Question about Sony Cyber-shot DSC-W55 Digital Camera
DSC W55 Error code E:91:01
Will not flash. 6 mos. old. great camera. Getting error code E:91:01. Tried resetting. Don't want to send back to factory unnecessarily. Sony Cybershot DSC W55 does not flash! an Error code E:91:01 always appear. I tried everything and did all the steps with a Sony live chat expert. However, he told me to take it to a sony repair center. Do you a solution for me. Please
Emad
  • 1 more comment
  • rltanmd Feb 07, 2009
    Hi. how do you reset the camera?
  • satyawan bansal Feb 12, 2009
    E:91:01 flashing on the screen. Flash button not working. Please suggest solution. After about 50 shots file error appears in every shot taken thereafter.
    Thanks in advance.
  • Shahid Electronics
    Shahid Electronics May 11, 2010
    I replied your first post, get back to me with results to guide you further.
  • Sony Master
  • 586 Answers
Hi,  Its an error of flash unit(E:91:01 denots flash unit problem) which get started malfunctioning. Therefore you have to replace the FLASH UNIT ASSY.
  For changing of flash unit assy. You can contact any sony service centre nearby to you. For your convenience please visit:
www.sony.net
or
www.sonyworld.com
Here you can find contact info of nearest service centres.
Thanks for using FIXYA.
Posted on Jan 31, 2009
I have a sony cybershot dsc w55 with error e:91:01. i have pressed the reset button and initialised the camera numerous times. the error is removed but the camera will not take a picture in auto or p mode...
E:91:01 is an error code that indicates problem with flash unit circuit in camera.
Flash unit board will be replaced to resolve this problem and temporary fix is to set flash Off quickly, before error could appear after initializing camera, hope this info will help you.
Thanks.
Oct 18, 2010 | Sony Cyber-shot DSC-W110 Digital Camera
Error:91:01 how do you get rid of it?
Follow the procedures given below to have a perfect fix for your problem.
  • Press Menu button.
  • Toggle across from REC Mode to setup
  • Toggle down thrice from camera to setup 1
  • Toggle across into sub menu
  • Toggle down from four times to Initialize
  • Toggle across again to the sub-menu
  • Toggle up from cancel to OK
  • Press center button to accept the OK choice
  • Screen changes and so press okay again
  • It should restart the camera
  • Opening on the 'Clock Set' screen
Toggle down to cancel and use the camera and make sure that you have the camera to flash, if it works try again in the Auto function. If it is still not working dont worry follow the steps again two or three more times, As this is related to a software error message and not a hardware malfunction. If it is working then don't forget to set your Clock.
May 22, 2010 | Sony Cyber-shot DSC-W55 Digital Camera
Getting error E9101 with my w55
The error shows that(Abnormality when flash is being
charged.) the problem in in FLASH UNIT, it needs replacement, the part number is given below according to the model number you mention DSC-W55 Part No. 1-479-663-31 Description (FLASH UNIT).
Thanks for using ifxya.
Jul 27, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
I tried using my camera using auto flash but no flash came out. Error E:91:01 keep on flashing in my camera.
This may be solved by doing a reset to the camera. There is a setting in the menu called Initialize, and it should reset the camera back to factory default.
Word of warning though. You will lose any pictures on it when you do this, so download them first. You will probably have to re-enter the date and time after this as well.
Jul 27, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
My Sony Cybershot DSC W55 "7.2 mega pixel" does not flash. Error code E:91:01 ?
Please RESET your camera , go to Menu > Initialize > OK
If problem still exist you need to replace flash unit in camera.
Let me know if you need further help.
Jan 28, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
SONY DSC W 90
Flash is not working and Getting Error on screen E91:01
Oct 21, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Error E91:01 on DSC H7
If the camera works in all other respects, then that has something to do with the flash setting or some other setting in the menus. But this sounds like something with the flash directly.
Here is a link which may be able to help on the DSC H7: http://www.aakatz.com/whitepaper/whitepaper/appendix2.htm
Try also to reset all the menu setting back to what it was for the factory. Most digital cameras have a setting for that, and usually is something like "RESET ALL" or something close to that.
If nothing works, then the camera needs repair. This is an error to do with the flash only, it appears. So some of the internal parts could be weak, thus causing the error.
Jul 27, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
I've had the camera for about 2 years. Have had this problem twice. All I've done is follow the manual to reset/initialize the camera's original settings. After that it works pretty good.
Mar 24, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
E:91:01
easily just reset the camera with a pencil.
Aug 14, 2007 | Sony Cyber-shot DSC-T10 Digital Camera
Sony Cyber-shot  DSC-W55 Digital Camera Logo
770 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
