I need a pin out for Aopen mx4ge motherboard
The motherboard was taken out without labeling the pin for the connectors. I need a pin out and socket print out
  • jwgriffin Jan 29, 2009
    Thanks for your information. I was able to get the manual and I am sure that I will use you in the future.
    James Griffin
    Problem Solver:
  • 13 Answers
The following link is a download to the Users Guide for the MX4GE. I look at the manual and under the install section it has the pin outs for the front panel connectors.
Hope this helps.
Posted on Jan 28, 2009
I believe you're referring to the AOpen MX46-533V
The Front Panel USB header is Blue in color, and located in-between the white No.3 PCI expansion slot, and bottom edge of the motherboard;
With the motherboard in the installed position;
5 pins across the Top row, 4 pins across the Bottom row.
Pins across the Top row are numbered EVEN
Pins across the Bottom row are numbered ODD
Starting on the Left side coming across to the Right, Top row;
Pins 2, 4, 6, 8, and 10
Bottom row;
Pins 1, 3, 5, and 7
There are TWO USB connectors supported off of this USB front panel header.
For one of the USB front panel connectors;
A) Pin 1 is USB PWR 0
Goes to the VCC contact pin on the USB connector.
B) Pin 3 is USB_FP_P0-
Goes to the D- pin on the USB connector.
(Data - )
C) Pin 5 is USB_FP_P0+
Goes to the D+ pin on the USB connector
(Data +)
D) Pin 7 is Ground (GND)
Goes to the Ground (GND) pin on the USB connector
E) No pin 9
F) Pin 2 is USB PWR 0
For the other Front Panel USB connector;
A) Pin 2 is USB PWR 0
Goes to the VCC pin on the USB connector
B) Pin 4 is USB_FP_P1-
C) Pin 6 is USB FP P1+
D) Pin 8 is GND
E) Pin 8 is USB_FP_OC0
Leave unconnected
This is more information on a standard USB connector pinout,
( A USB connector, and a USB plug are not wired the same.
The plug is wired backwards from what a connector is.
Otherwise you would have power and signal going to the wrong pins, and burn the USB Front Panel header out on the motherboard )
AOpen MX46-533V motherboard manual, but it is in Japanese.
May be one in English out there.
The Front Panel header pinout, USB header pinout, etc, is easily cross identified,
Manual / Japanese manual for MX46533V / Japanese / 1/28/2006
Go to the far right, and click on the Floppy Drive icon above -
3701.1 KB
On the next page click on the mirror server website that is closest to your country.
This is a PDF file.
The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the country server name it may take up to 30 seconds, before the first page comes up.
(File is downloading in background)
For additional questions please post in a Comment.
Oct 19, 2012 | ASUS P5PE-VM Motherboard
I have got a system with an Aopen motherboard which having only a 20 pin connector for smps connectivity. the Atx smps i have is is 24 pinned. i can connect the main line by splitting up the 24pin...
The actual Processor fan connects to the CPU Fan header on the mainboard. It's 4 small pins. It plugs in right near the CPU socket on the mainboard. Check the user manual for exact placement, you may download it from the AOpen website if you don't have one already.
Plug in the 20Pin connector if that is the most Pins that the mainboard will allow. Cable tie the other 4Pins back onto the 20Pin connector.
Then if there is additional 4Pin connector required by the mainboard for CPU power and you don't have that connector on you power supply, you will need to purchase a Molex to 4Pin CPU power connector. When you go to the computer store check with them that all is correctly connected.
Take care!
May 25, 2011 | AOpen MX4GER Motherboard
I am wondering if I can put a Intel Pentium 4 Processor 3.20 GHz, 512K Cache, 800 MHz FSB into a AOPEN MX4GE motherboard, the socket type is the same but I am not familiar with the FSB settings to...
I would guess not, but If you already have them both, then try it. If not then I'd get a cpu or motherboard to match the other. I once got a 2.8ghz p4 and wanted to swap it for a 3.2ghz I had lying around, quickest way was to try it out, it didn't work so I swapped them back and put the 3ghz in another pc later on, both still worked perfectly.
Feb 04, 2011 | AOpen MX4GE Motherboard
Woule like the pin location for power & leds on F-P1 socket
The corner of the motherboard "diagonally-opposite" of the keyboard/mouse PS/2-port connectors has a grid of gold pins. One pair of pins is labelled 'PWR'.
One pair of pins is labelled 'RST SW' ("Reset Switch").
Another pair of pins is labelled 'PWR LED'.
Another pair of pins is labelled 'HDD LED'.
Jan 10, 2011 | Computers & Internet
I need a schematic (pin-out)of the MX4-ge motherboard
You can download the manual for you're AOpen MX4GE motherboard from the link provided below;
You'll need Adobe reader installed to view the *.pdf file above.
Download Adobe @
Open manual to page 33. Here you'll see the layout for the front panel motherboard pins. The view towards the left shows where to connect the jumpers coming from the case to the motherboard. The view on the right shows where each positive wire and negative wire connects. The common colored wire for each jumper will be used as negative. Except for the internal speaker 4-pin jumper. Normally positive wire is red in color and ground is black in color and connects to pins 16 and 19 only. Pin 1 is shown. Pin 2 is to the right of pin 1. Pin three is below pin 1 ECT.
Mar 03, 2010 | GE AOpen AX4GE-N (NMBA0102) Motherboard
All are socket 478 and bus speed 400 to 533 intel chipset
the 2.2 celeron has socket 478 and bus speed of 400 so I believe they will be compatible
Jul 02, 2008 | Acer AOpen AX4BS-V (91.89J11.001)...
Missing CPU
AX4BS-v intel chipset pentium 4 sd ram
MX4GE socket 478 pentium 4
AX4B intel 845-d
hope this helps
Computers & Internet Logo
466 people viewed this question
David Payne
David Payne
