Question about Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal
Rose stem clippings have clogged my Badger 5 in sink erater. How can I relieve this?
    President:
  • 1,214 Answers
With power turned off and disposal unplugged (reach under sink), remove any rubber dampers in the throat of the sink drain by pulling on it.
Then, reach you hand into the disposal and remove any clippings that you can by hand.
Get a wooden dowel, like a broom handle or plunger handle, and lever against the cutter plate of the disposal and the side of the sink drain to get the disposal cutter plate to turn. Try both ways.
Once free, plug unit back in and try to run it. DO NOT PLACE YOUR HANDS NEAR THE DISPOSAL SINK OPENING! WATCH FOR FLYING OBJECTS COMING OUT OF THE DRAIN.
If all runs clear, replace the rubber part in the drain.
If it doesn't run clear, and the disposal hangs up again, repeat all of the above.
If disposal quits, there is a red reset button on the bottom that can be pressed to reset after the motor cools for about 15 minutes.
Posted on Jan 28, 2009
How to Dismantle an Under the Sink Garbage Disposal
Full user manual for this here. Cleaning it etc.
Don't think you would destroy the seal if you are careful. Sure you could get a spare if you did from their answerline at top of manual.
http://www.scribd.com/doc/9725184/Badger-5-garbage-disposal-user-manual
Sep 14, 2014 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
My Badger 5 in sink erator is leaking at the bottom of the unit where the electrical wire is connecting tot the metal plate. When turned on, there is a humming noise but the blades do not spin. I have
Thier is an Allen key hole at the very bottom and center of the badger. Try using that with an Allen key. And if it leaks your from where your wires are coming out of your seal is probably bad. Means new badger
Nov 27, 2012 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
My 555 in sink erator is not working and my sink is stopped up
Here is a tip that I wrote that will help you to figure out what is going on with your garbage disposal and why it is not working.
Garbage Disposal Clogged or Jammed
heatman101
Feb 11, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
My badger 5 plus in sink erator is not working
Here is a tip the I wrote that may help you to figure out what is going on with your garbage disposal and why it is not working.
Garbage Disposal Clogged or Jammedheatman101
Sep 04, 2010 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
Why is my badger .5 plus in sink erator leaking
One of your connections is either broken or missing a rubber gasket or a hose clamp. You have a lock ring on the top that basically bolts to the drain of the sink which is part of the disposal, IT has a rubber gasket or two on it, some have plumbers putty on the very top, the hose that goes from the dishwasher, if you have one, has a hose clamp on it, the drain line into the trap is a compression fit, needs to be tight, and it is usually bolted or screwed into the disposal itself with a rubber gasket. Check these out and tighten them up. Hope this helps.
May 13, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
In sink erator is leaking from bottom
I had this happen right before my disposal stopped working completely. Mine was leaking from the same place. The one I had was a 2 year Badger. They are easy to replace. If yours still works I would keep using it and just sit a pan down below to catch water. A new Badger 1 year cost $80 at Home Depot. If you get one, do not worry about buying extra gaskets or the black sink strainer thing because the new one will come with everything needed except for the plumbers putty. You will need plumbers putty. Good Luck
Jul 20, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Water draining backinto dishwasher from garbage disposal
You have a clog where the drain pipe leaves the garbage disposal that isn't draining fast enough or not at all. Or it could be a clog in the dishwasher drain hose where it connects onto the disposal.
Apr 07, 2009 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
My gargabe disposol won't turn off.
sounds like the wall switch needs to be replaced.
Apr 05, 2009 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal Logo
88 people viewed this question
Top Ace Hardware Electrical Supplies Experts
handygirl911
handygirl911
Mike
Treefrog15
Treefrog15
Are you an Ace Hardware Electrical Supply Expert? Answer questions, earn points and help others
