Question about Zenith C27A24T 27" TV
Get Analog How do I make the changes? When in affect? What will happen to my TV with reabbit ears? Ms M.A. Larson Grapevine TX 76051 214 552 0455
    Brigadier General:
  • 5,158 Answers
Should be fine as that appears to have a digital tuner built in
Robert
Posted on Jan 28, 2009
  • 242 Answers
Hello , If your tv set is not digital or HD you will have to get a converter box to convert digital into analog so it can be viewed on your tv.
  • Zenith Master
  • 13,433 Answers
United States, full-power television stations are scheduled change over to digital on February 17, 2009.
You will need a digital box for your tv to watch digital tv.
Sanyo hdtv model do 42647. 1080P tv
TV rabbit ears are for analog TV settings. You need an analog TV transmitter very close to the TV to get any good reception. Otherwise you need an antenna with more gain and more height to receive any analog TV transmitters in your area.
Aug 16, 2014 | Sanyo Televison & Video
I live in Victoria Tx. I can not afford cable or dish. I am able to recieve all 4 of the the number 25 channels. Why am I not able to recieve any of the three number 19 channes. All 19 and 25...
Channel 19 actually broadcasts on VHF channel 11 (approximately 201MHZ) and channel 25 actually broadcasts on UHF channel 15 (approximately 479MHZ). I know that sounds a bit weird but it has been done so that stations don't have to change there "call" channel number when we switched to Digital TV. Your digital converter box keeps track of this. This is important to understand because you need and antenna that is good at picking up both UHF and VHF signals. If you're not getting channel 19 it may be due to a poor VHF portion of your antenna. If your using a basic old set of rabbit ears for your antenna that has a loop in the middle then I might have a trick for you. Most rabbit ears have 2 telescopic antenna elements. Extend or collapse until each length is 14.7 inches long. (Which is a quarter wavelength at 201MHZ). You are effectively tuning (Optimizing) your antenna specifically for that channel 19. You may need to rotate your antenna a bit to find the best signal.
There are other factors which can hinder you receiving channel 19 but this is a good starting point. Let me know what type of antenna you have. Hope this helps.
Dec 03, 2010 | Insignia Digital-to-Analog Converter for...
We are in Ghana we need frequency and we update to get more channel
Your flat panel TV is probably factory set to receive ATSC signals (Hi-def DIGITAL TV), whereas
Ghana may not have converted from analog TV (NTSC) yet.
Digital TV's cannot receive analog signals. I'm just guessing about whether or not Ghana supports
Hi-Def broadcasts - you'll have to check with (any) TV channel in Ghana. The Analog-to-digital
conversion is an expensive one at the broadcast end, and may not have happened yet in Ghana.
The US conversion took place by FCC mandate June 12, 2009.
There are available $65 (USD) digital-to-analog converters, but what you may need is an
analog-to-digital converter, which doesn't exist. Your Flat-panel TV amy have to wait until Ghana
begins broadcasting a Hi-Def TV channel.
For a HD antenna, a regular old rabbit ear-type antenna will do.
Oct 15, 2010 | Televison & Video
Digital Converter connection with old Rabbit Ears TV
First, make sure your connections are right. The rabbit ears need to be disconnected from the TV and reconnected to the converter box. Then the output cable from the converter box connects to the TV. Then try turning the rabbit ears or re-locating them near a window if the wire is long enough. You should be able to get some signal. A newer indoor antenna may help you pull in some of the weaker stations.
Jun 15, 2009 | Insignia Digital-to-Analog Converter for...
Clunk/knock sound coming thru steering column from front wheels.
Sounds like the sway bar stabilizing links are shot.
May 14, 2009 | 2005 Lexus LS400
Analog or dtv
Hi, This tv has an NSTC tuner which is analog. If you subscribe to cable or satellite it will work just fine without you having to do anything for the upcoming change. However if you are using your own outside antenna or rabbit ears you will need a converter. Hope this helps.
Jan 30, 2009 | Philips 20PT6446 20" TV
Wish to record on analog VCR and not affect digital TV reception
I don't think it will affect the digital TV reception, but if you try to use the VCR built-in tuner it is still analog and you won't be able to record digital channels that way. If your digital TV converter has video-out and audio-out connectors, then you can connect those to the corresponding connectors on your VCR to record.
Dec 28, 2008 | Insignia Digital-to-Analog Converter for...
Is this an analog or digital television?
I e-mailed Sanyo, and their response is that this TV has an analog tuner so you will need a converter.
Feb 23, 2008 | Sanyo DS27510 27" TV
Zenith C27A24T 27" TV Logo
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
