Apple iBook Mac Notebook Logo
eldon_gemini chua Posted on Jul 25, 2007
Cant turn on
Last night i used my mac ibook i used the wi-fi and then when im already through i press the power button then it appears a message saying that "are you sure you want to shutdown?" then i press yes. then the other day i want to used my mac again i turned it on but it seems that it doesnt turned on. anyone can help me what seems to be the problem? i already fully charged the battery but there seems to be no solution. i removed the battery and wait for about an hour and insert it again but it wont work to.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jan 12, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
315
Points
If you have the problem with no chime, no screen light up, and fans at max, it may be possible to fix it. It is often a design flaw in the soldering process.
Press firmly down on the left of the mouse pad when you press the power button (or try holding it in your left hand with your thumb by the touch mouse and fingers under the mac pressing firmly on the bottom) if it chimes. or even boots when this is done you can find a shop that does soldering(micro soldering) and have them fix the chip thats lose. Or for a quick fix try this site http://www.coreyarnold.org/ibook/ he shows the most common chip that comes lose.
All but 3 or 4 failed iBook's that had the fans start and nothing else, seem to have this problem(that I've seen) but Mac refuses to say it's a defect in all country's but Denmark (because a official study was done there that proved it was a manufacturers defect that each time you power on/off the iBook the solder gets a little looser.)
Anonymous
Level 1:
  • Posted on Mar 12, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
315
Points
My iBook decided to (most of the time) not start, and then when it did start up, it would shut down at random intervals. I tried all the various key sequences, tried starting up with the battery, without the battery, all with no success.
There was only one tip that I stumbled upon (can't remember where or who the poster was--many thanks to them!) that did work.
1. Unplug the power adapter from the iBook. 2. Remove its battery. 3. Let it sit for 1/2 an hour to an hour. 4. Press the power button several times, as if you're actually trying to start up the iBook. Make sure you do this WITHOUT the battery and WITHOUT the power adapter! (Yes, I know there's no power source and it won't actually start.) 5. Replace the power adapter. Try to start the iBook with only the power adapter and no battery. If this works, then replace the battery as well.
From what I remember, what step #4 is supposed to do is drain all residual power (from capacitors maybe?) from the circuitry and forces the power management circuitry to reset itself. There's a key sequence that's supposed to reset the power management circuitry as well, but it didn't work for me (no matter how many times I tried it). My iBook now starts every time with no fuss.
I hope this helps someone out there!
Anonymous
Level 1:
  • Posted on Jul 28, 2007
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
315
Points
I had the same problem. Did the fan turn on after about 5 seconds at full power? If so it is a logic board problem and will cost ~$300 to fix if out of warranty. If you paid with a credit card check to see if they offer extended warranty coverage. Thank god mine did, so i should be getting mine fixed. Good Luck.
Anonymous
Level 1:
  • Contributor 3 Answers
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
760
Points
Try these in no particular order (except last 3) try command-option power this puts p-books to sleep (may trigger it to wake) (it could be asleep) Remove your battery and wait 5-10 mins then try to start up with battery in Remove your battery and wait 5-10 mins then try to start up with battery removed To zap PRAM On startup hold down the cmd, option, p and r buttons Hold till you hear boot up sound To zap NV RAM On startup hold down the cmd, option, n and v buttons Hold till you hear boot up sound To reset the screen on a powerbook: On startup hold down the r button - To force internal Hard drive to be startup disk On startup hold down the r button - until boot Disable extensions: Try power up-reboot with shift key down Last but not least try to startup with original MAC system startup CD If all else fails try to get to an Apple Store...unless it's a real hardware problem (fried circuits/damage they'll fix it for free!) Pray - believe it or not... it worked for me when I got down on my knees and prayed. Hope this helps
How do i get my mac or wifi number
Please follow these instructions to find the MAC Address of your Android phone or tablet:
  1. Press the Home button at the bottom of the phone.
  2. Press the Menu button.
  3. Tap Settings.
  4. Tap Wireless & Networks.
  5. If Wi-Fi is not already selected, tap Wi-Fi to turn it on.
  6. Press the Back button.
  7. Tap About Phone.
  8. Tap Status.
tip
How to set up internet on Samsung Jet
Ensure that you have the appropriate network key code needed to enable you to access a secure Wi-Fi network.
If you are connecting to a secure Wi-Fi network with MAC address restrictions, you will require pre-authorisation for the router. You will need to find your Samsung Jet's MAC (Media Access Control) address. This is a 12-character code which may be needed by the network controller to enable the phone to connect. See Getting the Samsung Jet's MAC address below.
You can get to the Wi-Fi application either via the main menu or using a homescreen Wi-Fi Widget.
  1. To get to the Wi-Fi application via the main menu, press the MENU button (either on the home screen or the hexagonal button beneath)
  2. In the main menu, swipe your finger sideways to go through the menu pages until you see the Wi-Fi icon. Press to select.
  3. The Wi-Fi application opens.
  4. Alternatively, to use the Wi-Fi Widget, from standby, press the home screen. The Widget toolbar opens up.
  5. Scroll down to find the Wi-Fi Widget icon. Press the Wi-Fi Widget. The Wi-Fi Widget will pop up on the main screen.
  6. Press the Wi-Fi Widget on the main part of the display to launch the Wi-Fi application. The Wi-Fi application opens.
  7. Once in the Wi-Fi screen, press the large Wi-Fi button in the middle of the screen to turn it on. Wi-Fi is activated and the button turns blue.
  8. Press SEARCH Nearby Wi-Fi access points (APs) will appear as small circles on the display, with their names next to them.
  9. Press the circle representing the Wi-Fi Netowrk you want to connect to. An options panel appears.
  10. You can press CONNECT to connect to the network or press ADD if you want to add it to a list of preferred networks for easy access later.
  11. You are taken into a settings menu for the Wi-Fi access point. If the Wi-Fi access point requires a network key code, scroll down to the Network Key panel. Press to select.
  12. The numberpad appears. Type in the network key code and press DONE. You are returned to the previous settings screen. Press SAVE
  13. A list of connections appears. Press the back arrow button
  14. If you initially pressed CONNECT, the phone will connect to the selected Wi-Fi network and a confirmation message will appear. The display now shows the new connection, illustrated by blue dots linking the circles onscreen (Figure 15).
  15. If you initially pressed ADD, you will be returned to the Wi-Fi screen. Press the circle representing the Wi-Fi network you want to connect to. A pop up panel appears.
  16. Press CONNECT. You will be connected and the connection illustrated onscreen.
Press the back button to return to the home screen.
  1. From the home screen press MENU to enter the main menu (Figure 1).
  2. In the main menu, press INTERNET
  3. Choose which browser option you want (Home, Enter URL, Bookmarks, etc.) (Figure 18) and press to select. If you press Home you will be taken to the pre-loaded home page.
  4. If required, use the numberpad to type in an URL or scroll a list to select bookmarks. When an URL is completed press GO. Alternatively press the bookmark you wish to access. You will taken to the web page requested.
  1. Activate Wi-Fi and press SEARCH, as before.
  2. When the Wi-Fi access point you want to connect to appears on the display (Figure 8), press it to select.
  3. A pop up options panel appears (Figure 9). Press DETAILS
  4. Details of the Wi-Fi access point appear onscreen.
  5. Scroll down by dragging your finger up the screen. Towards the bottom of the settings list, DEVICE MAC appears, with a string of 12 charactesr beneath (Figure 21). Each handset has an individual MAC address, and this panel will display your Samsung Jet's unique Mac address.
Make a note of the MAC address. You will need it if you want to use the Samsung Jet's Wi-Fi to access a secure Wi-Fi network using MAC address restrictions. This can be added into the wireless router settings access list.
2answers
My toshiba tablet wont connect to my wi-fi please help
1. Make sure that your wi-fi settings are turned on.
2. Scan for local wi-fi
3. Select your desired wi-fi and provide password if required.
Many times, the settings from the menu are not turned on, so the tablet will not try to link to a wi-fi site.
If you need more help, please provide the model number and the operating system currently being used on the tablet.
How do i find the mac address
    Follow these instructions to find the MAC Address of your Android phone or tablet:
    • Press the Home button at the bottom of the phone.
    • Press the Menu button.
    • Tap Settings.
    • Tap Wireless & Networks.
    • If Wi-Fi is not already selected, tap Wi-Fi to turn it on.
    • Press the Back button.
    • Tap About Phone.
    • Tap Status.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/dave_fb2c45146b845cea
Describe your cannot start ibook G3Problem it simply does not start, battery is ok and I have tried to take the battery away and back in its place, but nothing what can I do?
Make sure your iBook is plugged in to the wall. Hold down the power button for a few seconds. If that doesn't work, try holding down Command (the Apple key)-Option-P-R (hold all four keys down) and press the power button. Be sure to hold the power button for a few seconds whenever you turn it on.
If that doesn't work, try resetting the Power Management Unit (PMU). This is kind of a "last resort," according to Apple. Don't do this all the time.
  1. Reset the power manager by simultaneously pressing and then releasing Shift-Control-Option-Power on the keyboard. Do not press the fn (Function) key while using this combination of keystrokes.
  2. Wait 5 seconds.
  3. Press the Power button to restart the iBook computer.
If you have a very old iBook, you may have to unplug your iBook, remove the battery, and
  1. Press and release the reset button located above the Audio/Video port on the left side of the iBook (Dual USB) computer by inserting the end of a paper clip into the small hole and gently pressing the switch once.
  2. Wait 5 seconds.
  3. Reconnect the AC power adapter.
  4. Put the battery back in the computer.
  5. Press the Power button to restart the iBook computer.
(If it still doesn't start, do you hear the fans going?)
Good luck! Let us know if these steps solve your issue.
* If you find this information helpful, please rate my solutions and recommend me. Thanks! *
I cant connect my dell latitude d531 to the internet
Press the button just to the left of the power button (when mine turns on the bluetooth light appears just below the screen on the right side). See if it works now. If not, reboot, press the F2 key during startup (keep tapping until the message in the upper right goes to "Preparing to enter setup") to go into Setup. Go to the bottom of the list on the left side to Wireless. Hit enter to open the list, go down to Internal Wi-Fi and make sure it is enabled on the right side of the screen. Also, check the last setting and set LAN/Wi-Fi Auto Switch to Off. You might also have a bad wireless card or a bad driver. If nothing works then re-post as possible driver problem.
I purchased a new IPOD and I can not access the wifi from my Linksys wireless router.. I reset my Linksys router to try to solve this problem. And at first when the light was amber I was able to have...
Resolution If you know there is a nearby Wi-Fi network, but you are unable to locate it on the Settings > Wi-Fi screen:
  • Move closer to the Wi-Fi router or hotspot.
  • If you are using a personal Wi-Fi network, verify the Wi-Fi router is connected to power and turned on.
  • Wi-Fi networks configured as "closed" or "private" do not broadcast the network name to Wi-Fi devices.
    • Join a "closed" or "private" network by tapping Settings > Wi-Fi > Other and entering the Wi-Fi network name, security, and password.
After joining a Wi-Fi network, if you notice the signal strength is low or intermittent
  • Check for any sources of potential interference.
  • Remove any cases or attachments on your device that could interfere with a Wi-Fi signal.
If you are unable to access the Internet while connected
  • If you are using a commercial Wi-Fi network that requires a special login or subscription, see this article for more information.
  • If you are in a location with multiple Wi-Fi networks, verify that you are selecting the correct network.
  • Verify that the Wi-Fi network settings are correct:
    • Tap Settings > Wi-Fi.
  • You can configure network-specific settings, including IP address, DNS, and Search Domain settings.
  • Use "Forget this Network" to reset settings for this particular Wi-Fi network, including the password. This is also useful if you identify a network issue and want to prevent the device from automatically using this network in the future.
  • Use "Renew Lease" to acquire new IP address, DNS, and Search Domain information from the Wi-Fi network.
  • Note: If the Wi-Fi network uses MAC address filtering, you will need to add the MAC address to the access list for the Wi-Fi router. The MAC address for your device is listed as the Wi-Fi Address in Settings > General > About.
If you are still unable to join a Wi-Fi network, or are unable to access the Internet while connected, try the following
  • Restart the device
    • Hold the power button until "slide to power off" appears. Slide to power off your device. When it is off, press the power button to turn it back on.
  • Reset network settings by selecting Settings > General > Reset > Reset Network Settings. Note: This will reset all network settings, including passwords, VPN, and APN settings.
  • iPhone only: If you continue to experience issues, consider turning off Wi-Fi and using the cellular data connection instead of Wi-Fi.
Additional Information If using a Wi-Fi router at home, refer to your user manual/documentation to assist you with some of these suggestions.
  • Check the manufacturer's website for your Wi-Fi router for firmware or software updates.
  • Verify the Wi-Fi router can broadcast an 802.11b/g signal. If using a 802.11n Wi-Fi router, consult the manual/documentation for how to configure the Wi-Fi router for 802.11b/g compatibility.
  • If you are using multiple WEP keys on your Wi-Fi router, try configuring your Wi-Fi router to use only a single WEP key.
  • Try or resetting (or turning off and then on again) your Wi-Fi router. Note: If your ISP also provides cable or phone service, check with them before attempting this step to avoid interruption of service.
  • Disable wireless encryption or security on the Wi-Fi router to rule out encryption issues. If this resolves the issue, try using a different encryption or security protocol.
Hello- I have a ibook G3 running 10.3.9 and the wireless connection stopped. I changed out the air card, still nothing. Could this be a firmware issue, or a bigger hardware problem?
Try disconnecting the air card and pushing the wire back on it firmly.  Click on the wi/fi and type in your password.  Could be the little wire for wi/fi is broke.  Check Apple web site for updated drivers.  Update your OS to Tiger 10.4.11 if you got a new modem.
Dead sleep
happened to us many times, the sleep to death error
logic board problem. buy a new mac realy.
try this, reset prom
take out the power cord. press hold the power button
and plug the power then takeoff power button and press it again.
try this, press hold P and I and power on
Ibook G3 will not start
If you stilll have the Mac OS installation CD available the when it is starting up press down C and it will start from the Mac OS X installation Set up then you can reinstall OS X and it should work.
Top Apple Computers & Internet Experts
Paul Carew
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
