Question about Panasonic SC-PT1050 System
Can't get sound from the wireless subwoofer
I followed the instructions which were turn on wireless subwoofer. While pressing >>/>> on the main unit, press the numbered button (3) on the remote until "P" lights in the main unit's display. While "P" is displayed, press ID/SET. While pressing >>/>> on the main unit, press the numbered button (3) on the remote. The WS lights on the main unit's display. Turn subwoofer off and on again. Make sure its indicator lights up green. What is happening when I take these steps is, the W1 stays lit, the WS next to it flashes. The indicator light goes green for a second, then back to red. No sound comes from the subwoofer throughout the process. All the other speakers are working fine. They have speaker wire to connect to the wireless system. The subwoofer doesn't have any wires, except the power cord. Please help. I am so close! Thank you. Missy
  • zdenneh Jan 05, 2008
    I have a similar problem. I've got everything set up but the sub. The sub is plugged into the wall and i've pushed the the on/off button on the sub yet there is no red light, green light, or any light whatsoever coming from the indicator light. I've tried swapping the ac cord with the other equipment and everything works fine but the sub. It has no power. Apparently mine is defective. I spent hours trying to figure out why I could not get a green light till I finally read somewhere I should at least be seeing a red one to begin with.
I had the same problem and it turned out that the directions are very unclear. You need to not only press the ID/SET button on the wireless system, but also on the wireless subwoofer itself. That solved my problem.
Posted on Oct 04, 2007
    President:
  • 1,114 Answers
There are 2 things you can try, first ensure that the digital transmitter is fully inserted into the slot of the main unit. Secondly do you have any other wireless devices near such as cordless phone or wireless network equipment? See page 5 of the installation manual as per this picture.......
Posted on Jul 26, 2007
My Panasonic inverter split zircon with r410a blinking the red timer running indoor motor while out door unit not running?
To display memorized error (Protective operation)
status:
1. Turn power on.
2. Press the CHECK button on the remote controller
continuously for 5 seconds.
3. "- -" will be displayed on the remote controller display.
Note: Display only for "- -". (No transmitting signal, no
receiving sound and no Power LED blinking.)
4. Press the "TIMER" or button on the remote
controller. The code "H00" (no abnormality) will be
displayed and signal will be transmitted to the main
unit. The power LED lights up. If no abnormality is
stored in the memory, three beeps sound will be
heard.
5. Every press of the button (up or down) will increase
abnormality numbers and transmit abnormality code
signal to the main unit.
6. When the latest abnormality code on the main unit
and code transmitted from the remote controller are
matched, power LED will light up for 30 seconds and
a beep sound (continuously for 4 seconds) will be
heard. If no codes are matched, power LED will light
up for 0.5 seconds and no sound will be heard. 7. The breakdown diagnosis mode will be canceled unless pressing the CHECK button continuously for 5
seconds or operating the unit for 30 seconds. 8. The same diagnosis can be repeated by turning
power on again.
To clear memorized error (Protective operation) status after repair:1. Turn power on.
2. Press the AUTO button for 5 seconds (A beep
receiving sound) on the main unit to operate the unit
at Forced Cooling Operation mode.
3. Press the CHECK button on the remote controller for
about 1 second with a pointed object to transmit
signal to main unit. A beep sound is heard from main
unit and the data is cleared.
• Temporary Operation (Depending on breakdown status)
1. Press the AUTO button (A beep receiving sound) on
the main unit to operate the unit. (Remote control will
become possible.)
2. The unit can temporarily be used until repaired
Apr 24, 2017 | Panasonic Heating & Cooling
How do I program the jamo torsten sound bar to my remote control?
Great product, horrible instructions that focused on every language known to man rather than clear steps. Hope this helps....for the JAMO TORSTEN 2 WAY SOUNDBAR W/ WIRELESS 10" SUB 360 Series, as well as other Klipsch soundbars.
If the SoundBar is in STANDBY mode (solid RED status light), push the <SOURCE> button on the SoundBar until the status light is solid GREEN.
STEP ONE (Place the unit in learning mode): With the status light showing solid GREEN, press and hold the <SOURCE> and <MUTE> buttons on the front of the SoundBar at the same time (approximately 3 seconds) until the status light flashes RED and GREEN.
STEP TWO (Select the function to learn): Press the <MUTE> button once on the SoundBar (the status light changes to solid ORANGE).
STEP THREE (Learn the function): Hold your remote control within one foot and pointed at the front of the SoundBar. Slowly press the <MUTE> button on your remote control four times. On the first three presses, the status indicator light will flicker ORANGE with each press. If the unit has successfully learned the function, on the fourth press of the button, the light will flash GREEN several times and then turn to solid GREEN.
To program the remaining functions, simply repeat all steps, substituting <MUTE> with the new function and button presses (VOLUME UP, and VOLUME DOWN) on steps TWO and THREE.
Apr 28, 2014 | Jamo Torsten Soundbar with 10" Wireless...
Programming time warner remote to boston tvee volume
I had just about given up on programming my Time Warner universal remote with my Boston Soundbar until a mental lightbulb came on. This is a two step process. Step 1: Program your Time Warner remote (I have CLIKR-5, instructions available for other models at timewarner.com) Using Pre-Programmed 3-digit Code method -Turn on soundbar - Press device button (I chose AUX) and OK/Select simultaneously until device button stays lit. - Point remote control toward the soundbar and enter code (447 for Boston Acoustics) - Press the device button again to store the code. The TW instructions say you should now be able to turn the device off to verify that it works, but this is not true for the soundbar. Hang in there with me. Step 2: Program your remote from the Boston Soundbar. - Press the power button and the volume up button simultaneously until the indicator light flashes orange. Here's where the instructions provided with the soundbar fail to explain how to do this. Each button is individually programmed into the TW remote. What you have done so far is enable the remote to accept the programming. - Volume Up: press the volume up button on the soundbar while it is flashing, the light should become steadily orange. - While holding the remote steady about a foot away from the soundbar, slowly press the volume up button on the TW remote four times. The orange light should flicker each time you do, turning green when completed. - Volume Down, Mute, Power: repeat the steps for Volume Up, except press the button on the soundbar you wish program to the TW remote while the soundbar is flashing orange. It should become steady before you press the corresponding button on the TW remote. Good luck, I hope this helps. -Deidre.
Dec 05, 2012 | Boston Acoustics TVee Model 25 Sound Bar...
Philips DC912/37 will not pair with the subwoofer. I have had the device for 2 years, and the subwoofer stopped working recently, and now it will not pair with the tuner.
This worked for me. Try it and it should work for you all as well..;-)
Frequently asked questions See all FAQs Question How do I get the main unit to recognize the subwoofer? Answer Wireless connection will set up automatically when you switch on both the main unit and subwoofer.
Sometimes you may encounter the problem that the main unit does not recognize the subwoofer. Try the following process to solve the problem:
  • They are heavily interfered by other wireless home appliance such wireless network, TV etc. Move the subwoofer to another place, the main unit will auto detect & recognize it.
  • Switch off the main unit and the subwoofer and then switch on them again. The main unit should recognize the subwoofer automatically.
If neither of the above works, try to pair with them manually.
  1. In standby mode, press and hold the 090518075138_27245.gif button on the main unit (PAIR flashes on the display screen.) to activate signal transmitting.
  2. Press and hold the PAIR button on the rear of the subwoofer (You will find the LED indicator on the subwoofer flashes in blue and green alternatively) to activate signal receiving.
The wireless connection will set up automatically and the main unit should recognize the subwoofer now.
Dec 21, 2010 | Philips DC912/37 iPod Docking Shelf Bar...
I have SC-PT750 Wireless system with SH-FX65T and SE-FX65, the wireless does not work and the screen flashes W1 to W2 and the SE-FX65 red light stays on
1 Turn on SE-FX65 2 While pressing [>>/>>'] ] press the numbered button [3] on the remote control until "P" lights in the home theater unit's display The indicator on SE-FX65 turns green. 3 While "P" is displayed, press [I/D SET] 4While pressing [>>/>>'} press the numbered button [3] on the remote control.
This worked for me. I moved and lost the FX65A, and Had to buy a replacement off ebay,
Used this manual http://www.specsserver.com/CACHE/FRQUJVMNXTYS.PDF but I have to give mosyzlak props, cause he gave me the idea to look for it.
Nov 28, 2010 | Panasonic Home Theater System System
How can i pair my subwoofer to the main unit
Oct 13, 2010 | Philips DC912/37 iPod Docking Shelf Bar...
Garage door opener will not program the remote. After following directions on back of the opener the remote will not work. The doorbell button on wall the light keeps blinking. What do I do to fix this...
Reset both the units the door unit and the remote by cutting off supply for a while. Now it will move to the default settings. If the earlier process had hung the system then reset the codes given once again to allow the main control unit to lock on with the remote. follow as instructed till the remote locks.
If not contact the dealer as the main unit has some errors.
Sep 26, 2010 | Sears Craftsman LiftMaster Chamberlain...
I have a Samsung HT-z510 home audio and the wireless receiver for the back speakers stays in standby mode. I have set the mode to cinema but it still stays in standby. What can I check next?
Here is how I reset. Key terms to identify: Main unit, remote unit, transmission card, reset button on remote unit. 1. Unplug both units and remove transmission card from rear of Main unit. 2. Wait five minutes. Insert transmission card in rear of Main. 3. Turn on both units. If units do not communicate, there will be a solid red indicator on remote unit...In this case continue with 4. Use remote and turn off main. 5. Point remote at main and enter the following four digits, holding each down for about a second:  0   1   3   5 6. The main unit should turn on. 7. With remote unit on, press and hold down the reset button for 5 seconds.
Nov 29, 2008 | Audio Players & Recorders
DEH-2050MPG
Yesterday I installed the Pioneer DEH-2050MPG in an old Beetle I just bought, and had the same problem. The instructions were completely useless; Ignore them.
Here's how to set the time...
1. Hold the source button down until clock starts flashing.
2. Use arrow buttons to set time.
3. Press source again to save.
That's what worked for me.
Sep 25, 2008 | Pioneer DEH-P2000 CD Player
Subwoofer output
There could be a number of reasons causing this malfunction, try replacing the subwoofer's cord, it might be damaged, you can also try reseting the system to the factory settings according to the following instructions: Reset Instructions: 1. Press the power button to turn off the power 2. Press the power button while pressing the ENTER button. (note: this will reset all memory) Good Luck
Jan 09, 2006 | Aiwa AV-D57 Receiver
Panasonic SC-PT1050 System Logo
2,267 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
blanqui2000
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
