Question about RIM BlackBerry Curve 8310 Smartphone
Blackberry curve won't pair with my bluetooth headset
I just switched from a blackberry Pearl to a Curve. When trying to set up my bluetooth options I have found that the Curve can't find my bluetooth headset to pair with it, and although the Curve has paired with the Pearl and my Husband's Samsung phone, I can send items via the bluetooth, but the Curve will not receive items via the bluetooth from either of the phones. I have been over and over the options allowing the Curve to "Trust" the other phones and allowing the Curve to be detectable. What am I missing? Or is there a problem with this feature on my new phone?
  • 2 more comments
  • vasuu Mar 16, 2009
    I have taken curve and a bluetooth headset along with it and i am not able to connect to the head set and m mobile is not able to find the head set and tht head set is found by other mobile.What shall i do???
  • Anonymous Apr 16, 2009
    can't pair blackberry 8310 with bluetooth
  • Anonymous May 03, 2009
    I have a Blackberry Curve and Motorolla Bluetooth. My Curve can not find my Bluetooth so I can not add it as a device. Why not? I was able to pair the Motorolla with the Blackberry Pearl.
  • Tim Babcock
    Tim Babcock May 11, 2010
    What is the make and model of the headset you are using?
    Problem Solver:
  • 10 Answers
Try the following. Hope this helps.
Okay,
1. Go into "Media" on your BlackBerry and enable incoming files (Menu-->Receive using bluetooth).
2. Find the file on your friend's device that you wish to send, and beam the said file accordingly.
2a. If you have not "paired" (created a friendship between) the two devices before, you will need to do this first...
2b. One of the devices will ask for a PIN code first and on this device you need to create a four-digit, numeric password that can be anything you like.
2c. On the second device, enter the four-digit, numeric password you created and follow the simple, on-screen prompts on both devices to complete the pairing (you can also pair the devices in advance by going into Menu-->Set Up Bluetooth).
2d. Depending on the devices being used and the time taken to complete the pairing, you may need to re-send the file (go back to step 1), otherwise, continue below...
3. When your friend's device tries to send you the file, your BlackBerry should ask you to name the file and where to save it; if you have not set the device as "trusted" in the bluetooth settings (Options-->Bluetooth-->your friend's device), you may need to approve the file transfer first though.
4. The file should now be on your device.
Note: by default, all
* Pictures are saved into /Device Memory/home/user/pictures or /Media Card/BlackBerry/pictures if you have a memory card.
* Sounds (including songs) are saved into /Device Memory/home/user/ringtones/ or /Media Card/BlackBerry/ringtones/ if you have a memory card.
* Videos are saved /Device Memory/home/user/videos or /Media Card/BlackBerry/videos if you have a memory card.
In other words, unless you specify somewhere else in step 3, this is where you will find your file.
And remember, your incoming file transfer WILL NOT WORK UNLESS YOU FIRST "PAIR" (CREATE A FRIENDSHIP BETWEEN) THE DEVICES, go into Media and CLICK MENU-->RECEIVE USING BLUETOOTH!!!
Posted on Jan 28, 2009
  • rykerho Aug 05, 2011
    ive been searching to solve my blackberry bluetooth issue and this the easiest and yet very helpful ...thank you so much durrtech1...highly recommended..
  • Jonah May 24, 2013
    It works for me Thanks!
I bought a used Blackberry Curve 8900 recently and have tried to pair it with my BT112 Bluetooth Headset without success. The BT112 has successfully paired up with my Blackberry Pearl and my Blackberry Tour in the recent past, so I know that it is working properly. The Curve can't detect the BT112 and the pairing signal from the BT112 does not seem to connect to the Curve. The Bluetooth is enabled on my Curve. What do I need to do now?
Posted on Apr 18, 2011
    New Friend:
It works for me thanks!
Posted on May 24, 2013
I cant receive anythin om my bluetooth yet i can send,,,my device cant be paired
Hi,the BlackBerry Pearl is a versatile mobile phone. It's primarily a Smartphone that's suitable for business use but it's also equipped with some decent entertainment features. The pearl can also play music files which you can enjoy with the help of a hands free Bluetooth headset. Let me teach you how to pair a Blackberry Pearl Smartphone to a Bluetooth headset.
Things You'll Need:
* Blackberry Pearl Smartphone
* Bluetooth headset
Turn on your Bluetooth headset by pressing and holding the multifunction button.
Check if the LED light is a solid blue. Turn off the headset and repeat the first step if the light is blinking.
Activate the Bluetooth wireless connection on your BlackBerry Pearl by Going into your "Settings" menu
Select the "Options" menu to go to your connectivity settings
Click on the "Bluetooth" option to activate the connection
Choose the "Add Device" option on your BlackBerry Pearl to locate the headset
Wait for a while as your Smartphone locates the Bluetooth headset
Enter 0000 for the password after selecting the headset to complete the Bluetooth pairing process
After that, your Done !!!!you can now send and receive. But after following this instruction and no solution yet, that means there is something wrong with your blue tooth. Corrupted. You will need to reset the phone.
Mar 11, 2011 | RIM BlackBerry Pearl 8120 Cellular Phone
I cannot pair my blackberry curve 3G with my Wireless Nokia headset BH-503! It was working until I paired it with another nokia 2700 and after trying to pair it with my blackberry curve 3G again, it...
It is paired with the Nokia 2700.
From the manual (Click here to get it) page 11;
To clear the pairing and volume settings, switch off the headset and press and hold the multifunction key and press the volume up key until the indicator light alternates red, green and blue three times.
Feb 05, 2011 | Nokia BH-503 Bluetooth Headset
Cannot connect my blackberry tour to my mercedes bluetooth program. its is asking for a passkey which i do not have
BLACKBERRY PRODUCT
BlackBerry Bold 9700 ...............$350
BlackBerry Storm2 9520 ............$320
BlackBerry Curve 8520...............$300
Blackberry Tour 9630 ................$250
Blackberry Curve 8900...............$230
Blackberry Storm 9530 ..............$230
Blackberry Storm 9500 ..............$250
Blackberry Pearl Flip 8220 .........$200
Blackberry Bold 9000.................$240
Blackberry Pearl 8110................$230
Blackberry Pearl 8120.................$215
Blackberry Curve 8320...............$180
Blackberry 8830 World Edition ...$180
Blackberry 8100 Pearl ...............$180
Blackberry 8300 Curve .............$170
Blackberry 8800 .......................$165
Blackberry 8820 ...................... $160
Contact: Mr. Randy Barnett
Email: isell.seitz@gmail.com
Email: isellfast198@yahoo.com
Nov 10, 2009 | RIM BlackBerry? Tour 9630 Smartphone
Blackberry Curve 8330 can not find my bluetooth headset
Turn the 360 off.
Then turn Bluetooth off, then back on the Curve.
Then turn the 360 back on, input the code when asked to due so.
Jul 23, 2009 | RIM BlackBerry Curve 8310 Smartphone
Igave been using my Verizon Jabra VBT185Z
where can I find the setting on my Blackberry Curve to pair my Jabra VBT185z
Jun 20, 2009 | Jabra BT350 Bluetooth Headset Headset
I want to pair with another device, a blackberry curve
I have a Blackberry curve and i use this headset. You just hold in the key to your bluetooth till it stays solid blue light, then go on your blackberry under "options" then "bluetooth" then search or add new device. it will search it, pascode is "0000" should load up then. then everytime u put ur bluetooth on and hit the button to turn it on ur blackberry will pop up and ask if you want to use it, just hit yes and your good to go.
Mike
Jun 12, 2009 | Motorola Mobility H300 Wireless Headset
Motorola hs850 bluetooth headset won't pair with Blackberry Curve
try to delete it out of ur phone all the way and then try to pair it again
Dec 15, 2008 | Motorola Mobility HS850 Consumer Headset
I can't pair my Motorola H700 to my Blackberry curve.
http://khaoohs.wordpress.com/2007/11/16/motorola-h700-bluetooth-blackberry-pairing/
this actually works.
Aug 09, 2008 | Motorola Mobility H700 Wireless Headset
H500 won't pair with Blackberry Curve
It might already have been figured out but if you hold the answer button on the headset down until the light stays on steady, it is in pairing mode. You can then go to bluetooth setup on the Curve and it will find the headset.
Nov 08, 2007 | Motorola Mobility H500 Wireless Headset
RIM BlackBerry Curve 8310 Smartphone Logo
5,516 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
David
Martin Murray
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
