Question about Acer TravelMate 290LCi Notebook
Computer goes into sleep mode when you first sign on
Whenever you first start up our computer it will go into sleep mode without warning and we have to do a hard boot on it to restart it.
    President:
  • 2,692 Answers
START - CONTROL PANEL - POWER OPTIONS -    POWER  SCHEMES. Ajust times.
If this is not hrte problem then go into the BIOS setup screen and turn off the BIOS power managment.
Posted on Jan 28, 2009
M305d-s4829 stuck in sleep mode
go to power potion and disable sleep mode
Jan 30, 2013 | Toshiba Satellite Computers & Internet
Enable Hibernation in Windows 7 Starter on Samsung N150
Sleep mode on a Windows 7 PC saves power without you having to turn your computer off and without losing any work. This option cuts the power to your monitor, powers down the hard drive and pauses all functions until you awaken the computer from hibernation. Whether you have a laptop, desktop or workstation, putting your computer into sleep mode will lower your electric bill and save money! Click the "Start" button in the lower left corner of your desktop. In the lower right corner of the Start menu, next to the "Shut Down" button, is a button labeled with a small, right-pointing arrow. Mouse over the arrow. The Shut Down menu appears. Point at "Sleep" and click on this option. Your Windows 7 computer goes into sleep mode. Wake your computer from sleep mode by jiggling the mouse. There may be a delay of a few seconds before your hardware powers on. All of your open programs are still open and your work is intact, just as you left it before the computer entered sleep mode. Configure your Windows 7 PC to go into sleep mode automatically when it is not used for a certain amount of time. Click "Start" and select "Control Panel." Click "System and Security." Click "Power Options." A menu opens. Click on "Choose when the computer sleeps" and select the number of minutes of inactivity. You can also set a separate time interval to put your monitor into sleep mode. If you set both to 10 minutes, then your PC and monitor will automatically go into sleep mode after 10 minutes of inactivity Your Computer in sleep mode b> First, save all of your work. Information in computer memory is not saved while your computer is on standby. From the Start menu, select Settings, then Control Panel, then Power Management. Click Standby Beside When I Push the Power Button. Push the Power button. b> Automatically Putting Your Computer on Standby b> Save all work before leaving your computer. From the Start menu, select Settings, then Control Panel. Double-click Power Management. Set the times that you want your system to go on standby, to shut off the monitor and to shut off the hard disks. Click OK. Your computer will go on standby according to the schedule you have entered. b> Putting Your Computer in Hibernation b> From the Start menu, select Settings, then Control Panel. Double-click Power Settings. Click on the Advanced tab. At the When I Push the Power Button On My Computer screen, click Hibernate. Click the Power button. Hope this helps.
Jan 16, 2013 | Samsung N150 Series Netbook
Windows sleep mode problems
Dec 21, 2012 | Computers & Internet
Won't go into sleep mode
Which operating system ?
A menu opens.
Hope this helps.
Nov 25, 2012 | Dell Factory Refurbished 4700-HH79N81...
My laptop shuts off automatically without warning
Go to settings. Click on power savings and you can set when the unit goes into sleep mode. You can also set it to never sleep.
murf427
Aug 02, 2012 | Computers & Internet
Hit start Alienware computer goest to alien head on screen then straight to sleep mode. Please read
When you say computer clock do you mean the LED read out on the mother board? if so the numbers you are seeing are error codes you will need the mother board manual to know what those codes mean. If you don't have the manual it's possible you can go to the mother board manufacturers web site and download one then you can look up the codes to see what the problems are. Hope this helps
Jul 26, 2012 | Alienware PC Systems Computers & Internet
I have my acer p205h 20 inch monitor hooked up to my tobshiba laptop and it works great except it will not go into sleep mode when laptop goes into sleep mode the monitor goes to there is not signal check...
Unfortunately, this is a standard problem, as when your laptop goes into sleep mode, it shuts off power to the secondary monitor, without giving it the signal to go into sleep mode. You could try digging around your settings, but most likely you'll just need to turn off the monitor when you're not using it.
Mar 01, 2011 | Acer P205H Widescreen LCD Monitor
I've got a HP w1907v monitor and latly it has been going into sleep mode without warning while i'm using it. All my power saver settings are set to off.
If this monitor is going into sleep mode the normally blue power led will change to yellow. This indicates loss of video signal or possible out of range resolution. If the picture goes dark and the power lite stays blue, you have a backlight malfunction. It can be an inverter power fault but this model mostly has worn out backlights causing a shutdown condition.
Monitor Mike
Aug 18, 2010 | HP w1907 LCD Monitor
Computer goes to sleep before it even starts up
Hi there, it appears as though the Power Options are set too short a time and the PC is going into sleep mode. Go to Start menu/Control Panel and look for Power options. Set them all to "never" This will prevent her PC from going into sleep mode. Good Luck.
Oct 26, 2009 | Dell Dimension 4600 PC Desktop
Low battery warning
That is because while a computer is in sleep mode, it is still using power to keep the memory. The battery is only used when the computer is turned off. You should replace the battery as soon as you can in order to keep your computer running properly.
Jun 29, 2009 | Dell Dimension 2400 PC Desktop
Acer TravelMate 290LCi Notebook Logo
145 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
