Question about HP Color LaserJet 2600n Printer
Problem to print envelopes
How to print envelopes for printer 2600n
  • 3 Answers
U can change the size of the paper size , u can make that from the default settings o, u can get that by making right click at the printer in control panel --> printers --> right click the Properties , u must be the administrator user of that computer , or press shift + right click the choose Run as .
Posted on Feb 04, 2009
How do I print legal size envelopes using 2600n laser jet printer?
Use the manual feed tray(tray 1).
Do one as a test to make sure that it is facing the correct way.
May 11, 2011 | HP Color LaserJet 2600n Printer
Hello I have an HP 2600n and would like to print on 5x7 paper, is this a possibility with this printer? it seems that it will pull the paper through but nothing is printed
Copied this from the specification on HP site.
It would appear not to take 5 x 7. It's the 7" is to small, 8.5 is the smallest.
Media sizes, std.
Letter, legal, executive, No. 10 envelopes, Monarch envelopes
Media sizes, custom
Tray 1, 2, 3: 3 x 5 to 8.5 x 14 in
Media types
Paper (plain, letterhead, prepunched, bond, color, rough, preprinted, recycled), HP Color Laser Glossy Photo Paper, HP Color Laser Glossy Brochure Paper, HP Color Laser Matte Brochure Paper, HP Color Laser Matte Photo & Imaging Paper, HP Color Laser Soft Gloss Presentation Paper, HP color laser transparencies, labels, envelopes, cardstock
Nov 30, 2010 | HP Color LaserJet 2600n Printer
What is the maximum weight of paper can you put in the printer?
Plain paper (60 to 90 g/m2), heavy paper (91 to 163 g/m2), envelope
(Envelope DL, Envelope COM10, Envelope C5, Envelope
Monarch, Envelope B5), label sheet, transparency ((Black and white
printing only)
Jun 10, 2010 | HP Color LaserJet 2600n Printer
It seals every envelope I print
The humidity is too high in your location, or the envelopes are using a very soft glue. The heat produced by the fuser is bonding the glue.
Try different envelopes, you might have a brand that is more heat activated and less moisture activated. Try placing a de-humidifier where your printer is, will help alot.
Jun 23, 2009 | HP Color LaserJet 2600n Printer
Print en enveolppe with hp color laser jet 2600n
Envelopes can be printed from tray 1 or 2. Select the type of envelope you are using from the PRINT dialog box or the driver. In your program, set the margins. Typical margins for a commercial #10 or DL envelope would be: Return Address Top margin 15mm(0.6 Inch) Left margin 15mm(0.6 Inch), Delivery Address Top margin 51mm(2 Inches) Left margin 89mm(3.5 Inches). For the best print quality, position margins no closer than 15mm (0.6 Inch) from the edges of the envelope. Avoid printing on the seams of the envelope. Envelopes with a peel-off adhesive strip or more than one flap that folds over to seal must use adhesives that are compatible with the heat and pressure of the printer fuser. the extra flaps and seals can cause wrinkling, creasing and feed jams, could even damage the fuser.
Apr 15, 2009 | HP Color LaserJet 2600n Printer
Printing envelopes
Try setting the page setup to 8.5x11 and adjust the margins to landscape, top and left margin approx 4". A lot of times the envelope templates are afterthoughts.
Pagemaker programmer's supervisor, "Forget that template, nobody will ever print envelopes in Pagemaker"
Hope this helps!
Mar 02, 2008 | HP Color LaserJet 2600n Printer
Envelope printing
did you go to the menu in the printer and set it in yhe paper options to envelope? You MUST also set it in the PC.
Go to
1- file
2-Print
3-right click on your printer
4-Properties
5-Device settings
6- set tray 1  to envelope
Oct 12, 2007 | HP Color LaserJet 2600n Printer
HP Color LaserJet 2600n Printer Logo
100 people viewed this question
Ben Johnson
