I turn it on, put in the dvd, then it just says ''loading'' Eventually it says no disk. It worked fine last week! Any ideas?
SOURCE: Insignia dvd player will not load. error messages:
could be dirty laser, try a laser cleaning cd,you should get a little bottle with alcohol in to put on the little brushes, if that doesn't work could be the laser has given up the ghost
SOURCE: dvd player won't load disk
The only troubleshooting you can try is to unplug the unit for 30 minutes. If the problem persists, the unit needs to be repaired. If you're under warranty, the manufacturer will repair or replace the unit. If you're out of warranty, they may have an out of warranty exchange or repair program.
I hope I've provided you useful assistance and that this information
allows you to make an informed decision as to how to proceed from
here. Please be sure to vote on my response. I hope I've earned a
good rating from you today.
Please post a comment if you need
additional assistance so that I can help you further.
SOURCE: Advent ADV35 dvd player disk wouldn't eject, now won't load
Hello there:
I would first check to see if eye is not scratched or dirty and clean it if nesassary..
If you unplug the unit for a few minutes it should reset it's self.ok
and good luck on the drive i am a retired navy vet and know what you are going thru with the move.
best regards michael
(USN RETIRED)
Testimonial: "Thanks!"
SOURCE: Honda Odyssey 2006 DVD player says loading, disk in light on, and
pulled the fuse and left it out for over an hour. The system reset itself when turn back on.
SOURCE: Toshiba sd-4990 dvd player will not load a disk
Your toshiba is not spinning that's why it keeps on saying loading. Unplug the dvd Open the device,once open plugin the dvd and put the dvd cleaner in the player. take your finger on the top where the dvd disk is and spin the disk. What happening is that you are cleaning the len. keep spinning until it spin on its own.Put the toshiba top back on and clean again. It should clean on it's on. Now you can play your dvd. Clean your dvd on a regular basic.
player will not read dvd
I have had this problem from one day past the warrenty experation.
Will not read disk. Opened up the unit, disk doesn't spin. Spun up the disk manually, spindle motor can almost keep it going..but eventually slows. Motor driver IC gets quite warm. trying to decide if motor driver IC is the problem or the spindle motor. Am now looking for replacement spindle motor price to decide if unit is worth repairing. BTW: disk carriage and associated mechanisms is made by sony (in the suffex C unit anyway).
