Question about Dell 1700n Laser Printer
Dell 1700n margins shifted to the right..paper tray is ok....?
Help, my margins have shifted to the right. The paper in the tray is just fine and the holders in the tray are set just right. Please help!
  • 624 Answers
SOURCE: Dell 1700n Laser Printer paper jams
Some questions first: -Where in the paper path is it jamming? -Is it always in the same spot or does it vary? -Roughly how many pages have you printed with this printer? -Did anything lead up to this or has it progressively gotten worse?
Posted on Feb 21, 2007
SOURCE: Dell 1700N
We had a printer with the same problem, and turning the pickup wheels inside out (on the back of the paper tray) solved the problem.
Hope this helps.
Posted on Feb 11, 2008
SOURCE: Dell 1700n: Paper Loaded, Light still on, will not print
It sounds like the feeder wheels are going out. If you pull out your tray and look up underneath you will see a set of rubber wheels. THey are supposed to lower and feed the paper. I am sure they are still rolling but not lowering all the time. Mine are out completely, can still print by feeding a sheet at a time in the front load slot.
Posted on Jul 06, 2008
SOURCE: Dell 1700n Jamming
Rotating the rubber worked perfecty, thanks!
Posted on Sep 02, 2008
  • 53 Answers
SOURCE: DELL Laser printer 1700/1700n
All flashing lights for the Dell 1700 series (1700, 1710, 1720 including those that have n or dn as part of the model) printers is a service related error. When double pressing the continue button twice quickly, the printer will give a secondary error code, narrowing down the printer part being effected. It is possible to even narrow the error code down even futher by double pressing the continue button and taking note of which combination of lights come on, wether they are steady or blinking. Most generally when this series of printers, when you get all flashing lights, something major is going on with the printer. It could be pointing to the fuser, or main board, etc. You can call dell warranty support and they will help narrow down which part is being effected. Most generally, what is being effected is not cost effective to get fixed if you are no longer under warranty.
Posted on Apr 27, 2009
My printer is leaving toner "tire marks" up and down the right and left side of the page margin as well as spilling uneven blotches of toner along the right side of the paper.
Your printer needs cleaning. Consult your printer manual on how to clean it. If you do not have the manual, you can usually download it from the printer manufacturer's website.
Apr 23, 2010 | Dell 1700n Laser Printer
Paper won't pull from the paper bin
ROLLER MAYBE HAVE OIL FROM HUMANS OR OTHER TYPE OF PAPER PRODUCTS,
TRY A DIFFERENT TYPE OF PAPER
MAKE SURE THE PAPER TRAY IS IN PROPERLY,
PAPER HAS MAXIMUM #'S OF SHEETS OF PAPER,
COPIER NEEDS TO BE SERVICED AND ADJUSTMENTS NEED TO BE MADE ON THE PICKUP TRAY, SERVICE TECHN WILL KNOW WHAT TO DO TO FIX THE ISSUES TO THE MACHINE.
ROD
Feb 05, 2009 | Dell 1700n Laser Printer
Printer problem -Dell Laser printer model 1700.
make sure the side guides in your paper tray are tight against the paper.
Dec 19, 2008 | Dell 1700n Laser Printer
Printer size small
Go to printer preferences and settings and put the right setting there.
Also in your document check the margins and print preview
Oct 13, 2008 | Dell 1700n Laser Printer
Paper jam
There is a sensor in the back that lets the printer know the paper has exited the fuser. It is probably broken off if paper is getting stuck back there.
Also check for paper remnants that are jammed. This may require removal of the fuser.
Mar 13, 2008 | Dell 1700n Laser Printer
Printing size and shifting to the right
Hi there check the print margins within MS Word goto
  1. File
  2. Page Setup
  3. Margins
And check that they are OK. if not check that you haven't got the wrong size paper set in word. Same as above but select Paper size then check in the printer driver that you have the correct paper size selected and that you haven't selected a strange margin.
Hope this works
Thanks J
Nov 28, 2007 | HP DeskJet 5650 InkJet Printer
Margin problem???
I can just guess it has to do with the paper being fed. either you have the paper wrong or the paper settings to a different size then the actual dimensions of your print material.
Oct 24, 2007 | Dell 3100cn Laser Printer
Dell 1700N
Hope this helps.
Oct 19, 2007 | Dell 1700n Laser Printer
Dell 1700n paper jam
Most larger printers like yours have an optical sensor that needs to have the paper pass by in order for it to send the "sent" signal. If the paper doesn't trigger that you get the paper jam error. look at this page http://www.fixyourownprinter.com/forums/laser/47953#1 it will tell you what and where to check for your problem. It has photos and videos. I hope this helps some.
Sep 29, 2007 | Dell 1700n Laser Printer
Dell 1700n Laser Printer Logo
83 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
