Question about Radio Communications
Kenwood 802r power lead
I NEED TO NO THE POWER AND GROUND PRONG COMMING OUT OF THE POWER BOX ON THE TK 802R RADIO NOT ON THE HEAD BUT ON THE BOX YOU PUT IN THE TRUNK.
I CONTACTED A KENWOOD DEALER AND HE WAS GLAD YO HELP ME WITH MY PROPLEM AND DIDNT CHARGE ANYTHING.
Posted on Jan 29, 2009
I NEED WIRING GUIDE FOR a PPT, PRC to Kenwood K1
not sure does this help? http://images.kenwood.eu/files/prod/855/5/R-K1_EN.pdf
Apr 30, 2014 | Kenwood Radio TK 260 360 270 370 2100 3100...
I need help programming my tk-690 / tk 790 dual head dual band
Try this: join yahoo group Specific to your radio Make/Model, apart from great info you can download manuals, schematics and other goodies for your radio, all this is free.
Note: Re:- Downloads, only if available!!!
I hope this helps you with your query.
Cheers,
Peter
Mar 09, 2013 | Kenwood Kpg-44d 2.03 Radio Programming...
How do I reset my KENWOOD TK-3170-K 4 to original settings?? Thank you!!
- Power the radio OFF
- Power the radio ON
- Push and hold The UP arrow, DOWN arrow, and MON keys and power the set ON
- Release the keys when the message rESt (reset) appears on the display.
Need the manual? You can download and print it, at no cost, here:
http://www.kenwoodusa.com/UserFiles/File/UnitedStates/Communications/LMR/Manuals/TK-3130_B62-1486-20.pdf
Bill B.
Nov 22, 2010 | Kenwood Protalk XLS TK-3130 (2 Channels)...
My kvt-719dvd will not power up. I hit the reset button and nothing happens. When I take the faceplate off the red security light blinks....Just wired up a flip down and using the same power source as the...
take a digital volt meter and check powers and grounds
red ignition switched wire should read with car on and running 12.5 volts to 14.4
yellow constant power comming from battery should read at all time 12.5 to 14.4
black wire is ground and should be ground to the frame of car
lets take your radio ground and put your volt meter black lead on it and then put the red test lead to the read wire and if you have a good ground you get a reading of 12.5 to 14.4 if you car is running if ignition if on accesory it will read 12.5 do the same test to the yellow wire make sure you get a reading without the car on at all . this wire will have power on all the time hint(constant power) or (b+) if no reading on any wires you have a bad ground
let me know what you get for voltage to help you more
caraudioquestion@gmail.com
to get a good ground you need to scrap the paint off to bare metal and then us a stare washer and use a good stanless steal screw so dont rust for a good ground ..
Oct 14, 2010 | Kenwood KVT-719DVD 7 in. Car Monitor
I bought a Kenwood model TK 8102/TK 7102 how do i program it?
I bought Kenwood TK 7102 VHF radio, but it was programmed and I can listen the dispatcher but can not transmit to him. Any solution please help.
Aug 20, 2010 | Kenwood TK-3101 Radio
No power
check ignition and ground maybe even double up ur ground
May 18, 2009 | Kenwood KDC-MP438U Car CD/ MP3 Player
Problem with radio in vw sharan
First remove the unit so as to access the power and ground leads. Then with a voltage testers ground lead attached to the head units ground wire operate the unit as normal until the shutdown happens. Then test both power supply leads for 12+ vdc (one is a constant 12+ volts memory feed and the other is a switched 12+volts for operating functions)
If ether of these do not register 12+ volts then you need to find a different power source. If they do register 12+ volts then the problem is in the head unit. In which case if you are emotionally attached to that unit then have it serviced, if not replace it.
Note: A replacement may be cheaper...
Good luck
Aduz
Mar 23, 2009 | Kenwood KDC-MP4028 CD Player
How can I program my Kenwood TK-3101 Radio?
Here is a link to the Kenwood TK3101 Manual which explains how to program this radio.
http://www.hitechwireless.com/pdf/Kenwood/TK3101-manual.pdf
If you need custom programming please contact us.
HiTech Wireless 888.511.5162
Mar 18, 2009 | Kenwood TK-3101 Radio
Fixing kenwood tk-80
If you have the schematics try to follow the voltage lines with a volt meter. If this is beyond your capabilities then I would suggest taking the radio to a service center or sending the radio to Kenwood.
Nov 18, 2008 | Kenwood FreeTalk XL TK-3101 (15 Channels)...
Radio Communications Logo
29 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
