, where to i get this?  could this be my problem instead of needing to re-solder convergence chips or is this a separate issue?
    Thanks in advance
    Joe
    Novelist:
    Champion:
  • 203 Answers
This is a common problem on projection sets and if you have someone carefully resolder the pins of the convergence chips, it will probably solve your problem. If you continue to use the set, the amps will fail and leave a dead set condition. What needs to be done is to disconnect the power, remove rear cover, loosen all snug wiring making sure to mark any wires that you disconnect, remove screws holding chassis in and undo plastic hooks at front of chassis, access bottom of circuit boards and with low wattage soldering iron resolder convergence amps, reinstall chassis and rehook all plugs in original places especially ground wires and high voltage leads, and test. If the soldering iron is too powerful it will damage the chips, also, be sure each solder joint is clean and not touching the one next to it or you will fry circuitry. Hope this helps. Russmann.
Posted on Jan 28, 2009
  • Rusty Larmann
    Rusty Larmann Jan 29, 2009
    Glad I could be of some help. The convergence I.C.s or (chips) are stereo amplifiers which in your set perform color alignment duties instead of audio functions. These two I.C. chips are located on the largest metal brackets standing on the circuit board known as "heatsinks". There are locatiion numbers for each component on the circuit board and the location numbers for the convergence I.C.s are IC8D01 and IC8D02. The generic number stamped on the side of the parts is STK392-110. I really do have to suggest having a professional tech. do this repair. Saving a little money may cause you to have to replace the tv if not done properly. Of course, my opinion and help is free..... You're welcome, Russmann.
  • Rusty Larmann
    Rusty Larmann Feb 05, 2009
    Well, that changes everything. Coolant leaking from the tubes can cause anything in the set to fail depending on what it drips on. This is a major repair even for an expert. We use dawn dishwashing liquid and warm water to clean the circuit boards then put it in front of a fan to dry.(Scrub with brush). Resealing the tube can be real tricky, especially if the expansion chamber is what burst to cause the leakage. If this is the case and the rubber expansion baloon has busted, silicon rubber will do you no good. Only if the seal around the face of the tube has failed is silicone sealant going to help. Look very closely with good lighting for the leak before spending more money on it and check on the board for corrosion or burnt components. It's probably time to call a local pro on that brand and ask for their advice.Good luck, Russmann.
Looks 3d,bows in the middle
You must replace conversion IC's (2)
Part number: STK 392-xxx
Also check resitors in circuit for>>open
easy repair!
May 19, 2010 | Sony KP-43HT20 43" Rear Projection...
Sound no picture
backlight invertor board/does it flash when powered on
Apr 20, 2010 | LG 32LB9D TV
Wharfedale LCD3210HDAF blank screen
Wharfedale LCD3210HDAF this tv was working fine the night before .. when i turned it on in the morning the screen came on then instantly went blank .. although the sound is fine i am unable to get any on screen including menu an volume information and of course can any one help ??
Oct 27, 2009 | Televison & Video
Samsung PS50C91HDX Sound but no picture
It sounds like the main board or screen may have gone
Sep 26, 2009 | Samsung 50 in. Plasma TV
Picture is blurred and bowed
ok you have a convergence problem. first check out the article the fl231 problem in the tips and tricks section it will tell you of a condition that might mean an easy repair. first check to see if you have the convergence options in the customer setup menu
Mar 15, 2009 | RCA HD52W59 HDTV Projection Television
Sony 53 inch projection screen with hourglass picture
If you are familiar with TV repair, have electronics basic knowledge, good soldering skills and tools then check dry (cold) soldering joints at D board of this TV. Resold all lose connections there and check picture.
Still no joy then you need to replace D board.
Feb 25, 2009 | Philips 60PP9202 60" Rear Projection...
KP-43t75 no picture black screen, Menu comes up bowed
Ur convergence it dead.Buy a convergence kit,replaced what in that kit.Know how to solders right?Buy a convergence kit in these websites Tv repair World.com,Tv rpair Kits.
Feb 04, 2009 | Sony KP43T75GRAY 43" Rear Projection...
Picture(Color Convergence)
Go to menu look for convergence on menu if it is not on menu then you have a open fuse located next to Flyback Transfomer on deflection board.
Sep 18, 2008 | RCA D52W19 52" Rear Projection Television
JVC i art 32" flat screen
Does anyone know where can I buy a screen for a 27" LCD Insignia TV. Model is NS-27LCD? My screen creaked. I checked out e-bay and have not found a broken TV with a good screen. Does anyone know where I can buy a screen at.
Thank you all for you time.
JC
Jul 22, 2008 | Televison & Video
No picture but sound works.....
  • adjust brightness setting when playing tv.
  • adjust screen control located on flyback transformer.
  • hope this will help.
Oct 23, 2007 | Sony KV-36FS16 36" TV
Televison & Video Logo
222 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
