Question about Tools & Hardware - Others
Routine Maintenance? Are there any routine maintenance procedures for my B&D 7447 belt sander? I noticed today while using it that there appears to be an oil leak, and it smells kind of like gear oil. Is this a problem? Thanks for your time. T. Rourke
  • David Ford
    David Ford May 11, 2010
    I tried the B&D website and didn't find the tool you listed. Please check again and I will look at a breakdown and help you. But yes there different PM procedures. Let me know
    Sniper:
  • 86 Answers
This is an older model tool, not many parts are available. The problem will continue if you don't address it. The reduction geartrain is "permanently" (not so much) lubricated from the factory with a heavy weight grease. With age, time and enough use these less-expensive gearboxes get hot and the heavier solids separate from the oil base, causing the oily smell you are experiencing and presence of oil.
If you are mechanically inclined; I attached a link to the exploded diagram, you can open the geartrain, clean all the old stuff up and if the heat wasn't because the parts are visibly worn; then use a moly-based bearing grease from your local autoparts store (comes in a can, looks like a waxy paste). Coat the teeth so the grease fills the tooth gaps, but don't get carried away. Re-assemble and you should be good to go.
Honestly, this is an inexpensive sander, Ryobi makes a value priced model that works great if you choose to replace it verse service it.
Here's the diagram link
http://www.blackanddeckerservicenet.com/Products/DocumentView.aspx?productid=18190&typeId=1379&documentId=1235
Posted on Mar 01, 2009
Routine maintenance required needs to be reset
Routine maintenance is required ie fuser, charge roller, transfer roller & pickup rolls need to be replaced.
Apr 02, 2014 | Lexmark T650n Laser Printer
What car routine maintenance items ?
Routine maintenance items mainly include oil and oil filter, air filter , fuel filter and pollen filter replacement , spark plug maintenance / replacement , gearbox oil -related system checks and maintenance projects.
In addition, brake fluid, transmission fluid , battery , throttle , diagnostic tool , brakes and other components, when they belong in the regular maintenance of the test items , depending on usage Maintenance .
Nov 07, 2013 | Cars & Trucks
Printer is flashing "Clean Unable 46- Refer to Troubleshooting & routine maintenance in user's guide" BROTHER DCP-135C
printer is flashing "CLEAN UNABLE REFER TO 46- TROUBLESHOOTING AND ROUTINE MAINTENANCE IN USER'S GUIDE..BROTHER 2480C
Feb 23, 2013 | Brother Multi-Function Center MFC-3360c...
The Compressor on my Maytag M7DH65B2A quit running, I brought it to my shop and noticed corrosion and an oily residue on the sensor with the metal clip. Looks like the corrosion caused a hole in the coil....
This is a common problem with most dehumidifiers, not matter who the manufacturer is. The best way to prevent it is routine maintenance. Especially when you stop using it for the season. Dismantle it and clean the unit thoroughly. Putting a light coat of WD40 on the coils and contacts will help abate corrosion during the off season. If you are in an area where you use the dehumidifier continuously , then you should step up your routine maintenance to every 6 months. Cleaning the filter regularly, will help expand the dehumidifiers life span. By the way, the model you listed was manufactured by Fedders for Maytag.
Keep up the routine maintenance.
Apr 06, 2011 | Maytag M7DH65B2A Dehumidifier
Clean unable 46, See Trouble shooting and routine maintenance chapter in User's Guide.
Hi there. . . okay . . . Follow this step
1.) Unplug your printer.
2.) Plug your printer again while holding the menu button 15 sec.
3.) select 8 by using the arrow buttons ,push OK and select 0 and push OK
4.) then numbers appear looks like this ###:### ###:###.
5.) now push the MONO button until the purge:#### appears on the LCD
6.) Select 2, push ok, select 7,push ok,select 8,push ok, select 3,push ok
7.) - switch off the printer ,switch it on
- ready to print
- CHEERS!
 email me if I help you. . ryuuzaki182@gmail.com
Mar 20, 2010 | Brother DCP 165C Compact Color Inkjet...
1999 Nissan Sentra GXE timing belt/chain maintenance
good day Sir, your nissan sentra 1999 gxe have a timing chain this is some tips for your routine maintenance.
Replace engine oil
Replace engine oil filter i
Oct 29, 2009 | 1999 Nissan Sentra
Its says. see trouble shouting and routine maintence.chapter. in users guide,.but theres nothing there in the book
Hi there. . . okay . . . Follow this step 1.) Unplug your printer. 2.) Plug your printer again while holding the menu button 15 sec. 3.) select 8 by using the arrow buttons ,push OK and select 0 and push OK 4.) then numbers appear looks like this ###:### ###:###. 5.) now push the MONO button until the purge:#### appears on the LCD 6.) Select 2, push ok, select 7,push ok,select 8,push ok, select 3,push ok 7.) - switch off the printer ,switch it on - ready to print - CHEERS! email me if I helped you. . ryuuzaki182@gmail.com
Aug 29, 2009 | Brother DCP 130C All-In-One InkJet Printer
Want to do routine maintenance. is the filter
The filter is NOT in Hyundai's maintenance schedule (it's internal). However, if there's been a major malfunction of the transmission, the filter is replaced during overhaul.... It is not a routine maintenance requirement. However, the fluid is recommended to be replaced/flushed every 30,000 miles to assure warranty coverage. Contact your nearest Hyundai Service Center for more facts.
Jun 05, 2009 | 2006 Hyundai Tucson
Cleaning
unable to clean see troubleshooting and routine maintenance. unable to use it from then
unable to clean
Feb 19, 2008 | Brother MFC 420CN All-In-One InkJet...
Tools & Hardware - Others Logo
307 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
