Question about Craftsman 16" High Garden Tractor Snow and Dozer Blade
Snowblower Auger rubber has worn out basically after 2months of u
I bought a single stage craftsman snowthrower from sears on Feb 12th, 2007 and less than a yr later i took it to the repair center coz, it was stalling out. The tech indicates that water got into the carburator and also the rubber on the auger has worn all the way to the steel......which needs replacement and it's gonna cost $212 to repair. Sears tells me that my manufacters warranty is not gonna cover this. How common is this problem?? Is this a bad model snowthrower? What's a reliable and durable name brand snowthrower out in the market today??
  • Anonymous Jan 29, 2009
    Hey Jer! Ty for the reply. I just gave in to the sears repair people and told them to go ahead and fix it....they told me it's gonna cost about $158.
    How come the rubber on the auger wears out so quickly??.....i've really used only about 10 times.
    Jer - u said that the rubber will wear out quickly if the snowblower is not operated properly. What does operating properly mean??.....i just push it up and down the driveway and sidewalk the way u would with a lawn mower. What's the proper way to operate this machine? thanks.
SOURCE: manual
goto sears.com click parts. type in your model # when page opens will be on the right of page asks if you would like to see owners manual you have to sign in to manage my home ****, but I found it there.its free just wants email address to send you junk mail.
Posted on Dec 15, 2008
SOURCE: Auger stopprd working on an MTD snowblower.
The manual has a step by step procedure for adjusting the cables for the auger, speed selector and drivewheels. One socket wrench and about 10 min should do it.
My Yardworks is an MTD product and it's manual should be similar to yours. If you lost it, you can download it from MTD's site.
Posted on Dec 26, 2008
efs_perpends
  • 1996 Answers
SOURCE: Need manual for a sears craftsman router
Try ManageMyHome.com. That's the online sears store for manuals, etc.
Otherwise, for older craftsman routers you might have some luck here.
Here's one that's pretty close.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Aug 29, 2009
  • 12744 Answers
SOURCE: who sells craftsman parts besides sears?
check with any place that carries or repairs small engine or farm equipment call or bring model number they can cross reference the part number for other comparable parts some parts are craftsman only and they will be able to tell u also a lot of online companies carry many parts also
Posted on Oct 01, 2009
Testimonial: "Thank you!"
  • 10 Answers
SOURCE: I need to replace my table saw switch assembly
I am not getting either # from sears parts. I deal in Craftsman Belt drive table saw parts. I should have a switch that would work for you. Can you send a picture? jimatcavanaungh@cs.com
Posted on Feb 12, 2010
I have an MTD single-stage snow blower that I replace the other the cable and the belt and under a load it's still not throwing snow
There should be 2 holes on the handle that engages the auger belt, use the top hole as it will increase the belt tension.
Check the condition of the rubber auger's rubber paddles as they are subject to wear and should be replaced if any signs of excessive
wear is present.
Jan 31, 2016 | Craftsman 21" 179cc* Single Stage...
I have a MTD snowblower yard machine.how to adjust
There should be metal shoes on the side of the snowblower. They have adjustment bolts that allow the auger housing to move up and down. loosen them and adjust to how close you want it to the ground. It also depends on the model. This process only applies to large self propelled models which are a two stage snowthrower. if its a small single stage there is usually no adjustment.
Oct 19, 2014 | Garden
Auger keeps spinning after releasing handle
so what is your question as long as it is spinning when you are using it and it is throwing snow so what
Jan 26, 2014 | Craftsman 21" 179cc* Single-Stage...
Craftsman model c950-52126-0 snowthrower wont move
I tried searspartsdirect and Sears doesn't show that model. Are you sure it's the correct model number ??
Is it gas, electric ... single stage or two
Have you tipped it up on it's auger (service position) and taken the bottom panel off to look inside and see what you can see ??
Jan 11, 2014 | Garden
Where is the auger sheer bolt
Figure 9 on Page 11 of the manual (linked below) shows the location of the auger shear pins. Do NOT substitute bolts for shear pins!
http://www.searspartsdirect.com/partsdirect/user-manuals/8227/536881800-Craftsman-Parts-SNOWTHROWER,+GAS-manual?pathRender=fromManualTabPage
Feb 11, 2013 | Craftsman Sears Snow Thrower Manual Model...
Have a craftsmand 24" snowthrower
If the motor runs well, the two most common causes of this are the drive belt is worn and/or the shear pins are broke.
If you remove the cover (usually plastic) in the middle of the snow thrower and look at the belts.
Your operator's manual will show you how to remove the cover and check/change the belts.
If you don't have a copy you can get the manual through managemyhome.com
You will need the model number off the snowblower. It is usually located on the bottom right hand corner of the frame (from the handle side)
The model number looks like 247.123456.
The belt closest to the blower assembly drives the auger/blower and the belt closest to the engine drives the transmission. It sounds like you need to inspect the blower belt.
With the engine not running, have someone depress the drive lever and check the belt.
You should only be able to depress the long side 1/2 inch or less. More than that the belt has stretched and needs to be replaced.
On some older blowers you can adjust the tension pulley, but most made in the last 15 years, you can't.
The belt may be frayed on the edges or glazed causing it to slip (it is shiny on the sides of the belt) It may be torn and broke completely.
Replace the belt if it is worn, stretched or frayed
The shear pins are located on the auger in the front of the machine. Your newer Craftsman has four. If you don't now about them look in your operator's manual for the location. You need all four for the snowblower to work well. Replace the missing ones.
You can get parts for you Craftsman and most MTD made models through searspartsdirect.com. With other makes you can get parts through jackssmallengines.com
If you are unfamiliar with repairing machines you can get your snow blower repaired by taking it to your local Sears.
They will have a technician troubleshoot and repair the unit.
Feel free to ask any other questions. I know Snow Blowers. Please remember to rate this answer!
Jan 13, 2011 | Craftsman Garden
My Craftsman 5.0 horsepower 5 speed forward, 2 speed reverse snowblower has a problem with the auger. After using it this morning working fine now the auger isn't turning. It's about 8 years old and has...
If the blower (impeller) turns and the auger doesn't there is a 90% chance you broke the shear bolts that protect the auger gear box.
Look at your auger and you will find the bolts shown at the arrows in this picture are missing. Some snowthrowers will have two bolts and others like the new Craftsman will have four.
You can get new ones at your local mower repair shop, your local Sears mall store, or online at sears.com.
Use shear pins or shear bolts not regular bolts. The shear bolts are designed to break off so you don't tear out the front gear box.
Feel free to ask any other questions. Don't forget to rate this answer!
Jan 12, 2011 | Craftsman Garden
I broke a belt on the snowblower. How do i change the belt?
take the side panel off and loosen the belt tensioner, replace belt and re tension
Jan 06, 2011 | Garden
Auger blades won't turn
You need what they call a "friction wheel" replaced.
Oct 31, 2009 | Garden
Craftsman 16" High Garden Tractor Snow and Dozer Blade Logo
254 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
