Question about Nokia 6500 Slide Cellular Phone
My Nokia 6500 is not getting switched on
Could anyone advice if its is a battery problem or a software problem? I bought Nokia 6500 Slide 4 months back. Everything was fine. Suddenly I found my phone switched off. I tried to wsitch it on. but it didn't get switched on. It only displayed the nokia starting display screen and the screen gets blank after 5 seconds.
Could anyone advice on it?
Appreciate your feedbak.
  • mzeke77 Mar 16, 2009
    Just bought Nokia 6500 slide, charged it for 4hrs and switched it on. the screen only went on for 5min and became blank. I switched the phne off and stiched it on again but the screen was still blank. tried it for several times but the screen is still blank(dark). Is it the problem with the screen or what?
  • juliux72 Mar 27, 2009
    pues de repente se me quedo oscuro,le doy a encender,vibra aparece las letras de NOKIA y no suena la musiquilla,sino q parpadea la pantalla se queda toda blanca y se apaga,y no funciona nada,lo pones a cargar y esta todo el rato encendiendose y apagandose la pantalla,pero toda blanca,no se q le puede pasar,si alguien encuentra una solucion o le a pasado se lo agradeceria,me lo puede decir juliux.acha@gmail.com gracias....
    Problem Solver:
  • 8 Answers
Its problem flex if u change flex everything will be fine
or contact me balwinder_monica@hotmail.com
Posted on Mar 17, 2009
Try charging it or, checking if there is anything wrong with the battery if not then try the repair shop.
Posted on Mar 28, 2009
  • 4 Answers
...You broke it.
Posted on Jan 28, 2009
How i unlock my nokia 6500 slide ?
There are lot of ways to Unlock the Phone from Network lock,But i suggest the Network Unlock code to unlock the Phone from Network ,you can get the unlock code at here
Mobile-Unlocker and follow the instructions below and unlock it step by step.....
1 - Switch on your Nokia 6500 SLIDE without any sim card.
2 - Don't bother as to what is displayed on your Nokia 6500 SLIDE.
3 - Compose #pw+CODE+1#.
4 - The Nokia 6500 SLIDE would then display the message "SIM Restriction Off" and will be unlocked!
Unlocking instructions for Nokia 6500 SLIDE:
Note :For Nokia 6500 SLIDE mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia 6500 SLIDE
Sep 07, 2011 | Nokia 6500 Slide Cellular Phone
When i switch on my nokia 6500 it switches back off
hi first of all charge your phone battery after doing this switch on your phone if it shows same problem then there is a software issue with your phone you have to load the nokia phone software on your phone from nokia service center
Apr 28, 2010 | Nokia 6500 Slide Cellular Phone
Nokia 6500 slide. turns off after about 4 minutes
its either a battery or software problem.
Test the phone with another battery. And if its not a battery problem, then it should be a software problem. Maybe you should flash the phone.
Take care.
Mar 08, 2010 | Nokia 6500 Slide Cellular Phone
I have a nokia 6500 slide black edition and I bought only last month.I was wondering about the ime # 353187031886656 and made in hungary is this right?as I know (03)(7 to 8 digit)is made in china.I need...
can be.most of the 6500 be are made by nokia.the sticker that says that it is made in hungary has been changed.by the seller or by someone.can't say deffenetly.but the IMEI says the truth.
Aug 17, 2009 | Nokia 6500 Slide Cellular Phone
The phone turns on then the screen goes white
Hi Friend,
The problem may be because any software my got hanged or any virus may create this problem so kindly check it out.
Or you may try the below steps,
1.Switch off the mobile
2.Remove the battery,sim card and the memory card
3.Hold the Switch ON/OFF button for 20 to 30 sec's
4.Now Replace the battery and the Sim card
5.After it has Switched ON,replace the Memory Card.
Check and revert back
Thanks and revert back
Regards,
Ayyasam
Jul 31, 2009 | Nokia 6500 Slide Cellular Phone
All buttons suddenlly stopped work correctly.
must be check if it exposed to any sort of liquid and if not remove the memory card and try to do software
May 11, 2009 | Nokia 6500 Slide Cellular Phone
My nokia 6500slide displays white screen only
u'll have to give ur handset to the nokia warranty service centre n they'll fix it in a day or two. Its a common problem that is effecting all the 6500-s models sooner or later. even i had that problem only after 1 1/2 month after i bought my new nnokia 6500-s,thank God as i had the warranty card and period...i got it repaired.
Jan 14, 2009 | Nokia 6500 Slide Cellular Phone
6500 slide on3g unlocking codes to 02 network
Dude, I have no clue what you are talking about. But did you try the last 4 digits of your phone number or maybe the BHLPJ code?
Mar 16, 2008 | Lands Phones
Nokia 6500 Slide Cellular Phone Logo
301 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
