Question about Denon DVD-2500 DVD Player
No sound with Denon DVD-2500
I have a Denon AVR 3300 with a Denon DVD-2500. Both about 10 yrs old. When I try to play a DVD, I have video but now get no sound. If I turn the volume way up, I can hear faint sound--like program from somewhere--maybe the TV, but not the dvd.  I tried several discs, same result. Also tried the VCR and audio works fine, so I'm thinking it's the dvd player and not the amp. Suggestions?
  • Denon Master
  • 19,396 Answers
The "faint sound--like program from somewhere" is an interfeerence problem related to a bad shielded video cable.
Also the sound but no video is probably because of the cable.
Just replace the cable that connects from DVD to TV.
Posted on Feb 15, 2009
  • 4,806 Answers
Hi there
Check the audio jacks at the back of the unit to make sure that the phono leads are in the correct output source.
Also hook the DVD up to the TV using a standard scart lead to rule out the audio output on the DVD player itself.
Good luck and thanks for using Fixya!!
Posted on Feb 14, 2009
    Sergeant:
  • 250 Answers
As it was working properly before and now suddenly it has stopped giving sound fron dvds.thgis indicates as the unit is 10 year old it can be the problem of any thing got short in the circuit board which is making this problem of no sound/other wise the cables are either fauly or got looser or not connrected properly or the socket in which the cable is connected is got loose internally.just remove all the external cables connected to the unit and clean the cable pins and sockets  make them absolutely dust free.then reconnect every thing and check out. thanks.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Your post "but now get no sound" indicates that it was working before and just recently had the "no output audio" fault. It would be appreciated if you could pls post back/describe how the DVD 2500 is connected to the AVR 3300. Of particular interest would be which input of the AVR is used by the 2500.
Initially, you can try:
  • relocating the 2500 connection to any of the other inputs of the 3300;
  • play the 2500 with the 3300 either in 5-CH STEREO, MATRIX, STEREO or DIRECT but not DOLBY DIGITAL, DTS nor DOLBY PRO-LOGIC;
  • likewise, if possible do not use any of the DSP "effect" modes;
  • playing an ordinary audio CD on the 2500.
Pls post back result(s) of above tests. Good luck and thank you for using FixYa.
Posted on Feb 04, 2009
  • 104 Answers
Assuming you play the same DVD dics which were working fine before. When the sound gradually decrease and eventually no sound the cause is sound IC gone bad. YOu can change this chip in a local repairing shop.
Posted on Jan 28, 2009
  • 41 Answers
Hello ther it sounds like the onboard sound card has gone in the player i had 1 for about 4 years and mine did exactly the same i took it to a local repair shop and they told me that the sound chip was fried hope this helps many thanx
  • 10,594 Answers
I think your DVD disc has DTS system in sound and your sound system is 10 years old so could not process its sound.
You will get good sound if you play Dolby Pro Logic DVD disc.
  • Shahid Electronics
    Shahid Electronics Feb 14, 2009
    Please check dvd audio connections as is it optical cable or RCA cable used.
    You can confirm sound connection by playing an Audio CD in same player.
My Denon dvd-2910 does not play 5.1. It is connected to Denon AVR-3805. It plays just stereo. The center, back channels and subwoofer don't give any sound
Your Denon DVD-2910 produces left and right audio output. Your Denon AVR-3805 generates 5.1 channel output; therefore, 5.1 channel output may not have been selected or the AVR-3805 may be defective.
Jan 29, 2017 | Denon DVD-2910 DVD Player
I have a Denon AVR 1707 reciever. I am trying to connect my dvd player through RGB cables. The sound works just fine when i turn the reciever to dvd but there is no video. I have the component 2 set to dvd...
The video cables--the green, blue, and red ones must be connected from the video OUT portion of the DVD player to the Component 2 video IN of the Denon. It could be the handshake between your Denon and your television. Do you have anything else to connect to the Denon to see if you get a picture? How are you connecting the Denon to the television? Make sure you have your television on the proper input and check the cables going between it and the Denon.
May 25, 2011 | Denon AVR-1707 Receiver
I have a Denon AVR 790 for about 8 months now. Hooked up a combo DVD VCR player using the red/yello/white cables. It worked fine for about 6 months. Now I cannot get the DVD or VCR to play. I get sound,...
If dvd combo player is only video source connected with Denon AVR 790 then unplug yellow video wire from Denon and plug it directly in TV input, now video signal will go directly to tv and sound will come from Denon AVR 790 speakers during dvd playback.
This is simple bypass that wont effect surround sound of dvd playback.
Let me know if you have additional question.
Thanks.
Oct 20, 2010 | Denon Audio Players & Recorders
Noise coming out of speakers connected to Denon AVR 1908
Check for nearby wireless devices and move them away. -If the audio output from the source device (i.e. DVD, CD player) is digital (i.e. PCM, DTS or Dolby Digital) you're on your own. I'd be willing to bet the output is analog (red and white RCA), because the "beeps" and "exploding sounds" you describe seem like it could be caused by interference. Try replacing the cables. Otherwise the issue is probably with your receiver.
Aug 11, 2009 | Denon AVR-1908
Denon AVR 1705-no audio on TV
I have had the same problem and was told that it is a "board" inside. Essentially it has lost the surround sound ability and can only play things in Direct/Stereo. Mine is just over 2 years and I originally thought my kids had hit a button on the thing causing the issue...ended up paying $100 to trouble shoot it and confirm that it is internal and more expensive to fix than replace. Can't say that I will be buying a Denon again.
Jul 09, 2008 | Denon AVR-1705 Receiver
No sound for TV AVR 786
Check cables, see if other audio sources work through audio input ports.
Apr 24, 2008 | Denon AVR-786S Receiver
Denon AVR1602
I know the avr 1602 well....What exactly do you mean "I have my TV cable service wired to the Denon".....Do you mean the actual co-ax cable ?....
The denon is only able to switch raw video and audio signals.
What do I mean by that ?....IF you are running your co-ax cable from your cable company directly into the back of the denon, it won't work. The Denon has an AM-FM tuner, but not a video tuner ( channels 1-121)....If this is what you are doing, then you want to run it to your samsung first ( as long as the samsung has a tuner so you can change channels ).
If the samsung operates like an old VCR, whereby you can plug the cable company co-ax cable into the back of it, and change channels with the samsung, then that is what you must do. You would then hook up the OUTPUTS of the samsing to the VCR or DVD inputs on the Denon receiver. ( use DVD inputs on the denon if the samsung has optical audio out, and use an optical cable as well for better sound ).
You would then use the Denon for the sound, and hook up your TV to the Monitor out jack on the back of the Denon.
The Denon is like a big switchbox. You plug your DVD, VCR, Satellite, video game, or what-have-you into the Denon. Then you use the denon to route the signal to your TV for the picture, and the denon takes care of the sound.
Hope this helps, and remember to always follow your owners manual.......Rob
Mar 13, 2008 | Denon AVR-1602 Receiver
Denon AVR 2500 no sound from 3 of 4 speakers
Do you have a copy of the owners manual for the Denon AVR 2500? I can't find a copy of one.
Thanks,
Steve
Dec 18, 2007 | Denon AVR-2500 Receiver
Denon reciever
Sounds like you are exceeding the maximum power output of the receiver. Try disconnecting some speakers (and switch to A-only mode if your model has multi-zone) and see if that makes a difference.
Dec 31, 2006 | Denon AVR-2801 Receiver
Denon DVD-2500 DVD Player Logo
63 people viewed this question
Top Denon Televison & Video Experts
 Grubhead
Grubhead
Are you a Denon Televison and Video Expert? Answer questions, earn points and help others
