Question about Brother MFC-3240C All-In-One InkJet Printer
After the drivers load, when it come to the place in the install to plug in the printer it does not see it. I installed this printer on another computer and it worked just fine. I also pluged a jump drive into the usb port and it sees it just fine. The computer is a toshiba satellite, with a fresh install of windows. I don't know anything else to try, I even used a different usb cable, nothing !!!!
  • Anonymous Mar 17, 2009
    I have windows xp and I have been using this printer up until I had to reconfigure my computer and now it will not pick up the printer is there a solution for this
  • 2,692 Answers
Did the other computer have the same version of windows as this one?
Below is the link to the BROTHERS support website for your model printer:〈=en∏=mfc3240c_all
Posted on Jan 28, 2009
1) Turn on the Deskjet D2360 and the computer. Make sure the USB cord is not plugged into the printer.
2) Open the computer's web browser and go to Click on "Support and Drivers" at the top of the page and select "Download Drivers and Software." In the blank box type "Deskjet D2360" and press "Enter." Select the operating system your computer is using, then click on the "Full Software and Drivers Download" link. A download dialog window will come up. Choose a place on the computer's hard drive to save the installation software
3)Double-click on the installation software to launch the installer. Follow the on screen instructions, which will vary based on the operating system you are using. When the installation process is completed, restart your computer
4)Plug the USB cable into the printer and computer, making sure it is securely in place on both ends. The printer is installed and ready to use.
If this answer helpful please vote me. Good luck.
Thanks for using FixYa
Jan 12, 2011 | Office Equipment & Supplies
I Just install Windows 7 Home Premium and have a OKI c5150n printer connected by a wired router. My XP machine prints fine but I can't get "7" to show my printer drivers after loading them. I...
in the install did you set the printer as a local printer or a network printer? try connecting the printer to the pc with windows 7 directly this should load the correct driver under plug and play once it sees the printer connected. once the driver is set and you go through the install of the printer set it as a network printer.. and specify that it is connected over the interface for the wired router. hope this helps.
Dec 11, 2010 | Computers & Internet
I can't get the down load for the Lexmark x1240 to work. I have down loaded it but when I try to get the computer to recognize the printer, it doesn't or it doesn't let it connect
Did the drivers install completely?
If so, try plugging the printer USB cable in a different USB socket, one that you did not plug the printer into before. If you don't have a "fresh" free USB socket, you can always swap plugs with the mouse for example.
Te computer should discover your printer and use the already installed driver.
If the driver did not install at all, try installing it again with the printer unplugged from USB, and plug it in to a "fresh" USB socket (as described above) only when asked to by the installer software.
Nov 22, 2009 | Lexmark X1240 All-In-One InkJet Printer
I tried to load the Lexmark x125 to windows vista and it would not print once it was loaded. I found on the internet to run C:/Drivers/printers/1200. I uninstalled Lexmark X125 then ran the program. It was...
Are you saying that the computer crashed? Try plugging in the printer without installing the driver. The computer should recognize that you plugged it in and search for a driver. Do you get that far?
Do you have the original installation CD? If not, then download the driver software from Navigate to the support and drivers section and get the proper driver. Then try to install it that way.
Mar 15, 2009 | Lexmark X125M All-In-One Printer
I can not install printer software on vista 64 ultimate
Download the vista 64 driver and then let windows install the printer with you telling it where you place the driver on you computer.〈=en&product=439491
Jan 22, 2009 | HP Photosmart 3310 Printer
Printer installation?
You will have to reload your printer. Plug the printer to your computer and reboot. The Plu and Play should recognize it. Then the Ad Hardware Wizard will pop up. Load the CD that came with the printer and the Wizard will allow you to load and configure the printer driver. Once the drivers are loaded you can print a test page. If it is a USB printer then load the drivers first, then plug your printer in and reboot.
Dec 24, 2008 | Canon MultiPASS C555 InkJet Printer
I need to install my lexmark x7170 all in one but i lost my install disk what can i do.
IF you have Vista when you plug in USB cable it automatically loads drivers for your printer no disk needed.On rare occasion it may not find it but check the Lexmark website for your printer and download drivers to computer.Disconnect printer from computer then install drivers.After drivers load then plug in usb from printer and they should automatically load and find printer.
Oct 06, 2008 | Lexmark Office Equipment & Supplies
Plug and play problems
Let me ask one question. Have you loaded the print drivers for your printer. If not do so. This will fix the problem.
Feb 12, 2008 | HP PSC 2175 All-In-One InkJet Printer
Make sure if driver are properly installed...Go to bios and OPEN ALL USB PORTS...Check the USB HUB PORT IF THEY WORKING PROPERTLY!!!
Oct 17, 2007 | Lexmark X1270 All-In-One InkJet Printer
Problems installing a printer
You can follow the steps below to install a resident printer driver which is part of your operating system.
NOTE: Windows should detect and automatically install devices attached via the Parallel or USB ports on the computer. You should be able to attach the printer, and the "Plug and Play" feature will install the appropriate driver.
If the driver does not automatically install, please contact your Computer vendor. The "Plug and Play" feature may be disabled within your computer.
The resident driver installation should only be used if the printer is not detected and installed.
1. Start by opening the "Printers and Faxes" window. Click on "Add Printer" on the left hand side of the screen.
2. The "Add Printer Wizard" screen will come up. Click on "Next".
3. At the "Local or Network Printer" screen, select "Local Printer" and place a check on "Automatically Detect and Install my Plug and Play Printer". Click on "Next".
4. Windows should report it will check for Plug and Play hardware. It should also detect and install the appropriate resident printer driver.
5. A window will appear and tell you when the process is completed.
*NOTE: If Windows does not detect your printer automatically, you can manually install the printer. Simply select EPSON under manufacturer and select your appropriate model under PRINTERS.
6. When the printer is installed, it will ask you if you would like to print a test page. Check "Yes", then click on "Next".
7. The next screen will display the settings for the printer. Click on "Finish" to complete the installation and print the test page.
May 27, 2006 | Epson LX-300 Matrix Printer
Brother MFC-3240C All-In-One InkJet Printer Logo
41 people viewed this question
James Cagle
James Cagle
Jim Keysor
