Question about Kenmore 64254 / 64252 / 64259 Top Freezer Refrigerator
I have a Kenmore refrigerator/freezer. Model is 106 71192100. I just noticed a fair amount of ice build up on the back wall of the freezer unit. What could be causing this?
  • 93 Answers
Your defrost timer is not working repkace timer cost about 20.00 look at back bottom some on upper top ofin fresh food compartment near the light thanks from gilles
Posted on Mar 15, 2009
Kenmore model 795.71022.010 water builds up in the bottom of the freezer every two weeks I have to defrost the unit and remove the ice build up if I dont the door wont close
The fan unit behind the wall inside the freezer may have frozen over.
Even though you see no ice inside the shell of the freezer, it can still have blocks of ice behind the back wall.
So remove the 3-4 screws holding the back wall, remove it and check on the ice there.
Make sure it is completely defrosted or ice melted before reconnecting. Leave the wall off while you connect it to make sure the small fan is kicking in.
IF the fan does not kick in. you can get a replacement for $15-$20 at any fridge parts supply house. It is easy to disconnect and reconnect.
Jun 04, 2016 | Kenmore Refrigerators
Kenmore bottom freezer refrigerator warming up
Hi
There is a definetely leak in the cooling gas.
Firstly... You will need to find from where the gas has leaked. It is usually on the compressor pipes..... but not always.
Secondly you are right about the Water Valve... it needs to be changed.
Regards
Berry
Feb 02, 2010 | Kenmore 73502 / 73504 / 73509 Bottom...
Ice continues to build up behind the back wall of the freezer and the vents on the back wall of the freezer and it blocks the cold air from getting to the refrigerator. I have to defrost it every two...
You obviously have a defrost problem. There are 3 components. Defrost heater, defrost thermostat, and defrost timer or board depending on model. One or more of those are defective
Nov 02, 2017 | Kenmore Refrigerators
Kenmore elite fridge. Bottom freezer ice builds
You have a bad defrost system on this unit, that's why you're freezing up. Call us with the model number and we'll get the correct part out to you right away. We hope to hear back from you soon.
Oct 09, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
My Kenmore freezer won't make ice. I can feel a
water supply must be checked first, constant flow to the area confirmed. compreesor running? does the system reach temp in other compartments? Isolate system from the electrical supply pull away from the wall and clean behined unit clean coils and fan blades.
check tube for water still connected and return unit power supply. let me know what you have temp in fridge and freezer if this unit is duo.
Jun 24, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Ice on back wall but not freezing food and rattle noise. Moved all food to other freezer
This is a fairly common problem with these types of refrigerators. The design is set to defrost every 12 hours and be down for 1 hour to allow ice to melt on coils. More often than not the ice never fully melts and creates a blockage in the coils and in turn slows air flow. You can remove the screws in the back wall of freezer unit and unsnap the ice maker plug to allow access to the coil. Gently tilt the back plate forward. You can then unplug the ref. and help it thaw with a blow drier. If you are not comfortable removing the back plate then you can just unplug the ref. and let it thaw on its own. this may take a while. try to remove as much ice as you can from the back of the freezer wall by hand and prop the door open for a couple of hours to ensure that all the ice melts. The rattling sound you are hearing is the fan blades hitting the ice that is built up around it. As a precaution I recommend that these type of refrigerators get manual defrost simply by unplugging about once a month for about two (2) hours. I hope that this will help you out with the melted ice cream. Good luck.
May 30, 2009 | Kenmore Refrigerators
Kenmore Side by side Model #53271... not cold
you have a defrost problem in the freezer,it is one or more of 4 things,freezer fan,defrost timer,defrost bimetal switch or defrost heater,check all until you find your bad part-mike
Jan 07, 2009 | Kenmore 53262 / 53264 / 53269 Side by Side...
Freezer not cold, the meat is melted
Sounds like you have a defrost problem. Pull the back panel off inside of the freezer and make sure the fan is running (evaporator fan motor). If it is, check the defrost heater and defrost thermostat for continuity. If one is bad, you have found your problem. If both are good, replace the defrost timer, adaptive defrost board, or main control board (I'm not sure which you have since I don't have your model number). Let me know if I can be of further assistance.
Mar 27, 2008 | Kenmore 53542 / 53544 Side by Side...
Water leaking onto floor
unplug it again , sounds like your drain line has frozen, instaead of defrost water going down the tube and under refrig in drain pan, becuse tube is frozen its draining into freezer compartment and eventually spilling out through front of unit. totally defrost unit and behind back wall of freezer youll see a metal trough designed to catch water, in the center (under the ice is gonna be the drain hole, pour boiling water down until it runs freely
Feb 23, 2008 | Kenmore 71279 Bottom Freezer Refrigerator
Refrigerator Not Making Ice, Frost in Freezer and Refrigerator Not Cold
It has a defrost problem.  Most likely cause would be the defrost thermostat which clips onto the evaporator behind the back panel in the freezer.  Next most common would be the defrost timer.  Third would be the defrost heater.  Let me know if you want to try to test these parts.  If so I will need the entire model # from the sticker in the fridge or on older models on a plate at the bottom front below the door.
Oct 10, 2007 | Kenmore 53542 / 53544 Side by Side...
Kenmore 64254 / 64252 / 64259 Top Freezer Refrigerator Logo
423 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
